If Moore has time, he's going to switch his aura back to the dex one. I doubt it'll help, but you never know.
No time unfortunately Moore, this is happening pretty bang-bang. A readied action could, but alas.
Dex check, Ithea. +4 bonus for every 10ft your base movement speed is above 30ft.
Well, it'll be switched to the dex one whenever it can be.
[20:34] <Merc> roll d20+7+11+4 dex+brains+speed bonus
[20:34] <Kobot> Merc rolled d20+7+11+4 dex+brains+speed bonus --> [ 1d20=13 ]{35}
As the others watch, Ithea dives through the wall's gap. She's just fast enough, for a split second after she's through, another stone wall appears. You're past it - and here two earth elemental monoliths loom well over you, looking down. Neither looks the slightest bit amused as...
Init here. This includes everyone on the other side of the wall, in case someone tries to get through it.
[20:39] <Merc> roll d20+22+5 nerveskitter
[20:39] <Kobot> Merc rolled d20+22+5 nerveskitter --> [ 1d20=2 ]{29}
[20:39] <Merc> roll d20+3 Balyss
[20:39] <Kobot> Merc rolled d20+3 Balyss --> [ 1d20=10 ]{13}
[20:39] <Merc> roll d20+12 Crystal
[20:39] <Kobot> Merc rolled d20+12 Crystal --> [ 1d20=20 ]{32}
[20:40] <Merc> roll d20+14 Hope
[20:40] <Kobot> Merc rolled d20+14 Hope --> [ 1d20=15 ]{29}
[20:40] <Merc> roll d20+3 Smrgol
[20:40] <Kobot> Merc rolled d20+3 Smrgol --> [ 1d20=16 ]{19}
[21:41] <Nephrite> roll 1d20+20 (+11 more if the aura was allowed to be changed)
[21:41] <Kobot> Nephrite rolled 1d20+20 (+11 more if the aura was allowed to be changed) --> [ 1d20=6 ]{26}
> roll 1d20+5 Dana
<Kobot> Kotono rolled 1d20+5 Dana --> [ 1d20=18 ]{23}
> roll 1d20+11
<Kobot> Kotono rolled 1d20+11 --> [ 1d20=9 ]{20}
> roll 1d20-2 monolith 1
<Kobot> Kotono rolled 1d20-2 monolith 1 --> [ 1d20=3 ]{1}
> roll 1d20-2 monolith 2
<Kobot> Kotono rolled 1d20-2 monolith 2 --> [ 1d20=3 ]{1}
Initiative is Crystal (32) > Ithea = Hope (29) > Moore (26) > Dana (23) > Stille (20) > Smrgol (19) > Balyss (13) > Monoliths (1)
Open Crystal and then Ithea/Hope combo.
Dana
HP: 313/313
Effects: Heroes Feast (CL20), Aura (+11 Dex checks, +1 attack rolls)
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves
Resources used: Power Points 129/239, protection devotion used.
Other: -
Stille
HP: 300/300
Resources used: 3/4 Power Points, 1 4th level cleric spell: Moon Bolt. 1 6th level cleric spell: Healx2. 2 8th: All. 1 use of moon gloves used.
Other: -
Crystal doesn't have a better plan while the wall is up, so she waits on faith that it will crumble, and commands Hope to wait and charge forward as soon a gap opens.
"If you can bring down the teleportation blocking spell, I can summon you to me!" Ithea calls out loudly. "Or if I see that the magic weakens, I will cast another disintegrate spell!"
Casting swift invisibility, she holds, stretching her magic sense and hearing to decide which spell to cast. Hopefully the invisibility helps, though she doesn't count on it. The monoliths might have some sort of tremor sense or something.
Is it possible to ready two actions, each with different triggers? "If (A), then (B). If (C), then (D)."?
A readied action can be whatever, though it should be fairly direct and to the point. Ideally, it can be summarized in a sentence.
Above can be summarized as: Crystal/Hope readying to charge if hole opens. Ithea readies to Disintegrate if she sees magic on wall weakening, or Regroup if someone shouts that teleporting works.
Okay.
Ithea vanishes from sight as she comes through, as...
Moore. Ithea's shout didn't make it through, due to thick stone stopping sound from getting through.
"I think our only option is to try and destroy this or weaken it somehow with a concentrated effort." Moore says with a frown. "I don't really have a lot of magic that's going to help with that, but I can at least bolster our fighting capacity to make the rest of it easier." With that, he takes a breath. "If we all focus on one part of it..." Moore reasons as he calls on his powers to inspire courage in everyone!
+12 to attack and damage rolls and +12 against charm and fear. Also +2 from the harp is now active.
Moore
HP: 245/245(59)
AC: 40 (+1)
11/23 bardic music left
Bard: 7/6/7/5/6/6/0/3
FS: 9/9/9/8/8/7/4
"Easy," Dana steps forward, mouth transforming into that of a dragon's, spewing out foul acid all over the stone wall.
Breath of the black dragon, up to 22d6.
> roll 22d6 acid on wall
<Kobot> Kotono rolled 22d6 acid on wall --> [ 22d6=82 ]{82}
It hits the wall right on, sizzling and hissing through the stone. It doesn't get all the way through, but it visibly damages it, parts of it thinner and other parts steaming from the blast.
Stille trots up to the wall and gives it a solid kick, putting his all in it.
> roll 1d20 1 check, max PA here
<Kobot> Kotono rolled 1d20 1 check, max PA here --> [ 1d20=1 ]{1}
He kicks the wall hard, but it doesn't budge an inch.
Smrgol's up.
Dana
HP: 313/313
Resources used: Power Points 107/239, protection devotion used.
Other: -
Stille
HP: 300/300
Other: -
[/quote]
Smrgol moves over to take a huge chunk of the wall out with his impressive maw!
[23:00] <Nephrite> roll 1d20+28 bite (-33 pa)
[23:00] <Kobot> Nephrite rolled 1d20+28 bite (-33 pa) --> [ 1d20=7 ]{35}
I forgot the +3 so that's 38. Doubt it matters at all.
[23:00] <Nephrite> roll 2d10+22+33+3
[23:00] <Kobot> Nephrite rolled 2d10+22+33+3 --> [ 2d10=10 ]{68}
