Chomp!
A hunk of sizzling, acid tinged stone is bitten away, a gouge into the wall now. It's softened but not down, as Dana laughs, "Damn Stille, looks like Ithea's the one bending you over if that's as hard as you can kick."
Balyss.
Balyss casts another Greater Dispel Magic at the wall!
Common Effects:
Heroes' Feast, Moore's +3 to Atk, Inspire Courage +12 (except Smrgol/Ithea)
"Ithea": ShowHide
HP: 281/346
AC/Touch/Flat-Footed: 56/39/56
Effects: GMW (CL 25)
Qualities: DR 10/silver, SR 34, Darkvision, Low-Light Vision, +4 CMD vs Trip/Overrun/Bullrush, Evasion, Uncanny Dodge, Immunity to Frightful Presence, +4 vs Fear, Spellwarped
Inspiration: 0/6
Abilities:
Racial: Healing Touch 1/1
Rogue: Mimic 0/1
Factotum: Inspiration 0/6, Nerveskitter 0/1, Heroics 0/1, Piety 3/9
Duskblade: Attunement 0/14, Quick Cast 3/4
Feats: Chaos Devotion 1/1
Gear: Counterstrike 0/2, Greatreach 0/3, Reciprocate 0/2, Haste 0/10 (rounds), Daylight 0/1, See Invis 0/1, +2d6 electric damage 0/3, Gate 2/3
Spells:
Lv 0 - 0/6
Lv 1 - 0/23
Lv 2 - 2/23
Lv 3 - 2/23
Lv 4 - 5/18
Lv 5 - 8/12 (Note: Lost 2 spells from NL, counted already)
"Balyss": ShowHide
HP: 228/228
AC/Touch/Flat-Footed: 51/39/48
Effects: See above
Qualities: Darkvision, low-light vision, RE(Fire) 20, RE(cold) 15, RE(sonic) 10, RE(acid/electricity) 5, prophet's sight 3/day, Evasion, trap sense+2,  uncanny dodge, DR 10/cold iron and evil, Regen 1/cold iron and evil.
Spells Used:
9 - Gate (x1), Mass Heal, Undeath's Eternal Foe, Quickened Life's Grace, Miracle (x2)
6 - Greater Dispel Magic (x5)
Spells Lost due to NL:
10 - Energy Immunity, Mass Freedom of Movement, Curse of Inadequacy, Moonrise
TU's Used: 1
http://www.soulriders.net/forum/index.php/topic,102879.msg1046029.html#msg1046029
"Crystal/Hope": ShowHide
Crystal
HP: 185/223
AC/Touch/Flat-Footed: 43 / 39 / 31
Effects: See above
Qualities: Low-light vision, DR 10/cold iron, greater invisibility, SR 36, evasion
Used:
3x Smite Evil
1x Righteous Fury
1x Righteous Might
1x Greater Mirror Image
65 HP out of LoH
Spells Lost:
Divine Agility/Inner Beauty
http://www.soulriders.net/forum/index.php/topic,102879.msg1059605.html#msg1059605
Hope
HP: 484/484
AC/Touch/Flat-Footed: 51 / 21 / 41
Effects: See above
Qualities: Improved Evasion, +4 will vs enchantment, DR 15/epic, SR 32, immunity to sleep and paralysis, RE(acid/cold/electricity) 20, darkvision, low-light vision, water breathing, fast healing 3.
http://www.soulriders.net/forum/index.php/topic,102879.msg1059616.html#msg1059616
I assume Ithea's readied action can go off? Checking before I cast disintegrate.
Balyss casts greater dispel magic again, but nothing happens.
Enchantments are still down, the new wall can't be dispelled because it is an instantaneous effect. Go Ithea.
...I'd thought it was blocked by enchantment or I'd have disintegrated on my turn. Hence looking for a change in wall in my ready action. Feel you were unclear or I was and turn got screwy as a result. If I could have disintegrated then, others might have gotten through on their turn and Balyss might not have dispelled because there was a hole. :-/
QuoteThis time there's a flickering in the magic - it's disrupted, not dispelled. The effect is tenacious and will quickly recover from this dispelling.
QuoteIthea readies to Disintegrate if she sees magic on wall weakening
Well yeah, it is disrupted. It didn't say how long 'quickly recover' would be. Also the magic on the wall hasn't weakened - it's still down.
Technical readings of your post aside, since you felt things got off balance there, you're welcome to just disintegrate now. I don't really wanna do a retcon since this format's really poor for it.
Ithea casts disintegrate at the wall, hoping people get through, enough to keep the monoliths distracted from sealing it again.
[17:37] <Merc> roll d20+30+1 ranged touch
[17:37] <Serith> Merc roll for Serith < 36 > [d20=5]
[17:37] <Merc> roll 40d6
[17:37] <Serith> Merc roll for Serith < 137 > [d6=3,5,2,3,2,6,4,6,5,6,1,4,1,2,3,2,4,3,3,6,6,2,3,2,3,6,2,6,3,1,1,1,1,2,6,5,6,2,2,6]
The wall opens right up, revealing the way once more. This time, no wall immediately takes its place. Instead, the two monoliths try and squash Ithea flat beneath their massive feet.
Going to use inspiration here, Ithea? I'm trying to remember to give you a chance to use it, since posting isn't the best venue for easy questions and interrupts.
Yeah I'll use it. Crystal's readied action should trigger and she should zip  to the other side also.
> roll 1d20+48 (+1 defensive stance, +3 ???, +5 ???, -10 PA)
<Serith> Kotono roll for Serith < 66 > [d20=18]
> roll 1d20+53 (+3 ???, +5 ???, -4 awesome blow)
<Serith> Kotono roll for Serith < 59 > [d20=6]
AC is 67, so two misses.
Ithea's a hair too fast, diving to the side as dual boots miss squashing and punting her. Meanwhile Crystal also zips through, making it to the other side safely. The wall's down and still down.
You're up, Ithea. Go.
Initiative is Ithea (29) > Moore (26) > Dana (23) > Stille (20) > Smrgol (19) > Balyss (13) > Crystal = Hope (12) > Monoliths (1)
Ithea attacks both monoliths, switching attacks between the two as she does so, dealing arcane empowered strikes.
Need someone to roll for Ithea.
roll d20+42 K:P for knowledge devotion (I will assume it worked for attacks, subtract 5 from them and damage if it rolls a 1)
Use appropriate if not Planes. Most have modifier +42 anyway.
Based on roll above, are the monoliths just straighr up earth or are they modified by Lixer? I want to channel vampiric touch if it seems safe to do so.
Arcane strike of 5th level spell, and assuming Moore's +3 aura applies but not IC+12,  so attack rolls:
Roll d20+40+5+1+3+5 glaive+KD+feast+moore+AS vs Monolith #1
Roll d20+35+5+1+3+5 glaive+KD+feast+moore+AS vs Monolith #2
Roll d20+30+5+1+3+5 glaive+KD+feast+moore+AS vs Monolith #2
Roll d20+25+5+1+3+5 glaive+KD+feast+moore+AS vs Monolith #1
Damage is:
Roll d10+20+5+5d4
Roll 2d6 holy (if applicable)
Roll 10d6 vampiric touch (if applicable)
In case Neph rolls, VT van only hit each opponent once, so even if I hit a target twice only roll once.
If SR is needed:
Roll d20+25+2+6 CL+items+spell power
[13:46] <Nephrite> roll d20+42 K:P for knowledge devotion
[13:46] <Serith> Nephrite roll for Serith < 52 > [d20=10]
This seems to setup the rest of the attack, so I'll post it first.
[13:55] <Nephrite> Roll d20+40+5+1+3+5 glaive+KD+feast+moore+AS vs Monolith #1
[13:55] <Serith> Nephrite roll for Serith < 59 > [d20=5]
[13:55] <Nephrite> Arghhhh it wasn't supposed to just line that, hold on (This is +12 so 71)
[13:56] <Nephrite> Roll d20+35+5+1+3+5+12 vs Mono 2
[13:56] <Serith> Nephrite roll for Serith < 69 > [d20=8]
[13:56] <Nephrite> Roll d20+30+5+1+3+5+12 glaive+KD+feast+moore+AS+IC vs Monolith #2
[13:56] <Serith> Nephrite roll for Serith < 69 > [d20=13]
[13:56] <Nephrite> Roll d20+25+5+1+3+5+12 glaive+KD+feast+moore+AS+IC vs Monolith #1
[13:56] <Serith> Nephrite roll for Serith < 64 > [d20=13]
[13:57] * ChanServ sets mode: +qo Kotono Kotono
[13:58] <Nephrite> Roll 2#d10+20+5+5d4+2d6 vs Mono 1
[13:58] <Serith> Nephrite roll for Serith < 53, 52 >
[13:58] <Nephrite> roll 10d6 vampiric touch vs Mono 1
[13:58] <Serith> Nephrite roll for Serith < 33 > [d6=3,2,1,6,4,6,1,2,6,2]
[13:58] <Nephrite> Roll 2#d10+20+5+5d4 vs Mono 2
[13:58] <Serith> Nephrite roll for Serith < 47, 41 >
[13:58] <Nephrite> roll 2#2d6 holy seperate in case it doesn't apply
[13:58] <Serith> Nephrite roll for Serith < 7, 4 >
[13:59] <Nephrite> roll 10d6 vampiric touch vs Mono 2
[13:59] <Serith> Nephrite roll for Serith < 37 > [d6=5,3,2,1,4,5,4,4,4,5]
Total damage to Mono 1 is 138
Total Damage to Mono 2 is 136
Ithea turns into a whirl of violence, hacking at both elementals. Spell fire and glaive tear through the ankles of both, dodging retribution stomps and leaping up hack at their upper legs. The massive creatures take this assault well enough, damaged but not stopping in the least.
Moore.
#599
"Go, go go go!" Moore calls, rallying his friends to get moving.
He's rallying them by casting Haste on everyone and then zipping through himself.
Moore
HP: 245/245(59) (Haste)
AC: 40 (+1)
11/23 bardic music left
Bard: 7/6/7/4/6/6/0/3
FS: 9/9/9/8/8/7/4
