Ithea dives down. Going the 23 feet and a bit more reveals no cavern.
Ithea adjusts her travel in the direction of the wet side wall and checks for signs of caverns that way then.
23 feet? Might as well stick to the distance given, and then worry about digging deeper if I can't find anything.
Ithea just keeps exploring until she finds a cavern, then will head back up from there.
She'll basically do some sort of search pattern where she keeps searching until she finds a cavern. If she doesn't after a few minutes, she'll just go up and note that they might be in the wrong place since she's found nothing.
I don't see any movement speed attached to the spell, so I assume it's my normal movement speed of 40ft
> roll 1d100+15
<Kobot> Kotono rolled 1d100+15 --> [ 1d100=59 ]{74}
Ithea dives down for a little bit, searching away. Just as she's about to give up, she feels a sudden, strong tug on her body down. As if everything is heavier, harder to deal with and more overwhelming.
Remembering Silver's warning about gravity, Ithea figures this is the right direction. She heads back up to let the others know, and to see how far from where she'd started she'd gone.
It's approximately 300ft, give or take a bit.
As Ithea emerges, she catches some conversation. "...the world," Balyss says, arms crossed.
Stille smiles and chuckles, "Still, be that as it may, it's important for women of-" He stops when Ithea emerges, "Ah, did you find anything?"
"I hope it's something big and painful," Dana says, "C'mon, it's just like counting fucking cats here."
"I think I've found it," Ithea says after heading back up.
"It's actually much further down than Silver suggested, closer to 300 feet. It'll take too long to go through with the golems, so I'm going to see the exact location of the cavern before returning here, then start bringing people down with dimension door. Not much better options given the distance."
"Alright," Balyss nods, "Good luck."
Go ahead and set up going down, getting into the cavern and all that, then.
"Goodness. I wonder if they warded it somehow against intrusion, then..." Moore says. "I can help out if you can't bring everyone with your magic."
If Ithea's Dimension Door can't bring everyone I can cast one as well to bring the golems.
Ithea travels down towards the source of heavy gravity, and once she starts feeling the sensation of it again, slows down her movement, edging forward just enough that she can hopefully peek out of the cavern wall and get a look into it while having the rock around her to keep her from just falling down. Hopefully that way she'll have time to get a clear view of any possible enemies in the area, as well as a good destination to teleport the group towards once she heads back up.
