On the prowl (Ithea)
Started by Anastasia, April 20, 2016, 11:16:08 PM
"If I had a connection to those, what would have happened? Particularly chaos, given my anarch abilities?" Ithea asks curiously. "Are there other connections as well?"
Sharess wiggles her nose, and suddenly your gear is back on and in place. Not that it disturbs her in the slightest. "You'd feel them more. Words don't properly explain it," she admits, "Human common is ill equipped to explain transcendent experiences." Another wiggle of her nose and you're back on the streets of Rapture, everyone still ignoring the two of you.
"Well, I -am- versed in a multitude of languages, if it helps," Ithea replies almost cheekily.
Sharess's tail flicks up, as she walks off Ithea's shoulder, ignoring gravity completely. "The second and largest benefit is that death is not the end for you, not now. You will reform in this realm, albeit shorn of everything you possessed when slain. But whatever you do, you must not die in this realm, or there will be no second chances for you."
Ithea nods more seriously. "Understood."
"Now then," You walk along, at one of the bridges that leads out of Rapture, "Go on and keep doing what I approve of, Ithea."
Ithea nods again.
Before she leaves though, she asks, "You mentioned something about Jaela and Angharradh, through Snowy?"
On a glance, you see Snowy isn't there anymore. Must not have been teleported or moved when Sharess moved you.
No response to the question from Sharess?
The cat before you laughs richly. "Oh yes, there are plant there, but it's not my place to spoil them. Speak to Jaela about them."
Sorry, misread your post.
Ithea nods. "I will."
With that, she starts making her way out and back to Aurora.
So noted. What's next on your agenda, kitty?
Might as well detour and find out what Jaela is up to and if Ithea can help since she's gotten curious. She'll want to describe that one elf dude to Tannin and ask him to look into him, but dunno if that needs to be done IC.
Jaela's off in Balmuria and will likely be there awhile, plus Cor's off in China. It would be best if you get something else done right now instead.
I shall gather fleshy ones and outsidery ones to join me in an epic quest of Earth hunting! Also, I need a diviner to find that prey. Who's available? I know Moore does that stuff, not sure who else.
