Yet more hoarding (Surraruthru)
Started by Anastasia, April 29, 2016, 12:36:28 AM
#285
Surraruthru winces.
"Ebony, are you okay? I don't remember getting hit with that... Here, let me, um, help."
Surraruthru starts casting Limited Wish, using it to emulate Silence!
Casting Limited Wish, CL 24 for Silence on the room.
Silence falls on the room. Ebony nods and goes forward, taking the chest. She's able to pull it with a silent grunt, removing the chest as she's peppered with rays over and over. Surely over a hundred by the time it's out.
"There, that's the first -" Ebony gets out, before suddenly the light of the glass orbs intensifies. Blindingly bright white beams of light fly, arching around in zig-zags before going out the door, one at each of you.
> roll 1d20+22 touch AC Surraruthru
<Serith> Kobrb roll for Serith < 38 > [d20=16]
> roll 1d20+22 touch AC Kascha
<Serith> Kobrb roll for Serith < 25 > [d20=3]
> roll 1d20+22 touch AC Ebony
<Serith> Kobrb roll for Serith < 26 > [d20=4]
Two htis, only Kascha dodged. Str checks, Ebony and Surraruthru.
> roll 1d20+4 Str Check >.>;
<Serith> Iddy roll for Serith < 19 > [d20=15]
Surraruthru
HP: 271/285
Spells Active: Mind Blank (CL 24), Cloak of the Sea (CL 24), Transformation of the Deeps (CL 24), Energy Absorption (CL 27), Mage Armor, Greater (CL 24)
Initiative: +12
Speed: 60 ft, 100 ft fly (perfect), 30ft Swim
AC: 32+6MAG
SR: 33
Fort: 29
Ref: 31
Will: 31
Resistances: 10/acid, cold, electricity, fire, sonic
> roll 1d20+4 Ebony
<Serith> Kobrb roll for Serith < 8 > [d20=4]
Kascha eeps and dives to the side, the beam missing her. But Ebony and Surraruthru aren't nearly as quick on their feet, hit dead on. They're pulled into the room in a split second, the iron door slamming shut behind them and cutting Kascha off from the two of you. You land on the far side of the room, 30ft from the door and prone. As you do, the orbs begin to silently emit gas, pumping it rapidly into the room.
Fort save vs poison. If I recall, you have diamond body so you're immune to poison, Surraruthru?
Yes, sir I do.
"Ebony! Poison! Can you protect yourself or do I need to use Wish?"
Surraruthru
HP: 271/285
Initiative: +12
AC: 32+6MAG
SR: 33
Fort: 29
Ref: 31
Will: 31
> roll 1d20+32 Ebony (+4 racial vs poison)
<Serith> Kobrb roll for Serith < 33 > [d20=1]
Well, that's unfortunate timing for a natural 1.
Unfortunately, Surraruthru's silence spell stops his words. Ebony gets one whiff of the gas and collapses, out cold. Meanwhile...
> roll 1d100
<Serith> Kobrb roll for Serith < 90 > [d100=90]
Kascha automatically passes the Spellcraft check because her mod is high enough to prevent failure.
> roll 30d10 fire damage on door
<Serith> Kobrb roll for Serith < 206 > [d10=5,8,5,8,2,9,10,9,4,10,8,3,3,3,10,4,7,8,5,6,8,4,8,10,7,3,10,9,10,10]
Beams savage Ebony. They fire three times as fast, dozens of them slamming into her. Only her protections and the silence prevent her from being utterly obliterated. It's then that a massive burst of fire rips through the door like it wasn't there, molten iron splattering into the gassy room. Kascha is surrounded by a halo of flames, fading as the door and some of the wall around it is melted.
Kascha shouts something blocked by your silence while the gas leaks from the room. However, one of Kascha's ioun stones, a clear cube, whirls around her head, dispelling any gas that gets close. Frowning, she gestures at Ebony and waves you forward, back towards her.
Kascha
HP: 258/258
Spells Active: Mind Blank (CL23), Superior Resistance (CL23), Cloak of the Sea (CL24), Transformation of the Deep (CL24), Energy Absorption (CL24), Greater Mage Armor(CL24)
Bonuses: Water breathing, freedom of movement, blur (20% miss chance), immunity to non lethal damage, immunity to damage from water temperature and pressure, resistance to all energy types 10 (doesn't stack) and can expend it as an immediate action to stop one elemental attack and heal half that damage.
Negative Conditions: 50% spell failure for 1 hour.
Ebony
HP: 217/247
Spells Active: Mind Blank (CL23), Superior Resistance (CL23), Cloak of the Sea (CL24), Transformation of the Deep (CL24), Energy Absorption (CL24), Greater Mage Armor(CL24), Energy Immunity (CL23)x2
Bonuses: Water breathing, freedom of movement, blur (20% miss chance), immunity to non lethal damage, immunity to damage from water temperature and pressure, resistance to all energy types 10 (doesn't stack) and can expend it as an immediate action to stop one elemental attack and heal half that damage, immunity to fire and electricity.
Spell-like abilities
At will-aid, charm monster, color spray, comprehend languages, continual flame, dancing lights, detect evil, detect thoughts, disguise self, dispel magic, hold monster, greater invisibility(self only), major image, see invisibility, greater teleport (self plus 50 pounds of objects only); 1/day-chain lightning, prismatic spray, wall of force. Caster level 22nd. The save DCs are 17 + spell level.
Kascha casts as a 21st level wizard. (Caster level 24th for spells with the fire descriptor; caster level 23rd for other spells. +6 caster level bonus to overcome spell resistance.) The save DCs are 20 + spell level. Her spell themes are spells learned from Seira, fire magic and minor buffing. Her metamagic options are Empower Spell (+2), Maximize Spell (+3), Twin Spell (+4) and Quicken Spell (+4). She may apply the following metamagics to the following spells once per day without adjusting their casting time or spell level: Magic Missile, empower; Inner Beauty, quicken; Summon Greater Elemental, quicken.
[7/day]2: False Life, Glitterdustx2, Knockx3, Scorching Ray.
[6/day]6: Empowered Enervationx2, Summon Greater ElementalSC, SR, Superior ResistanceSC, Surge of Hopex2Home.
[5/day]8: Dimensional Lock, Maximized Greater Fireburst, Quickened Empowered Scorching Ray, Mind Blankx2 (1/2 left).
[5/day]9: Empowered Maximized Enervation, Mass Heal, Twinned Greater Fireburst, Empowered Righteous Smite, Wish
[3/day]10: Celestial ValorHome, Energy Immunityx2Home
Ebony casts as an 22nd level bard. (Caster level 26th vs dispel) The save DCs are 20 + spell level. Her metamagic options are Consecrate Spell (+1) and Purify Spell (+1). Ebony may use Consecrate Spell and Purify Spell spontaneously without increasing the casting time of the spell.
[5/day]3: Charm Monster, Cure Serious Wounds, Fear, Gaseous Form, Major Image.
[5/day]4: Cure Critical Wounds, Greater Invisibility, Hold Monster, Modify Memory, Sirine's GraceSC
[6/day]6: Mass Charm Monster, Mass Cure Moderate Wounds, SnowsongFrost, Veil.
[1/day]7: Heal, True Seeing.
Ebony casts as a 21st level sorcerer. (Caster level 25th vs dispel) The save DCs are 20 + spell level. Her metamagic options are Consecrate Spell (+1) and Purify Spell (+1). Ebony may use Consecrate Spell and Purify Spell spontaneously without increasing the casting time of the spell.
[7/day]7: Greater Teleport, Holy Word, Righteous SmiteBoED.
[7/day]8: Greater Planar Ally, Polar Ray, Lightning RingSC.
[4/day]9: Blinding GloryBoED, Reaving DispelSC, Time Stop.
[4/day]10: Unseen NeedleHome
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
Surraruthru nods and tries to drag Ebony over to Kascha and out of the room!
Surraruthru
HP: 271/285
Initiative: +12
AC: 32+6MAG
SR: 33
Fort: 29
Ref: 31
Will: 31
As you approach, one obvious problem - the beams are hitting her all over. While she may not burn, dissolve, freeze or shock, you do. Getting that close likely subjects you to being hit by some of them.
Meanwhile Kascha drags the chest of pearls away from this entire death trap.
Surraruthru decides that taking one or two beams is entirely acceptable and tries to roll Ebony over on top of himself so he can carry her out... While using her as a shield. He should feel bad, but it's the only way with the silence.
> roll 1d12-1
<Serith> Kobrb roll for Serith < 2 > [d12=3]
2 beams hit you. Ebony gives 50% miss chance from the cover she provides.
> roll 1d100
<Serith> Kobrb roll for Serith < 96 > [d100=96]
> roll 1d100
<Serith> Kobrb roll for Serith < 16 > [d100=16]
One gets through, a cold beam.
> roll 1d20+12
<Serith> Kobrb roll for Serith < 17 > [d20=5]
> roll 10d6-10 cold damage
<Serith> Kobrb roll for Serith < 25 > [d6=6,1,5,6,2,3,5,2,4,1]
25 cold damage to Surraruthru.
Grabbing Ebony and hustling, Surraruthru is fortunate. Only a few beams come close, most hitting Ebony or missing. One gets him on the tail, a freezing blast that numbs it solid. But he flees out, the blasts stopping once you're out of the room. Sound returns, the scraping of Kascha dragging the chest away followed by her voice, "Hurry, let's get well away from that cursed room!"
Surraruthru continues after Kascha, carrying Ebony.
"We should check her for the poison. She passed out instantly."
Surraruthru
HP: 246/285
Initiative: +12
AC: 32+6MAG
SR: 33
Fort: 29
Ref: 31
Will: 31
Kascha nods, one of her ioun stones coming to the fore. A white sphere that glows with light, injuries wiped away from all of you.
Mass heal, 200 HP healed and most conditions negated, including poisoning. Affects all three of you.
Ebony stirs, eyes opening right away. She sits up in a hurry, looking around. After a moment she says, "I was knocked unawares? What transpired?"
Kascha
HP: 258/258
Resources Used: Mass heal ioun stone used.
Ebony
HP: 247/247
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
#297
"Poison. You went down instantly, and the whole room went crazy. We're going to have to come back with better preparation for the other eight chests, unless the two of you think we can get it done now."
Other 8 chests, Surraruthru. It's a 3 by 3 square of them.
Listen checks, all of you.
> roll 1d20+31 Listen
<Serith> Iddy roll for Serith < 46 > [d20=15]
Edited previous post for correct number.
