Afina vs the lich (Afina)
Afina tries to stand her ground, but it's too much. She's sent hurling down, a painful collision with the earth incoming.
Any way to stop or mitigate the impact?
Just tumble!
[19:38] <@Ebiris> roll 1d20+47 tumble
[19:38] <Rei-chan> Ebiris rolled : 1d20+47 tumble --> [ 1d20=12 ]{59}
DC 45 to treat a fall as 30 feet shorter when determining damage (just 1 point off treating it as 40 feet shorter!)
> roll 20d6 still lots of falling over 200ft, so ow
<Rei-chan> Kowork rolled : 20d6 still lots of falling over 200ft, so ow --> [ 20d6=77 ]{77}
Pain. You land on the ground flat, hearing thuds nearby you. There's a terrible rumbling as you recover, the earth shaking and something huge moving.
Using Spell Shield to sac an 8th level slot for -40 damage
Idiot, pixies don't stand their ground! She let the ease of their assault thus far get to her head. Springing to her feet, Afina takes in her new location at a glance, marking targets to deal with.
Afina: 247/277, heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), greater mage armour (CL 23), moment of prescience (CL 23), see invisibility (CL 23), haste (CL 23)
AC 87, spell resistance 38, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance
Spell charges: 5/9/9/6/9/8/9/7/5/7
Smrgol: 459/459
AC 50, immunity to magic, fast healing 10
As Afina berates herself, she sees Dana's nearby. She's also getting up from the impact, as is Mei and Smrgol. Ahead, the entire castle is slowly moving, shifting. A head of stone is beginning to rise from the top, as all of it begins to form a body.
Did he make a golem out of a castle? Afina thinks he did. If not, at least it resembles one as its forming. Making such a huge golem isn't impossible, but one that shape shifts between forms is tougher. Not impossible - Afina thinks she could do it with enough stone, time and money. Plus research.
Smrgol takes 77 points of falling damage, as do Mei and Dana.
Mei
HP: 178/295
Spells Active: Mind Blank (CL17), Fortunate Fate (CL15), Planar Tolerance(CL7), Greater Mage Armor(CL5), Haste(CL23)
Bonuses: +1 attack rolls, +1 attacks, haste movement speed, +1 ref.
Dana
HP: 221/313
Resources Used: 228/239 power points
But really why would you want to? It just makes more moving parts, more points of wear and tear, and more vulnerabilities. She's quite confident that Smrgol represents a pinnacle of golem-kind and could make short work of this much larger construct in decent time but treating this like a game is what just got her knocked down that big drop anyway. Moving away from the others so they can't all be hit in one grand strike she flings an orb of fire up at the golem's chest to test its defences.
[17:15] <@Ebiris> roll 1d20+47 ranged touch
[17:15] <Rei-chan> Ebiris rolled : 1d20+47 ranged touch --> [ 1d20=7 ]{54}
[17:16] <@Ebiris> roll 22d6 fire, ignores resistance, 50% vs immune, no sr
[17:16] <Rei-chan> Ebiris rolled : 22d6 fire, ignores resistance, 50% vs immune, no sr --> [ 22d6=85 ]{85}
Spell charges: 5/9/9/6/8/8/9/7/5/7
Smrgol: 397/459
No good - the orb stops when it touches the golem. Dana picks herself up and grins, "Now it's getting fuckin' interesting!"
Mei silently rises, firing off a blast that has as much impact as your own attack.
That just leaves Smrgol who takes a massive bite out of the slowly forming golem's leg!
[21:02] <@Ebiris> roll 1d20+50 -11pa
[21:02] <Rei-chan> Ebiris rolled : 1d20+50 -11pa --> [ 1d20=7 ]{57}
[21:02] <@Ebiris> roll 2d10+44
[21:02] <Rei-chan> Ebiris rolled : 2d10+44 --> [ 2d10=11 ]{55}
Smrgol: 407/459
Smrgol charges the larger golem, taking a chomp out of its leg. He tears stone and - clockwork? You see gears within the stone, as if parts of it are hollow. The creature stumbles from the bite but begins to rise, forming a crude golem. It's rough but in the shape of a man, staying where it is. Its left leg has a chunk gone, the grinding of gears heard within. Sparks come from it, little rivulets of blue spell-fire spilling out.
Init here.
[17:28] <@Ebiris> roll 1d20+29 Afina init
[17:28] <Rei-chan> Ebiris rolled : 1d20+29 Afina init --> [ 1d20=7 ]{36}
[17:28] <@Ebiris> roll 1d20+3 Smrgol init
[17:28] <Rei-chan> Ebiris rolled : 1d20+3 Smrgol init --> [ 1d20=2 ]{5}
> roll 1d20+11 Mei
<Rei-chan> Kotono rolled : 1d20+11 Mei --> [ 1d20=11 ]{22}
> roll 1d20+5 Dana
<Rei-chan> Kotono rolled : 1d20+5 Dana --> [ 1d20=2 ]{7}
> roll 1d20-2 castle golem
<Rei-chan> Kotono rolled : 1d20-2 castle golem --> [ 1d20=19 ]{17}
Init is Afina (36) > Mei (22) > Castle Golem (17) > Dana (7) > Smrgol (5)
Afina opens.
"Dana, Smrgol, this is mostly yours," Afina says, though she'll try and do what damage she can by running up its already damaged leg and spearing Afame into some of the clockwork gears before bounding off and away!
[18:12] <@Ebiris> roll 1d20+49
[18:12] <@Ebiris> roll 1d20+44
[18:12] <Rei-chan> Ebiris rolled : 1d20+49 --> [ 1d20=12 ]{61}
[18:12] <Rei-chan> Ebiris rolled : 1d20+44 --> [ 1d20=2 ]{46}
[18:13] <@Ebiris> roll 1d4+21+2d6
[18:13] <Rei-chan> Ebiris rolled : 1d4+21+2d6 --> [ 1d4=1 2d6=6 ]{28}
[18:13] <Rei-chan> Ebiris rolled : 1d4+21+2d6 --> [ 1d4=3 2d6=9 ]{33}
Smrgol: 407/459
What does Afame count as to bypass damage reduction?
It's an adamantine/linthrum alloy so I guess adamantine?
Thanks.
Afina strikes true, digging into the gears of the leg and sending a handful down to the ground. Mei meanwhile defends herself, falling back.
She's protecting herself since there's not a lot she can do here. Normally she'd eladrin form here, but no flying hurts that a lot. She'll be reactive in case someone needs healing next round. Golem's up.
The golem lurches forward and slams a fist down at Afina.
> roll 1d20+33 needs a 20 since steam pixie
<Rei-chan> Kotono rolled : 1d20+33 needs a 20 since steam pixie --> [ 1d20=19 ]{52}
But Afina's already well gone by the time the fist lands, flying to the side and back around.
Dana, but she'll hold and let Smrgol go first. Go.
Mei
HP: 178/295
Dana
HP: 221/313
[/quote]
