The past burns (Afina, Tryll)
Started by Anastasia, August 05, 2016, 12:14:48 PM
Init is Afina (44) > Willah (37) > Master (26) > Tryll (10) > Calleigh (9)
Open Afina. 9 things to dispel on her, go for it.
[22:13] <@Ebiris> roll 9#1d20+24
[22:13] <Kobot> Ebiris rolled 9#1d20+24 --> [ 1d20=20 ]{44}, [ 1d20=11 ]{35}, [ 1d20=2 ]{26}, [ 1d20=18 ]{42}, [ 1d20=7 ]{31}, [ 1d20=4 ]{28}, [ 1d20=10 ]{34}, [ 1d20=2 ]{26}, [ 1d20=1 ]{25}
Also using Afame as swift for +4 dodge
Afina: 287+20/287, heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 24), moment of prescience (CL 24), greater heroism (CL 24), interplanar telepathic bond (CL 23), planar bubble (CL 24), haste (CL 24), shield (CL 24), fires of purity (CL 24)
AC 103, spell resistance 39, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance, freedom of movement
Spell charges: 6/9/8/10/9/8/3/6/6/5/7/4
Magic collapses around Willah. She grimaces as she appears less beautiful now, far less captivating. "All my loyal slaves," she says, "Dead! My castle..." The ground beneath her sinks several inches, the entire castle groaning and starting to fall. "Ruined! Your souls will burn in the Lake of Fire for all eternity!"
But nothing happens, your magic protecting you from it.
Willah grimaces more, pointing up at Afina. From the poisoned skies a bolt of green lighting falls down at her.
> roll 1d20+24
<Kobot> Kotono rolled 1d20+24 --> [ 1d20=11 ]{35}
Does not beat your SR.
But nothing happens to that, either.
Master'll hold for Tryll and Calleigh, since he's planning on knocking her out non-lethally as the finisher. Go you two.
Manifesting Twinned Ataxia
<Kobot> DarthSquiddius rolled 1d20+25+3 --> [ 1d20=3 ]{31}
<Kobot> DarthSquiddius rolled 1d20+25+3 --> [ 1d20=12 ]{40}
Fort DC 30 halves damage of:
<Kobot> DarthSquiddius rolled 1d4 dex damage --> [ 1d4=4 ]{4}
In addition, if saves are failed:
<Kobot> DarthSquiddius rolled 1d100 --> [ 1d100=48 ]{48} Deafness
<Kobot> DarthSquiddius rolled 1d100 --> [ 1d100=82 ]{82} Stunned
Tryll
HP: 237
AC: 45
Touch AC: 28
Flatfooted AC: 39
Active Effects: Inertial Armor (Extended, CL 25), Mind Blank (CL 15), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Magic Circle Against Evil (CL 24), True Seeing (CL 25), Detect Psionics (CL 25)
PP: 566
Calleigh
HP: 118
AC: 47
Touch AC: 25
Flatfooted AC: 36
Active Effects: Inertial Armor (Extended, CL 25), Mind Blank (CL 15), Fortunate Fate (CL 13), Planar Tolerance (CL 7), True Seeing (CL 25), Detect Psionics (CL 25)
Psicrystal
HP: 118
AC: 31
Touch AC: 14
Flatfooted AC: 29
First one fails SR check, second one goes through.
> roll 1d20+23 vs the second, 1st didn't beat SR
<Kobot> Kotono rolled 1d20+23 vs the second, 1st didn't beat SR --> [ 1d20=5 ]{28}
Willah cries out helplessly as she's knocked to her knees, reeling and stunned.
Calleigh, anything? How long is she stunned?
It's not clearly defined in the spell text. Since you gave the power your stamp of approval and never specified, I suppose she's stunned forever.
In addition, if the Fortitude save is failed, they suffer a physical malady for 1d4+1 rounds. Roll 1d100 to determine effects.
From the text. Roll the 1d4+1.
<Kobot> DarthSquiddius rolled 1d4+1 --> [ 1d4=1 ]{2}
Whoops.
Calleigh aims a long, slim crystal at the insensate devil-nymph thing! A blob of unpleasant sticky mess flies out and slings itself at Willah-maybe!
<Kobot> DarthSquiddius rolled 1d20+24 ranged touch Calleigh --> [ 1d20=4 ]{28}
Ectoplasm covers her further, leaving her even weaker.
The castle shakes as The Master falls after her, feet first at her exposed, vulnerable head.
> roll 1d20+26 (nonlethal, +2 charge, +5 mind over hand, -20 PA)
<Kobot> Kotono rolled 1d20+26 (nonlethal, +2 charge, +5 mind over hand, -20 PA) --> [ 1d20=17 ]{43}
> roll 4d8+34
<Kobot> Kotono rolled 4d8+34 --> [ 4d8=14 ]{48}
The blow snaps her head back as she's knocked flat on her back, groaning but still moving.
Afina, go.
The Master
HP: 304/304
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Interplanar Telepathic Bond (CL23)
Bonuses: -
Negative Conditions: -
Resources Used: 1 use of mind over hand
[/quote]
Maybe she should tone down the winds a little? Nah.
Flying down after the Master, Afina smacks the flat of Afame against Willah's cheeks, knocking them back and forth. "Tryll, Calleigh, have a look around for Lief's body! It should be nearby!" she calls up to the incorporeal duo, the treacherous Lifasan well in hand right now.
[22:53] <@Ebiris> roll 1d20+57
[22:53] <Kobot> Ebiris rolled 1d20+57 --> [ 1d20=1 ]{58}
[22:53] <@Ebiris> roll 1d20+52 5th level arcane strike
[22:53] <Kobot> Ebiris rolled 1d20+52 5th level arcane strike --> [ 1d20=4 ]{56}
-4 on those for nonlethal
[22:54] <@Ebiris> roll 1d20+28 fires of purity SR
[22:54] <Kobot> Ebiris rolled 1d20+28 fires of purity SR --> [ 1d20=3 ]{31}
[22:55] <@Ebiris> roll 1d4+24+2d6+2d6+2d6+5d6+2d6+1d6+5d4
[22:55] <Kobot> Ebiris rolled 1d4+24+2d6+2d6+2d6+5d6+2d6+1d6+5d4 --> [ 1d4=2 2d6=7 2d6=12 2d6=6 5d6=19 2d6=11 1d6=2 5d4=15 ]{98}
Hits as good/chaotic/epic/silver
The blow is enough as the castle groans again. Willah goes limp as you look around the room. A rich room of luxury, now burnt and ruined. There's two doors leading from it, one collapsed inward and the other knocked ajar.
"Come." A voice Afina knows speaks that from the door. A voice full of power, dark and terrible. Gathgorian invites you deeper within.
Free act.
True Seeing is active!
'If you are concerned that she will recover, I can decerebrate her if you like.'
