[14:48] <Nephrite> roll 1d20+34 spot Surru
[14:48] <Rei-chan> Nephrite rolled : 1d20+34 spot Surru --> [ 1d20=8 ]{42}
As a note it's listed as 31 on the sheet, so that should be 39 unless there's a booster I'm unaware of.
Iddy, the difference may matter here, so please clarify.
It's whatever is on the sheet. At work and can't really check. I said +34 because most of my skills are, so I said I think.
> roll 1d20+34 Kascha
<Serith> Sunshine_Ko roll for Serith < 43 > [d20=9]
> roll 1d20+21 Sylvie
<Serith> Sunshine_Ko roll for Serith < 40 > [d20=19]
> OOC: +5 to that for a total of 45.
> roll 1d20+32 Ebony
<Serith> Sunshine_Ko roll for Serith < 52 > [d20=20]
You begin to go about. No sign of the rust dragon that any of you see, thankfully. Is it gone? You aren't sure, but after about 20 more minutes of travel through the wastes of Hades, "It's not here,' Kascha murmurs, "Or it's hidden so well we can't detect it."
Surraruthru goes down in altitude to better speak with the others.
"We'll just have to operate on the assumption it's going to ambush us when we're weakest. If it's a dragon that's craven enough to flee, then it's craven enough to let something else defeat us for it. Further proven by it's use of the Monolith. In any case, I've used some precious spells. Should we look for a place to rest before continuing or push ahead?"
"I've been conserving to save energy," Ebony admits, "I can go on."
"As can I," Sylvie says, "I don't fancy resting in Hades, this place erodes your soul like acid."
Kascha hums and pulls out her book, flipping through it. "Yes, Hades is a miserable place. But if you need to rest, we'll go extradimensional, of course. A mage's mansion should be suitable."
"We can continue, but I've used some powerful spells. I've still got most of my empowering spells, but I'm down a Wall of Force and Time Stop. I'm also a bit hurt. For now, we can continue, but if we come against more fights, then I'll need some rest."
Surraruthru
HP: 225/296+0/12
AC: 32+6
Init: +12, Touch Atk: 29
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Moment of  Prescience
"Allow me," Ebony comes forward, "I will heal you, if you wish."
Surraruthru nods and lands on Ebony's shoulders, curling around her.
> roll 3d8+15
> roll 3d8+15
<Serith> Sunshine_Ko roll for Serith < 22 > [d8=2,1,4]
<Serith> Sunshine_Ko roll for Serith < 20 > [d8=1,1,3]
Two cure serious wounds. What's that put your HP at?
Kascha
HP: 271+11/271
Spells Active: Mind Blank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Superior Resistance (CL25)
Bonuses: +1 morale attack/will saves, immunity to poison and disease
Resources Used: Greater elemental summon quickening
Sylvie
HP: 305+17/305
Spells Active: Mind Blank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Greater Mighty Wallop (CL23), Endure Elements (CL23), Overland Flight (CL23)
Bonuses: +1 morale attack/will saves, immunity to poison and disease, damage reduction 10/adamantine
Ebony
HP: 256+16/256
Resources Used: 1 dispel evil
Spell-like abilities
At will-aid, charm monster, color spray, comprehend languages, continual flame, dancing lights, detect evil, detect thoughts, disguise self, dispel magic, hold monster, greater invisibility(self only), major image, see invisibility, greater teleport (self plus 50 pounds of objects only); 1/day-chain lightning, prismatic spray, wall of force. Caster level 23rd. The save DCs are 17 + spell level.
Kascha casts as a 23rd level wizard. (Caster level 26th for spells with the fire descriptor; caster level 25rd for other spells. +6 caster level bonus to overcome spell resistance.) The save DCs are 20 + spell level. Her spell themes are spells learned from Seira, fire magic and minor buffing. Her metamagic options are Empower Spell (+2), Maximize Spell (+3), Twin Spell (+4) and Quicken Spell (+4). She may apply the following metamagics to the following spells once per day without adjusting their casting time or spell level: Magic Missile, empower; Inner Beauty, quicken; Summon Greater Elemental, quicken.
[6/day]6: Empowered Enervationx2, Surge of Hopex2Home.
[4/day]8: Dimensional Lock, Maximized Greater Fireburst, Quickened Empowered Scorching Ray, Mind Blank.
[4/day]9: Mass Heal, Twinned Greater Fireburst, Empowered Righteous Smite, Wish
[4/day]10: Celestial ValorHome, Energy ImmunityHome, Quickened Greater Dispel Magic, Seira's Unicorn ApocalypseHome
Sylvie casts as a 13th level chameleon (Caster level 23rd.) Her save DCs are 24 + spell level (arcane) or 15 + spell level (divine). Her spell selection themes are personal power and planar survival.
Arcane casting
[4/day]0: Detect Magicx2, Prestidigitationx2
[8/day]1: Improvisationx3SC, Magic Missilex2, Shieldx2
[8/day]2: Body of the SunSC, Detect Thoughts, Electric LoopSCx2, Resist Energyx2, See Invisibilityx2
[7/day]3: Amorphous FormSC,, Displacement, Greater Mighty WallopRD, Heroism, Sylvie's Speedy AppraisalHome, Vampiric Touch
[7/day]4: Assay Spell ResistanceSC, Attune Formx2SC, Dimensional Anchor, Dimension Door, Enervationx2
[7/day]5: IndomitabilitySC, Overland Flight, Teleportx2, Wall of Forcex2.
[7/day]6: Bite of the Weretigerx3SC, Disintegrate, Greater Heroismx2.
[3/day]7: Greater Teleport, Limited Wish, Waves of Exhaustion.
RD - Races of the Dragon.
SC - Spell Compendium.
Divine casting
[4/day]0: Create Waterx3, Cure Minor Wounds.
[5/day]1: ConvictionSC, Divine Favorx2, Foundation of StoneSC, Goodberry
[5/day]2: Aid, Lore of the Godsx3CC, Spiritual Weapon
[5/day]3: BlindsightSC, Cure Serious Woundsx3
[5/day]4: Death Wardx2, Divination, Divine Power, Freedom of Movement.
[4/day]5: Plane Shift, Righteous Mightx2, Spell Resistance, Zone of RevelationSC
[4/day]6: Healx4.
[1/day]7: Aura of VitalitySC
CC - Complete Champion
Arcane Dilettante casting. 9 spells with a maximum of level 8. Save DCs are 22 + spell level.
Bite of the Werebear, Cone of Cold, Enervation, Greater Mirror Image, Greater Invisibility, Greater Mighty Wallop, Greater Heroism, Polar Ray, Shield.
Ebony casts as an 23rd level bard. (Caster level 27th vs dispel) The save DCs are 20 + spell level. Her metamagic options are Consecrate Spell (+1) and Purify Spell (+1). Ebony may use Consecrate Spell and Purify Spell spontaneously without increasing the casting time of the spell.
[4/day]3: Charm Monster, Cure Serious Wounds, Fear, Gaseous Form, Major Image.
[6/day]4: Cure Critical Wounds, Greater Invisibility, Hold Monster, Modify Memory, Sirine's GraceSC
[4/day]7: Heal, Rain of EmbersBoED(1d2 str drain), True Seeing, Vision.
Frost - Frostburn.
Ebony casts as a 22nd level sorcerer. (Caster level 26th vs dispel) The save DCs are 20 + spell level. Her metamagic options are Consecrate Spell (+1) and Purify Spell (+1). Ebony may use Consecrate Spell and Purify Spell spontaneously without increasing the casting time of the spell.
[6/day]7: Greater Teleport, Holy Word, Righteous SmiteBoED.
[5/day]8: Greater Planar Ally, Polar Ray, Lightning RingSC.
[4/day]10: Planet DefenderHome, Unseen NeedleHome
[/quote]
267/296. And 0/12 temp HP from the feast.
One more then.
> roll 3d8+15
<Serith> Sunshine_Ko roll for Serith < 24 > [d8=5,1,3]
Temp HP's gone once it's expended, doesn't refill and isn't healable.
"More?" Ebony asks after the third spell.
Kascha
HP: 271+11/271
Sylvie
HP: 305+17/305
Ebony
HP: 256+16/256
Arcane casting
Divine casting
[4/day]6: Healx4.
[3/day]3: Charm Monster, Cure Serious Wounds, Fear, Gaseous Form, Major Image.
Frost - Frostburn.
[/quote]
[/quote]
"No, I feel much better, thank you."
Surraruthru
HP: 291/296
AC: 32+6
"Healing is a wonderful gift," Ebony says, adjusting her hood. "If I had it to do again, perhaps I would have studied the arts of a cleric and devoted myself to healing. What is sweeter than seeing the misery of pain be wiped away?"
"Victory. Strength enough to intimidate all enough that harm is prevented in the first place. Mounds and mounds and mounds of treasure. Vast, sprawling, verdant swaths of territory housing many groves. Friends."
Surraruthru settles in for the rest of the ride, trying to rest as much as he can since it was interrupted before.
Surraruthru
HP: 291/296
AC: 32+6
