> roll 1d20+31 spot
<Serith> Iddy roll for Serith < 32 > [d20=1]
You don't see anything unusual. Well, beyond what you've already seen, anyway. The whole brain thing clocks in firmly in the unusual category.
Surraruthru cautiously flies towards the door, watching for incoming traps.
You reach the door. No sign of traps or anything happening.
Surraruthru opens the door and goes through.
The door's jammed or locked, it doesn't open to a casual attempt.
Surraruthru turns back to the brains and inspects them, suspecting there's some trick to them and to this room.
They're big brains. Rather brainy, all told. You can see the wrinkles and folds of the gray matter up close.
Spot check.
> roll 1d20+31 Spot Serith
<Serith> Iddy roll for Serith < 44 > [d20=13]
You can see tiny green veins criss-crossing the grey matter. The liquid from below seems to be pulled from them.
Surraruthru tries to figure out a way to disconnect the brains.
You could remove the needles on the bottom if you wished to stop the collection of fluid, or you could unchain them from above. You'd need to break the chains in that case.
Surraruthru moves to remove the needles, waiting to see what happens after before worrying about the chains.
You pull the long needles out. On removing the first, a loud shriek comes from the brain itself, pounding in your mind. You can't get it out of your mind. Other shrieks join it, your mind going blank from the sound.
Init.
> roll 1d20+12 init
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 25 > [d20=13]
