Muirfinn's legacy (Moore)
Started by Anastasia, September 23, 2016, 02:19:12 PM
No specific plans so he's more or less going to wing it and see how things end up. If it only gets half done then he can get some help to complete it.
[16:44] <Nephrite> roll 1d20+7 Con check
[16:44] <Rei-chan> Nephrite rolled : 1d20+7 Con check --> [ 1d20=18 ]{25}
It takes several hours of playing, but you do it. It assembles before you as your hand cramps and you struggle, but you keep on at it. You have a crowd watching as...
Feel free to describe.
A glorious, yet humble building, large enough to fit many but small enough to not take up the entire area. The outside is covered in bright gold and silver lining, adorning the seven windows -- two on the front with the doors, then two more on the sides, save for the back that sets itself against the courtyard walls.
The main doors are two made of a strong wood with a circle on each with six smaller circles within, each circle having a small passage written in Celestial for each layer of Celestia itself. The handles are made of a polished stone that is smoothed over completely so as not to even seem rough at all.
Inside has several  pews, fit for at least 30 people comfortably across with a large walkway between the three sets on the left or right that lead to a grand altar for sermons or for prayer. The altar itself is covered in a rich and dark blue carpeting with gold lining on the ends that leads straight forward and up some small stairs to where the altar itself is. Atop the altar, made of a white and pearly stone, is a small stone and a plank of wood, both from Lunia.
Beyond the altar is a large, stained glass window (oh, there's the seventh one) set with another image of Mount Celestia, with each deity from Celestia set at varying levels, as represents the layers that they each reside in. Right below the stained glass is a permanent image, about 8 feet tall, of Mount Celestia, including clouds and a sparkling light at the top to represent Chronias.
Finally, on the far sides, near the two windows are chairs and tables, two each, for those who wish to simply sit in peace and enjoy the quiet. The windows themselves are all clear so people can look out onto the courtyard at their leisure.
Do me a favor and copy paste that into nagging, I'll probably need it later and that'll be easier to find.
You have plenty of attention when it's done, tired but in a good way. Adrian's there by now, as is Gisfal and Misalea. Cresiel approaches, "It is good," he intones, "You put heart and artistry into this."
"Ah... mm... it was the best way to represent each different lair without taking up too much room." He admits, smiling. he shakes his hands with a bit of a wince. "I'm just happy to... no." He shakes his head and smiles. "I'm just happy."
"You've been to light before," Cresiel says, focusing on the light that represents Chronias. "Be happy."
Moore blinks. ...is that... No... ...is it possible??
He turns and looks at Cresiel, his mouth slightly open. "It must've touched me in a way I can't yet comprehend, then."
"Beg pardon?" Cresiel says, "What touched you?"
Moore closes his eyes. "I keep seeing it -- light. Hearing it, even, apparently." Moore says, not bothering to explain the obvious sudden misunderstanding. "I came from there, before I was here. I think it's still affecting me in some ways."
"Ah." Cresiel leaves it at that, "Let us go in and open this, we can talk of it later."
Moore nods. He turns to the gathered and raises his voice. "Know that anyone with a pure heart is always welcome here. You need not follow in the wisdom of Celestia to enter, but I hope that you will find it while you are here."
At that, he'll move to open the doors for people.
From here there's a lot of people coming to take it in, seeing the new temple and the like.
Okay, there's a lot of stuff that's probably largely hand-waveable unless you wanna go into it. If you do that's fine, say so. What's your next move?
Moore really needs to clear his light-headedness (get it?????) before he does anything else so let's go talk to Cresiel.
