"A dungeon, eh?" Finnegan says this as he stands outside of Cresea's cafe, arms crossed as Finnegan rests on the wall next to him. "You two know anything about this slaad?"
"My understanding is you can find more or less anything you want within the dungeons he creates, but they're all quite dangerous." Moore says. "I think we have enough tricks up our sleeves that we could get through with minimal problems, though."
"Haven't met a dungeon I can't handle," Finnegan says, grabbing his spear. "So it you and Surraruthru?"
"It seems, unless there are others who wish to join. Any thoughts on what we'll be facing in this dungeon? Fire? Acid? Cold? Sound? So I can prepare defensive spells appropriately."
"It's an invitation for three, so it'll just be us." Moore says. "I would expect a variety of things, really... both from a combat perspective as well as a puzzle perspective. I'll have my mask to look around for hidden things at least, so that should help."
"How are we on healing?" Finnegan asks, "Dungeons mean danger, and danger means injuries."
"I should be able to handle it. I'm not an expert, but I can do well enough and in a pinch I have some emergency spells we can use." Moore says. "I can also augment the power of healing easily enough. I think we'd be fine. Surraruthru, can you muster any healing magic?"
"I have a single healing spell. It would be unwise to depend on a wizard for healing."
"Well, you can summon things that can heal, right?" Moore asks. "Either way, I think it will be fine. Like I said, I have plenty of backup spells in case of emergencies."
"It'll have to do," Finnegan says.
Okay, prep for before you go? Going to get any supplies, buy things or whatever?
Make sure everyone uses the arch. I don't think there's anything else for us to do (famous last words).
Also stop by the chow hall for food. Heroes' Feast buff. I don't know the CL on that or if it's DM roll for the temp hp.
Pre-loading Resist Energy to Tapestry: Fire/Cold/Acid/Sonic
Casting the following into the Tapestry (everyone gets these):
Create Magic Tattoo, CL 25, 24 Hour Duration.
+1 Luck Bonus on Attack Rolls.
+2 Competence Bonus on Attack Rolls.
Mighty Wallop, Greater, CL 25, 25 Hour Duration.
+2 Size Category to Bludgeoning/Unarmed Weapons.
Mage Armor, Greater, CL 25, 25 Hour Duration.
+6 armor bonus to Armor Class.
Energy Absorption, CL 28, 28 Hour Duration.
The subject gains resistance 10 against all five energy types: acid, cold, electricity, fire, and sonic.
As an immediate action, the subject can cause the spell to absorb the power of a single energy-based attack. The subject gains immunity to any energy types used in that attack (but only for that attack), and also heals a number of points of damage equal to 1/2 the damage the effect would normally have caused.
Self Only Buffs:
Mind Blank, CL 25, 24 Hour Duration.
Epic Mage Armor, CL 25, 24 Hour Duration.
+20 armor bonus to Armor Class.
Surraruthru
HP: 344/344
AC: 38+20+4 (Deflection)
Init: +13, Touch Atk: 29, +4 to Attack Rolls
Active: Epic Mage Armor (CL 25), Mindblank (CL 28), Fortunate Fate (CL15), Planar Tolerance (CL7)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Blur (Underwater), Freedom of Movement, Water Breathing, Magic Tattoo (+1 Luck to Attack), Magic Tattoo (+2 Competence to Attack), Mighty Wallop (Greater), Heroes' Feast (+1 Morale to Attack Rolls & Will Saves, Immunity to Fear, 1d8+1 Temp. HP.)
CL on Heroes Feast is 20.
Soon all of you are ready...
Go ahead and set yourselves up.
Finnegan
HP: 342/342
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Create Magic Tattoo (CL25), Create Magic Tattoo (CL25), Greater Mighty Wallop (CL25), Energy Absorption (CL28)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, +2 size category for bludgeoning and unarmed weapons, resistance 10 to all elements
Default Aurora boosts
Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20)
Moore has his mask on and is wearing an appropriate adventuring outfit for this as gathers with the others outside Aurora.
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Create Magic Tattoo (CL25), Create Magic Tattoo (CL25), Greater Mighty Wallop (CL25), Energy Absorption (CL28), Tyche's Touch (+4) (CL 24)
HP: 277+16
AC: 47, 27 touch
24/24 Bardic music uses
Spells:
0th - 7/7 (DC 21)
1st - 7/7
2nd - 7/7
3rd - 6/6
4th - 6/6
5th - 6/6
6th - 5/5
7th - 5/5
8th - 1/1
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 6/6
#14
Surraruthru sits next to Moore, having spread his magic between the group.
"I am ready, if you all are."
Surraruthru
HP: 344/344+12(Temp)
