The eastern door is locked. Annoying.
"Finnegan? Your speciality, please."
A simple kick opens the door. Within is a tiny room with a glowing green square raised up slightly and taking up most of the floor.
Okay, that definitely has to be magical.
It has to be.
There's no way it can't be.
RIGHT????
[14:43] <Nephrite> roll 1d20+24 CL
[14:43] <Serith> Nephrite roll for Serith < 37 > [d20=13]
Take 10 for 47 on Spellcraft. I'll also throw a 10 for 47 on K:A if appropriate.
Surraruthru scans the room as well.
> roll 1d20+24 CL
> roll 1d20+36 Spellcraft
<Serith> Iddy roll for Serith < 32 > [d20=8]
<Serith> Iddy roll for Serith < 44 > [d20=8]
Moore can detect that the suppression field isn't active here. This is a simple teleportation circle. Step in it and you'll go elsewhere.
"Oh, it's for teleportation. Should we try it?" Moore asks.
"Maybe not just yet. If we need the grail to deactivate a trap, this may take us to where the trap *is*. May want to look around for that, just in case."
"Wise, especially if there's no return on the other side," Finnegan points out.
Moore nods. "Then let us try the north door, lickety-split."
Surraruthru heads towards the north door!
The moment Surraruthru touches the northern door, it opens double quick. Ahead you can see a 10ft long stretch of pure chaos, the walls having given way. It turns to various elements faster than you can follow. Occasionally when it's right, you can glimpse intact hall beyond it.
"Let me give this a shot." Moore says with a smile. He casts a quick spell (Improvisation) and then tries to simply halt (or at least slow down) the chaos around them with his anarch powers.
[22:40] <Nephrite> roll 1d20+4+12 anarch
[22:40] <Serith> Nephrite roll for Serith < 17 > [d20=1]
The chaos slows and stills - briefly, quivering. The hallway continues on the other side, but you clearly don't have much time.
