"Clever. I wonder if it works going the other way." Moore muses as he waits for the others.
Finnegan crosses and goes to the door ahead, "Let's get moving."
Moore flies after. Hm, is it generating as they go along? Is there no actual 'map,' so to speak?
You open the door. Ahead is a large chamber with two stone statues of minotaurs midway. Past them is a wall of worked stone with three doors going ahead. One is painted orange, one is blue and the last is also orange.
One hardly has a chance to marvel, as one the door is opened, the two stone minotaurs rise up and charge the party.
Init.
[14:36] <Nephrite> roll 1d20+31 init
[14:36] <Kobot> Nephrite rolled 1d20+31 init --> [ 1d20=6 ]{37}
Don't forget +11 to init for everyone.
> roll 1d20+13+11 Init
<Kobot> Iddy rolled 1d20+13+11 Init --> [ 1d20=13 ]{37}
<Kobot> Sunshine_Ko rolled 1d20+24 Finnegan --> [ 1d20=14 ]{38}
> roll 1d20+9 mino 1
> roll 1d20+9 mino 2
<Kobot> Sunshine_Ko rolled 1d20+9 mino 1 --> [ 1d20=1 ]{10}
<Kobot> Sunshine_Ko rolled 1d20+9 mino 2 --> [ 1d20=3 ]{12}
Init is Finnegan (38) > Surraruthru = Moore (37) > Minotaur 2 (12) > Minotaur 1 (10)
Finnegan won but will hold in case either of you are using attacks he'd get in the way of, like fireballs or cones of cold. Go.
"Ah, finally, something serious!" Moore shouts. "Let's enjoy this with something musically various!"
Inspire Courage, +14 to attack and weapon damage rolls, and +14 against fear and charm. Technically this takes effect affter Surru's turn, but I guess he could just hold and then get the bonus.
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Create Magic Tattoo (CL25), Create Magic Tattoo (CL25), Greater Mighty Wallop (CL25), Energy Absorption (CL28), Tyche's Touch (+3) (CL 24)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, +2 size category for bludgeoning and unarmed weapons, resistance 10 to all elements
HP: (1)277
AC: 47, 27 touch
24/24 Bardic music uses (0/3 left from Refrain)
Spells:
0th - 4/7 (DC 21)
1st - 7/7
2nd - 7/7
3rd - 6/6
4th - 6/6
5th - 5/6
6th - 5/5
7th - 5/5
8th - 1/1
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 7/8
5th - 8/8
6th - 6/6
Pre-loading Resist Energy to Tapestry: Fire/Cold/Acid/Sonic
Casting the following into the Tapestry (everyone gets these):
Create Magic Tattoo, CL 25, 24 Hour Duration.
+1 Luck Bonus on Attack Rolls.
+2 Competence Bonus on Attack Rolls.
Mighty Wallop, Greater, CL 25, 25 Hour Duration.
+2 Size Category to Bludgeoning/Unarmed Weapons.
Mage Armor, Greater, CL 25, 25 Hour Duration.
+6 armor bonus to Armor Class.
Energy Absorption, CL 28, 28 Hour Duration.
The subject gains resistance 10 against all five energy types: acid, cold, electricity, fire, and sonic.
As an immediate action, the subject can cause the spell to absorb the power of a single energy-based attack. The subject gains immunity to any energy types used in that attack (but only for that attack), and also heals a number of points of damage equal to 1/2 the damage the effect would normally have caused.
Okay, you held a moment. You're still ahead of the minotaurs and Finnegan. Go.
Surraruthru darts towards the nearest minotaur, launching himself at it, punching, striking, biting and clawing!
> roll 1d6 flailing strikes
<Kobot> Iddy rolled 1d6 flailing strikes --> [ 1d6=6 ]{6}
-1 since I'm now monk 11, so 5 total. Also, I forgot about Magic Tattoo in these rolls, so +3 to attack rolls.
> roll 1d20+28+14 Unarmed
> roll 1d20+25+14 Unarmed
> roll 1d20+18+14 Unarmed
> roll 1d20+13+14 Unarmed
> roll 1d20+23+14 Bite
> roll 1d20+23+14 Claw
<Kobot> Iddy rolled 1d20+28+14 Unarmed --> [ 1d20=15 ]{57}
<Kobot> Iddy rolled 1d20+25+14 Unarmed --> [ 1d20=6 ]{45}
<Kobot> Iddy rolled 1d20+18+14 Unarmed --> [ 1d20=18 ]{50}
<Kobot> Iddy rolled 1d20+13+14 Unarmed --> [ 1d20=17 ]{44}
<Kobot> Iddy rolled 1d20+23+14 Bite --> [ 1d20=3 ]{40}
<Kobot> Iddy rolled 1d20+23+14 Claw --> [ 1d20=14 ]{51}
> roll 1d20+28+14 Flailing Strike 1
> roll 1d20+28+14 Flailing Strike 2
> roll 1d20+28+14 Flailing Strike 3
> roll 1d20+28+14 Flailing Strike 4
> roll 1d20+28+14 Flailing Strike 5
<Kobot> Iddy rolled 1d20+28+14 Flailing Strike 1 --> [ 1d20=13 ]{55}
<Kobot> Iddy rolled 1d20+28+14 Flailing Strike 2 --> [ 1d20=14 ]{56}
<Kobot> Iddy rolled 1d20+28+14 Flailing Strike 3 --> [ 1d20=17 ]{59}
<Kobot> Iddy rolled 1d20+28+14 Flailing Strike 4 --> [ 1d20=15 ]{57}
<Kobot> Iddy rolled 1d20+28+14 Flailing Strike 5 --> [ 1d20=3 ]{45}
> roll 9#3d6+6+14 (Unarmed)
> roll 1d6+3+14 (Bite)
> roll 2#1d4+3+14 (Claw)
<Kobot> Iddy rolled 9#3d6+6+14 (Unarmed) --> [ 3d6=4 ]{24}, [ 3d6=8 ]{28}, [ 3d6=16 ]{36}, [ 3d6=13 ]{33}, [ 3d6=11 ]{31}, [ 3d6=15 ]{35}, [ 3d6=13 ]{33}, [ 3d6=16 ]{36}, [ 3d6=9 ]{29}
<Kobot> Iddy rolled 1d6+3+14 (Bite) --> [ 1d6=5 ]{22}
<Kobot> Iddy rolled 2#1d4+3+14 (Claw) --> [ 1d4=4 ]{21}, [ 1d4=3 ]{20}
Greater Mighty Wallop and Moore buffs FTW.
Surraruthru
HP: 344/344+12(Temp)
AC: 38+20+4 (Deflection)
Init: +13, Touch Atk: 29, +4 to Attack Rolls
Active: Epic Mage Armor (CL 25), Mindblank (CL 28), Fortunate Fate (CL15), Planar Tolerance (CL7), Moment of Prescience (CL 25)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Water Breathing, Magic Tattoo (+1 Luck to Attack), Magic Tattoo (+2 Competence to Attack), Mighty Wallop (Greater), Heroes' Feast (+1 Morale to Attack Rolls & Will Saves, Immunity to Fear, 1d8+1 Temp. HP.)
On one hand, I didn't list distances by mistake, so it's not precisely clear how far away the minotaurs are. On the other hand they're certainly not within immediate FA range.
So I'll split the difference and assume you hold then unload as one charges. Seems fairest since they're already known to be approaching and I forgot to list the distances.
Incidentally, they're 20ft ahead and the far wall's 35ft ahead. I'll resolve your attack in one sec, once Finnegan goes, since he's first.
As one minotaur rushes Surraruthru, Finnegan becomes a blur, darting ahead to meet the other spear first.
> roll 1d20+41 (+2 charge, +14 bardsong, +1 luck, +2 competence, -25 PA, dire charge modifier is in play)
<Kobot> Sunshine_Ko rolled 1d20+41 (+2 charge, +14 bardsong, +1 luck, +2 competence, -25 PA, dire charge modifier is in play) --> [ 1d20=3 ]{44}
> roll 94*2
<Kobot> Sunshine_Ko rolled 94*2 --> {188}
> roll 2d8+188+1d6
<Kobot> Sunshine_Ko rolled 2d8+188+1d6 --> [ 2d8=10 1d6=6 ]{204}
One moment the first minotaur's head is intact, the next Finnegan's spear hits it and the stone bursts into a thousand tiny shards. Cracks run down the minotaur's form as it crumbles apart, crashing with a loud din. As the other minotaur passes him, Finnegan's spear lashes out for his side.
Finnegan gets AoOs on opponents who charge into a square he threatens thanks to his hold the line feat.
> roll 1d20+41 (+2 charge, +14 bardsong, +1 luck, +2 competence, -25 PA)
<Kobot> Sunshine_Ko rolled 1d20+41 (+2 charge, +14 bardsong, +1 luck, +2 competence, -25 PA) --> [ 1d20=7 ]{48}
> roll 1d8+94+1d6
<Kobot> Sunshine_Ko rolled 1d8+94+1d6 --> [ 1d8=5 1d6=1 ]{100}
The blow sends cracks all along the stone minotaur's side, a small crater where a hip should be. But it keeps going, meeting Surraruthru in a deadly, head on charge.
> roll 1d20+35 vs Surraruthru (+2 charge)
<Kobot> Sunshine_Ko rolled 1d20+35 vs Surraruthru (+2 charge) --> [ 1d20=19 ]{54}
> roll 1d20+35 vs Surraruthru (+2 charge) crit threat
<Kobot> Sunshine_Ko rolled 1d20+35 vs Surraruthru (+2 charge) crit threat --> [ 1d20=11 ]{46}
Surraruthru's total AC is 62, which means he misses flat out. Also, could you note your total AC after all the mods so I can just glance and get it? Thanks.
Surraruthru neatly sidesteps the attack and latches onto the golem, striking and biting. He gets into the cracks Finnegan's attack makes and simply rends it apart with a dozen blows, both of the minotaurs nothing but rubble now.
All that's left intact are a pair of stone axes, undamaged by your short combat.
Free act.
Bardsong+14 attack/damage/fear saves
Finnegan
HP: 342/342
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Create Magic Tattoo (CL25), Create Magic Tattoo (CL25), Greater Mighty Wallop (CL25), Energy Absorption (CL28), Share Talents (CL13)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, +2 size category for bludgeoning and unarmed weapons, resistance 10 to all elements, +2 swim checks.
"Well done, everyone!" Moore says with a clap. He'll investigate the rubble first.
Take 10 for 32 on Search if needed. Surru or Finnegan can store the axes since they're probably way too heavy for Moore to  lift.
You check the rubble over. In one of the minotaurs you find an intact stone crescent, carved from a deep green stone.
Finnegan hefts one of the axes, "It's magical," he says, "Can see the aura around it."
