"Personally, I'd rather be underestimated than anything else. Less work that way. Let's head down to the bottom and see if it left anything for us."
Surraruthru keeps heading down, keeping an eye out for loot or passages.
You descend down into the passage. As you do...
Do you still have DM up, either of you?
I have it as an at-will, so it's always active to me.
Surraruthru can note a complex and shimmering mantle of magic below, the area beneath you deeply enchanted.
Spellcraft.
I think Moore's skill boost is still up, but I wasn't sure so I didn't include it. +2 if it is.
> roll 1d20+36 Spellcraft
<Serith> Iddy roll for Serith < 46 > [d20=10]
Will save, Surraruthru. Mind affecting so note if immune or protected.
Mindblank, CL 28
But just in case:
> roll 1d20+29 Will
<Serith> Iddy roll for Serith < 40 > [d20=11]
Surraruthru
HP: 344/344+5(Temp)
AC: 62 = 38+20+4 (Deflection)
Init: +13, Touch Atk: 29, +4 to Attack Rolls
Active: Epic Mage Armor (CL 25), Mindblank (CL 28), Fortunate Fate (CL15), Planar Tolerance (CL7), Moment of Prescience (CL 25), Energy Absorption (CL 28)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Water Breathing, Magic Tattoo (+1 Luck to Attack), Magic Tattoo (+2 Competence to Attack), Mighty Wallop (Greater), Heroes' Feast (+1 Morale to Attack Rolls & Will Saves, Immunity to Fear, 1d8+1 Temp. HP.)
All the magic is simply a trap. It's designed to ensnare the mind of anyone who studies it and leave them comatose. Fortunately, your mind blank spell shielded you.
"It's a trap. The magic is designed to leave anyone who studies it comatose. Don't look in depth at it. Below it is a heavily enchanted area."
"Doesn't want anyone finding out his secrets, I suppose." Moore says as they continue along.
"Neither did Secretus. Look how well that worked out for him."
You descend a little deeper. As you do, 60ft below, you see a pair of black tentacles rising from the depths. They're coming up rather rapidly, making no attempt at stealth whatsoever.
"Round 2," Finnegan murmurs, spear ready.
Init here.
"At least it's direct." Moore counters.
[22:11] <Serith> Nephrite roll for Serith < 33 > [d20=2]
> roll 1d20+13+11 Init
<Serith> Iddy roll for Serith < 36 > [d20=12]
> roll 1d20+24 Finnegan
<Serith> Kotono roll for Serith < 26 > [d20=2]
> roll 1d20+20 Tentacles
<Serith> Kotono roll for Serith < 32 > [d20=12]
Init is Surraruthru (36) > Moore (33) > Tentacles (32) > Finnegan (26)
Open Surraruthru.
