Surraruthru begins chanting again, calling on his magical powers again as he blasts a spell at the thing!
Disintegrate, CL 25.
> roll 1d20+32+17 Ranged Touch Attack
<Serith> Iddy roll for Serith < 65 > [d20=16]
> roll 1d20+25 CL Check
<Serith> Iddy roll for Serith < 27 > [d20=2]
> roll 40d6 Disintegrate
<Serith> Iddy roll for Serith < 145 > [d6=2,6,3,1,2,5,5,6,5,1,2,5,5,4,1,3,1,5,5,6,1,4,3,3,1,3,6,6,4,6,4,5,2,3,5,2,3,2,6,3]
Surraruthru
HP: 344/344+5(Temp)
AC: 62 = 38+20+4 (Deflection)
Init: +13, Touch Atk: 29, +4 to Attack Rolls
Active: Epic Mage Armor (CL 25), Mindblank (CL 28), Fortunate Fate (CL15), Planar Tolerance (CL7), Moment of Prescience (CL 25), Energy Absorption (CL 28)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Water Breathing, Magic Tattoo (+1 Luck to Attack), Magic Tattoo (+2 Competence to Attack), Mighty Wallop (Greater), Heroes' Feast (+1 Morale to Attack Rolls & Will Saves, Immunity to Fear, 1d8+1 Temp. HP.)
> roll 1d20+26 main body
<Rei-chan> Kotono rolled : 1d20+26 main body --> [ 1d20=15 ]{41}
DC Iddy?
Okay, roll the 5d6 damage for a resisted disintegrate.
[12:34] <Nephrite> roll 5d6
[12:34] <Rei-chan> Nephrite rolled : 5d6 --> [ 5d6=19 ]{19}
The beam strikes the creature dead center, making a bit of it crumble away. Only a little bit, as you can see the clear effects of your spell being resisted. No great hunk of it is gone, the creature's endurance mightier than your magic.
The abomination rises up, Finnegan still on it. It's coming up right for you two!
You two can choose one of the following options.
1. Stand your ground. You'll get an AoO against it, but unless you kill it, it'll automatically slam into you.
2. Dodge upwards. It'll give you a chance to avoid it - it'll depend on how fast you and it are.
As I can't full attack on an AoO, I shall be taking the second option as well. 100ft fly speed with perfect maneuverability for Surraruthru.
Both of you fly up as fast as you can, the nightmarish mass following. You're both able to keep pace with it, avoiding being overrun. Tentacles lash up as you do, knocking bits of the wall away as they try and grab both of you.
> roll 1d20+40 Moore
<Serith> Kotono roll for Serith < 46 > [d20=6]
> roll 1d20+40 Surraruthru
<Serith> Kotono roll for Serith < 56 > [d20=16]
> roll 1d20+55 vs Moore's CMD if needed
<Serith> Kotono roll for Serith < 72 > [d20=17]
> roll 1d20+55 vs Surraruthru's CMd if needed
<Serith> Kotono roll for Serith < 59 > [d20=4]
Okay, do those first rolls hit you two? If so, does the second roll hit your CMD?
Fortunately, both of you are too fast. You fly upward as cracks in the gorge appear, greenish fluid leaking out the walls. At the same time, the flesh Finnegan stands on morphs into toothy maw, trying to swallow him whole.
> roll 1d20+40
<Serith> Kotono roll for Serith < 57 > [d20=17]
> roll 6d8+22
<Serith> Kotono roll for Serith < 54 > [d8=7,3,3,5,8,6]
Finnegan's leg is gotten up to the knee, teeth tearing into it. Finnegan winces and brings his spear down, forcing the mouth open and pulling his limb free. "Testy bastard, eh?" he mutters, spinning his spear back. He then brings it down over and over, dashing about despite his bleeding leg, trying to skewer the thing half a hundred times.
Finnegan's up.
> roll 1d20+47 (+1 aura, +14 bardic music, +2 competence, +1 luck, +3 destined strike, -21 PA)
<Serith> Kotono roll for Serith < 63 > [d20=16]
> roll 1d20+42 (+1 aura, +14 bardic music, +2 competence, +1 luck, +3 destined strike, -21 PA)
<Serith> Kotono roll for Serith < 44 > [d20=2]
> roll 1d20+37 (+1 aura, +14 bardic music, +2 competence, +1 luck, +3 destined strike, -21 PA)
<Serith> Kotono roll for Serith < 53 > [d20=16]
> roll 1d20+32 (+1 aura, +14 bardic music, +2 competence, +1 luck, +3 destined strike, -21 PA)
<Serith> Kotono roll for Serith < 52 > [d20=20]
> roll 1d20+32 (+1 aura, +14 bardic music, +2 competence, +1 luck, +3 destined strike, -21 PA) crit?
<Serith> Kotono roll for Serith < 40 > [d20=8]
> roll 1d8+89+3d6 and 1 negative level
<Serith> Kotono roll for Serith < 102 > [d8=2][d6=6,4,1]
<Serith> Kotono roll for Serith < 107 > [d8=7][d6=4,3,4]
<Serith> Kotono roll for Serith < 106 > [d8=7][d6=3,4,3]
> roll 3d8+267+3d6 and 3 negative levels
<Serith> Kotono roll for Serith < 294 > [d8=5,8,6][d6=5,1,2]
Finnegan is a blur of green and white as his spear rips into the flesh of the abomination over and over again. More oddly colored blood sprays out, but it's not stopping. No matter how many times he impales it, the mass of flesh keeps rising.
Moore, go. You're forced to take a move action to keep evading it. You can choose not to do this, but it'll catch you next round automatically if you do.
Finnegan
HP: 288/342
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Create Magic Tattoo (CL25), Create Magic Tattoo (CL25), Greater Mighty Wallop (CL25), Energy Absorption (CL28), Share Talents (CL13)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, +2 size category for bludgeoning and unarmed weapons, resistance 10 to all elements, +2 swim checks.
