So it doesn't, probably since it lists all of them rather than just one. In this case I'll give you the benefit of the doubt there, sure.
Hole's fine for that, but bear in mind it'll let some things through it, too. Radius spreads in particular can get through, as well as lines aimed at it.
Sure, but if we stand away from it, we should still be clear, yeah? If not, then no hole; I'll just dismiss it when/if we need to instead.
Depends on how big a radius spread you're talking about. But most likely yes.
Eh, go the safe route and leave no hole. If the storms get smashed to pieces, we'll likely want to just leave anyway.
Okay then. Moore? I'll describe all this when I have all the actions in.
#605
Once the allies have suddenly appeared, Moore gets to work!
"It's time to go all out, then!" Moore calls, invigorating his allies!
Casting Harmonize again and then Inspire Courage. +14 to attack and weapon damage and saves against fear and charm, +2 to attack rolls on top of that.
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Create Magic Tattoo (CL25), Create Magic Tattoo (CL25), Greater Mighty Wallop (CL25), Energy Absorption (CL28), Tyche's Touch (+3) (CL 24)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, +2 size category for bludgeoning and unarmed weapons, resistance 10 to all elements, +12 to attack and weapon damage, ac and saves
HP: (69)269/277
AC: 47, 27 touch
17/24 Bardic music uses (0/3 left from Refrain)
Spells:
0th - 3/7 (DC 21)
1st - 5/7
2nd - 5/7
3rd - 6/6
4th - 6/6
5th - 5/6
6th - 5/5
7th - 5/5
8th - 1/1
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 8/9
3rd - 8/8
4th - 6/8
5th - 8/8
6th - 6/6
Pre-loading Resist Energy to Tapestry: Fire/Cold/Acid/Sonic
Casting the following into the Tapestry (everyone gets these):
Create Magic Tattoo, CL 25, 24 Hour Duration.
+1 Luck Bonus on Attack Rolls.
+2 Competence Bonus on Attack Rolls.
Mighty Wallop, Greater, CL 25, 25 Hour Duration.
+2 Size Category to Bludgeoning/Unarmed Weapons.
Mage Armor, Greater, CL 25, 25 Hour Duration.
+6 armor bonus to Armor Class.
Energy Absorption, CL 28, 28 Hour Duration.
The subject gains resistance 10 against all five energy types: acid, cold, electricity, fire, and sonic.
As an immediate action, the subject can cause the spell to absorb the power of a single energy-based attack. The subject gains immunity to any energy types used in that attack (but only for that attack), and also heals a number of points of damage equal to 1/2 the damage the effect would normally have caused.
Okay.
Finnegan drifts back and waits, "Be ready to cut and run if this doesn't work," he warns, as one of them advances on the elementals, starting to go up as...
Go ahead and have the elementals unload on it, Iddy. Since I'm assuming they were holding for that. If not say so.
The Storm Elementals stare unflinchingly down at the rising monstrosity, their bodies rumbling and cracking with barely contained thunder and lightning as their fury against these unnatural things get closer. Once it close enough for the elementals to unleash their full fury, they do, throwing the rage of a thunderstorm at it!
Thunder and Lightning (Su); Also since they have Electrical and Sonic Healing (Ex) they heal 1 point per 3 points of damage from each of the other elementals, but not themselves.
CORRECTION: Sonic save is Fort based, not Ref. Electricity is Ref save.
> roll 8d6 Sonic DC 24, Ref Half, Elemental 1
> roll 16d6 Electricity DC 24, Ref Half, Elemental 1
<Serith> Iddy roll for Serith < 20 > [d6=2,1,3,1,4,3,2,4]
<Serith> Iddy roll for Serith < 53 > [d6=5,6,1,4,1,3,4,6,2,2,5,5,4,3,1,1]
> roll 8d6 Sonic DC 24, Ref Half, Elemental 2
> roll 16d6 Electricity DC 24, Ref Half, Elemental 2
<Serith> Iddy roll for Serith < 25 > [d6=4,2,2,4,2,2,3,6]
<Serith> Iddy roll for Serith < 56 > [d6=2,5,3,4,2,2,4,1,2,3,6,5,5,4,3,5]
> roll 8d6 Sonic DC 24, Ref Half, Elemental 3
> roll 16d6 Electricity DC 24, Ref Half, Elemental 3
<Serith> Iddy roll for Serith < 23 > [d6=1,3,5,1,4,3,1,5]
<Serith> Iddy roll for Serith < 48 > [d6=5,2,1,3,4,1,5,1,6,2,1,5,2,4,3,3]
> roll 8d6 Sonic DC 24, Ref Half, Elemental 4
> roll 16d6 Electricity DC 24, Ref Half, Elemental 4
<Serith> Iddy roll for Serith < 30 > [d6=5,5,1,3,6,3,4,3]
<Serith> Iddy roll for Serith < 61 > [d6=1,6,6,6,4,4,1,5,3,3,4,2,6,5,3,2]
> roll 1d20+20 (-4 circumstance) ref 1
> roll 1d20+20 (-4 circumstance) ref 2
<Serith> Kotono roll for Serith < 32 > [d20=12]
> roll 1d20+20 (-4 circumstance) ref 3
> roll 1d20+20 (-4 circumstance) ref 4
<Serith> Kotono roll for Serith < 25 > [d20=5]
<Serith> Kotono roll for Serith < 33 > [d20=13]
> roll 1d20+28 fort 1
<Serith> Kotono roll for Serith < 39 > [d20=11]
> roll 1d20+28 fort 2
<Serith> Kotono roll for Serith < 46 > [d20=18]
> roll 1d20+28 fort 3
> roll 1d20+28 fort 4
<Serith> Kotono roll for Serith < 36 > [d20=8]
Blasts of thunder and lightning pummel the abomination, enough to make it quickly retreat back and out of range, rather than pushing the attack. It's hard to see details with everything going on, but you can see patches of burnt skin after that, as well as the entire mass vibrating from the sonic assault.
Ball's in your court here since it doesn't seem inclined to challenge the elementals after that.
"Hmm.. I can order the elementals to go down to the mouth of the tunnel and see if they'll go after them there. Ideas?"
Moore rubs his chin. "I really didn't expect that. Are they smart enough to reason? Drat." He seems to consider for a moment. "I guess it depends on if we want to fight them at the disadvantage of going in there further."
"No. Too risky," Finnegan shakes his head. "All of this means nothing if we die."
"Well, I can send them into the open space and let them cause general havoc while I drop the Wall of Force and we try to lure them into the tunnel. If we can get them to come after us while the elementals keep them disorganized, we'll do well, I think."
Moore nods. "Give it a try. If we need to rethink the plan, we can, on the fly."
Surraruthru nods and turns to the elementals, pausing....
"Anyone speak elemental? I don't have a telepathic spell for them..."
