The Archive (Jaela)
Started by Anastasia, December 20, 2016, 04:17:10 PM
Canderella sighs deeply, "Ah, to be so focused. You'll learn to stop and sniff the roses as you get older, Jaela."
"Or lose track of centuries." Moonlight remarks, "Being focused is important rather than going after every little distraction."
"If you think that's roses you need to get your nose checked, Candy!"
"The metaphorical roses," Canderella retorts right away. "Roses are overrated, anyway."
Blindsight range, Jaela?
You can sense something small well above you, moving in and hovering directly above you.
"Bad idea to sneak up or spy on me," Jaela notes, manifesting Gae Dearg and pointing the anti-undead spear at the sensor.
You look up. It's not a sensor but instead a small little eye, floating in the air. It stares down at all of you.
"Annoying," Vul'lath says, "Do you want something or are you merely a voyuer?"
Jaela raises an eyebrow, deciding to give the interloper a chance to respond. Canderella will be happy with that, at least!
The eye bobs above all of you and then hovers right where it is.
"I'll take it as a no," Jaela says dryly, continuing down her original path.
Canderella looks up at it, "I hope whomever is spying thinks it's worth it. If we find you....oh, you know how these things go."
The eye follows above all of you in the meantime.
Jaela doesn't pay the eye any extra attention, retrieving her spear and proceeding onwards.
> roll 1d100
<Rei-chan> Kotono rolled : 1d100 --> [ 1d100=13 ]{13}
You wander for a time. This floor is rather quiet right now. You come to a normal enough turn, but from beyond it, you can her the sound of something clattering. Sounds metallic.
Ahead sits an iron golem. It's a creature you've seen many times. It holds a bloodied body in its arms, smashing it against itself. The clatter comes from its arms against its body. Books shake and a few fall as it does what it does.
