> roll 1d20+15 Bubbles
<Serith> Kotono roll for Serith < 19 > [d20=4]
> roll 1d20+17 Nessian
<Serith> Kotono roll for Serith < 35 > [d20=18]
Init is Nessian (35) > Bubbles (19) > Surraruthru (17) > Tryll (16) > Calleigh (10) > Construct 1 (8) > Construct 2 (3)
With an errant gesture, the Nessian points a single finger-claw at Surraruthru.
You're getting dispelled. Have any defenses against it? If not, list the spells your under and the caster level.
#256
Can I counter his dispel? If he's casting or SLA'ing, shouldn't I get an AoO? Though you didn't say anything about distances here. But yes, I do have Spell Turning active at CL 29.
Create Magic Tattoo, CL 26
Energy Absorption, CL 29
Elemental Body, CL 26
Surraruthru's Stupendous Dragonskin, CL 29
Agility of the Dragon Princess, CL 26
Strength of the Dragon Princess, CL 26
Mind of the Dragon Princess, CL 26
Mind Blank, CL 29
Stoneskin, CL 29
Spell Turning, CL 29
Moment of Precscience, CL 26
Superior Mighty Wallop, CL 26
Epic Mage Armor, CL 26
You're currently flatfooted, so unless you have a counter you can use while being so, no. Let me know if you do.
No, he makes a Concentration check he auto passes, so I don't bother to roll it. Same reason I don't ask y'all for routine Concentration checks.
He's about 10ft from you at most, he came right up through the ground.
Gotcha. Spell Turning would kick in, then. There's supposed to be some roll for it done secretly or something, I think.
Unfortunately, it's of a higher level than spell turning can reflect. So that means it is only partly turned instead. It's an 11th level spell and you got a 10 on your spell turning result, so it's mostly turned. After doing the math, that means .09 of the spell got through, or a 9% chance it succeeds anyway. So on a 1-9 you're hit and a 10+ the Nessian is affected.
> roll 1d100
<Serith> Kotono roll for Serith < 4 > [d100=4]
Brutal luck, man.
> roll 14#1d20+37 dispellin'
<Serith> Kotono roll for Serith < 43, 42, 53, 53, 49, 40, 43, 46, 44, 57, 53, 44, 42, 48 >
I know you have a lot of abjuration powers, do you have anything that specifically makes spells harder to dispel than the sheer CL?
All of your spells are shredded. Ow.
Surraruthru's magic collapses in a massive burst of spellfire, scorching the walls and ground around you. The Nessian growls low once your defenses are down, before the fury of the elements explodes around you.
Ref save, Surraruthru.
> roll 1d20+29 ref
<Serith> Iddy roll for Serith < 35 > [d20=6]
You dodge a spell you know well - Hellball. You dodge the four elements left unchecked, diving to the side in a graceful roll. As you do, you see the stray spellfire gush into the Nessian, a bright glow surrounding his body. It seems more, presence overpowering the room.
"Shit," Bubbles hisses. In your mind you hear, 'Get out of there, Surraruthru. I can trap it in there and give it some friends to play with.'
Bubbles holds. Surrurathru.
Surraruthru does so, moving back to a safer distance before casting a spell at the Pit Fiend himself!
Two can play that game.
Reaving Dispel, CL 33, No Save/SR.
Need the number of dispel roll to make.
> roll 20#1d20+20 Reaving Dispel
<Serith> Iddy roll for Serith < 39, 37, 27, 34, 36, 32, 31, 34, 23, 24, 26, 31, 21, 33, 35, 29, 26, 37, 34, 32 >
> roll 20#1d20+37 Spellcraft
<Serith> Iddy roll for Serith < 40, 53, 39, 51, 39, 53, 54, 47, 38, 45, 53, 41, 53, 49, 48, 39, 39, 48, 52, 49 >
You get the following spells:
Mind Blank (CL20), Freedom of Movement (CL20), Superior Resistance (CL20), See Invisibility (CL20), True Seeing (CL20), Death Ward (CL20), Bear's Endurance (CL20), Owl's Wisdom (CL20), Eagle's Splendor (CL20), Barkskin (CL20), Greater Mage Armor (CL20)
Taking them all?
Dispeling Bear's Endurance, Owl's Wisdom, and Eagle's Splendor. They don't stack with my equipment. Taking everything else.
Also, and this is 100% my fault since I forgot to say this then, moving away from the Nessian provokes an AoO. You okay with that?
