The first construct has been advised to turn and head toward the center of the chamber, and will proceed at the appropriate 5 ft pace. The second construct will wail on the devil somewhat blindly.
Rolling miss chances at 20%
[blockquote]Rolled 1d100 : 89, total 89[/blockquote][blockquote]Rolled 1d100 : 5, total 5[/blockquote][blockquote]Rolled 1d100 : 10, total 10[/blockquote]
Made one, so make the attack roll for the one that beat miss chance?
[blockquote]Rolled 1d20+28 : 5 + 28, total 33[/blockquote]
Swing and a miss, so onto a Fort save for Bubbles.
> roll 1d20+22 Bubbles
<Serith> Kotono roll for Serith < 30 > [d20=8]
200 vile damage. Surraruthru halves it but Bubbles does not. Track vile damage since it can only be healed in specific situations.
The assault of unholy power comes in a blast of sheer might, your bodies cracking and bleeding all over. It's like you're eggs tapped against the side of a bowl, cracks spreading all over you from your fronts. You hear Bubbles cry in agony as you're checked back hard, as...
Init is Nessian (35) > Surraruthru (17) > Bubbles = Elementals (16.1) > Tryll (16) > Calleigh (10) > Construct 1 (8) > Construct 2 (3)
Go Surru.
Bubbles
HP: 71/279 (200 vile)
Spells Active: Mind Blank (CL26), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Create Magic Tattoo (CL26), Create Magic Tattoo (CL26), Energy Absorption (CL26), Elemental Body (CL26), Surraruthru's Stupendous Dragonskin (CL26), Agility of the Dragon Princess (CL26), Strength of the Dragon Princess (CL26), Mind of the Dragon Princess (CL26), Stoneskin (CL26), Spell Turning (CL26)
Bonuses: +1 morale attack rolls, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, resistance 10 to all elements, +10 armor bonus to armor class, damage reduction 10/magic, water mastery, drench, +4 insight Dex, Str, Int, damage reduction 10/adamantine
Resources Used: Fog trap
As a note:
Moderate School Esoterica (Ex): At 7th level, your long study of your chosen school leads to a breakthrough. You gain an ability from those below based on your chosen school. Each ability is triggered automatically when you cast a spell from your chosen school and lasts for a number of rounds equal to the spell's level (unless otherwise noted).
Abjuration: If you are subject to a spell that has a partial or half effect on a successful save, you suffer no adverse effect if you successfully save.
Reaving Dispel that I cast last turn is an Abjuration spell of the 9th circle, and so I am protected for 8 more rounds.
Cool. No damage to you then. Your turn.
#291
Surraruthru gives the Pit Fiend a nasty smile as he begins chanting, calling on some of his most powerful magic!
Time Stop, CL 26.
> roll 1d4+1
<Serith> Iddy roll for Serith < 3 > [d4=2]
Round 1: Duelward, CL 229, Duration 29
Counter-spelling is an immediate action for you, allowing you to counterspell even when it is not your turn without having previously readied an action. You also gain a +4 competence bonus on Spellcraft checks made to identify spells being cast.
Round 2: Wall of Force, CL 26, Sculpted.
Using this to box in the Fiend; if possible I'd like to leaving a couple small holes in it so we can lob more spells in, but small enough that we can step out of the path of whatever spill over from him escapes through it.
Round 3: Hallow, CL 25.
Using this on a point so that the centered 40 ft area covers the fiend and leaves a bit outside for Bubbles and us to dive into for healing.
Surraruthru
HP: 294/347
AC: 53 =38+4+5+6 (Def/Barkskin/GMA)
Init: +13, Touch Atk: 37
Active: Mind Blank (CL20), Freedom of Movement (CL20), Superior Resistance +6 Saves (CL20), See Invisibility (CL20), True Seeing (CL20), Death Ward (CL20), Barkskin (CL20), Greater Mage Armor (CL20)
All that last bit happened before I was checked in. Can I manifest Intellect Fortress as an immediate action to halve the damage to Bubbles?
Certainly, Yuth. I'll describe that once Iddy's done tinkering with his post.
Surraruthru weaves spells around him, as Bubbles stirs. A glimmering field is momentarily visible, the worst of the blast having been deflected at the last moment. "THIS WILL AVAIL YOU NOTHING!" The Nessian bellows, as...
Bubbles stumbles into the holy ground, holding her injured body as her wounds heal.
Heal spell. Go Tryll'n'Calleigh combo platter.
Bubbles
HP: 279/279
Resources Used: Fog trap, heal.
Details of interrupt round: Intellect Fortress manifested, augmented to last 4 additional rounds. PP cost: 11.
Oh the plight of the blaster who cannot see. Wait a sec. If we can't see him, how's he seeing us in order to slap around Surru and Bubbles with vile damage?
Tryll
HP: 246/246
AC: 47
Touch AC: 30
Flatfooted AC: 39
Active Effects: Inertial Armor (Extended, Overchanneled, CL 26), Mind Blank (CL 26), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Magic Circle Against Evil (CL 25), Create Magic Tattoo (+1 luck bonus to attack rolls, CL 26), Create Magic Tattoo (+2 competence bonus to attack rolls, CL 26), Energy Absorption (CL 26), Elemental Body (CL 26), Surraruthru's Stupendous Dragonskin, (+10 armor bonus & DR 10/magic CL 26), Agility of the Dragon Princess (+4 insight to dexterity, CL 26), Strength of the Dragon Princess (+4 insight to strength, CL 26), Mind of the Dragon Princess (+4 insight to intelligence, CL 26), Stoneskin (DR 10/adamantine, CL 26), Spell Turning (CL 26), True Seeing (CL 26)
PP: 548
Spells Expended: Mending
Calleigh
HP: 123/123
AC: 49
Touch AC: 27
Flatfooted AC: 36
Active Effects: Inertial Armor (Extended, Overchanneled, CL 26), Mind Blank (CL 26), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Create Magic Tattoo (+1 luck bonus to attack rolls, CL 26), Create Magic Tattoo (+2 competence bonus to attack rolls, CL 26), Energy Absorption (CL 26), Elemental Body (CL 26), Surraruthru's Stupendous Dragonskin, (+10 armor bonus & DR 10/magic CL 26), Agility of the Dragon Princess (+4 insight to dexterity, CL 26), Strength of the Dragon Princess (+4 insight to strength, CL 26), Mind of the Dragon Princess (+4 insight to intelligence, CL 26), Stoneskin (DR 10/adamantine, CL 26), Spell Turning (CL 26), True Seeing (CL 26)
Psicrystal
HP: 123/123
AC: 31
Touch AC: 14
Flatfooted AC: 29
Active Effects: Inertial Armor (Extended, Overchanneled, CL 26), Mind Blank (CL 15), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Magic Circle Against Evil (CL 25), True Seeing (CL 26)
He dispelled the fog trap, that's how. Apparently I wasn't clear enough since both you and Iddy missed that. He dispelled and then zapped both of 'em hard.
I missed that! Well then, time for misery!
Wind! From nowhere! Twin windstorms gyrating in opposite directions scream across the chamber, blasting the devil and buffeting him about!
Ranged touch attacks!
[blockquote]Rolled 1d20+21 : 12 + 21, total 33[/blockquote][blockquote]Rolled 1d20+21 : 12 + 21, total 33[/blockquote]
Also my uncle just died 20 minutes ago so I might be dodgy for a bit.
