'We'll wait for now, then. Everyone hold position, if Tryll gets in trouble we'll have to go in hard and fast,' Afina sends to the other officers down here. Then topside, 'Tepen, I don't know how much of that you got? Start recalling everyone back to Aurora, if we fail here we need to minimise casualties to our forces.'
Tryll follows it. Through solid ground for a time until you hit something hard, something your ethereal form can't pass through. It pushes you back, solid as steel.
<Serith> Yu roll for Serith < 46 > [d20=5]
Spellcraft. Dafuq is it?
It's a ward against ethereal travelers, earth gliding and other means to pass through solid stone. It's well designed, inclusive and powerful. It does nothing to prevent solid material passing or magic, however.
So I could attempt to teleport through it to the other side?
Does it appear to be attached to the explosive ward? Is there anything here that would set off an alarm if I teleport that I can see?
It is not attached to that ward, though it's attached to the same thing the explosive ward is. You see no alarms or the like.
'I've encountered a barrier to non-corporeal travel. I'm going to attempt to circumvent it and teleport past it. It appears that it would let magic pass through. If I'm wrong, it was a pleasure knowing you all.' Tryll sends back to the group.
'Good luck,' Bubbles says, 'Darling, if you aren't sure it's safe, should you really do it?'
'What happened to that healthy wariness?' Afina asks dryly.
'Should we coordinate an attempt to get to the anchor on our end as well?'
'Well, from what I can see the ward prevents travel by means ethereal, earth-gliding, and the like. Physical and astral travel is unimpeded. I don't want to really do anything to bring it down as it's also attached to the anchor I'm looking for. The other option is to, well, leave.' Tryll replies. 'I can't not be incorporeal, or I'd just disintegrate a hole and stroll past.'
'We'll give Tryll his shot,' Afina says. 'If we fail to hear from him afterwards or he gets into distress we'll attack in force as I outlined.'
Without further ado, Tryll teleports forward!
Using Dimension Door to teleport to the other side of the ward.
