You teleport across it. You're presumably across it, stuck in more stone and unable to see. So it worked, looks like.
'I am across, any new activity on your end?'
'Not seeing any response from the guards visible from here,' Afina replies.
'Alright, proceeding.'
Moving toward the anchor.
You proceed onward, following it until you come up into a dimly lit room. The entire room is full concentric circles, one inside of the next. Nine in total, the last circle holding a black orb. Lines of magic as thick and solid as veins connect to it, pulsing and sucking black energy from the orb, which quickly tints green. A radiance of blue spellfire comes from the top of the orb, spreading all about the chamber. No one is in here besides yourself.
I'm assuming the spells all lead here?
Looks like it, but a Spellcraft check to analyze the situation is called for.
<Serith> Yu roll for Serith < 42 > [d20=1]
They all come here, alright. They flow right in.
'I've found the anchor.' Tryll sends, 'It's not good. Nine circles around it, each appearing to power some sort of ward. The anchor itself is a large black sphere.'
Can I tell if it all needs to be brought down at once, or can I pick and choose which part to break? What's the thing at the center? Sphere of Annihilation?
'Can you dispel them all or do you need us to come in?' Afina asks.
