Boots on the ground (Moore)
Yes. He figures if something can see him he'll just... you know, leave.
The room ahead is a small room. It's mostly empty, save for a few broken chairs and some trash. A door leads further into the building.
Moore will simply turn around and unlock the front door to open it, since he doesn't have a lot of time to go phasing about!
Done. Adrian steps through and nods quietly, moving as silently as he can. He points at the next door and then to you.
Moore flies over and will pass through it to check!
Greater Blink lasts for 26 rounds so he should have the time to do that.
The next room is a large shop floor, completely trashed. Over a dozen collaborators and barbazu mind the windows on the far side, while near you are few dozen innocents held captive by several barbazu. In the center of it is a single woman in a tight-fitting dress, a vision of lavender skinned loveliness.
K:P, Moore.
The creature is a brachina, a powerful temptress.
I can go into more detail if you aren't familiar with them, Moore. You aced the check so you'd know most everything about them.
I am not, so a few questions: Is it reasonable to believe that Moore and Adrian could probably deal with the fluff enemies and she'd be the actual challenge? Do brachina tend to be able to see invisible things?
As you've seen, typical barbazu are no thread to either of you.
Brachina do not innately see invisible creatures.
Moore will check to see if he can tell if the door is locked from this side.
#283
Moore phases back to the other side.
He uses his artful magical skills to create a small replica of the room for Adrian to see.
He's using his SLA for major image to basically just make a tiny version of the room so Adrian can see what he saw.
EDIT: Excuse me, it's permanent image, but I'm pretty sure he can still just do the same thing.
Adrian sees it and nods tersely, 'We break in, free the hostages as I send a message for our forces out there to attack. We hold them off while they batter down the front. I need you to be a distraction while I cut through the barbazu guarding the hostages. Can you do that?'
