Boots on the ground (Moore)
"You cut that out." Moore says as he waves a hand again.
[22:38] <Nephrite> roll 1d20+20
[22:38] <Serith> Nephrite roll for Serith < 39 > [d20=19]
The tower shakes again as the glow sputters out. A few more cracks and a little more rubble falls, but nothing more. The door within is sturdy wood and firmly closed.
"Got magic that can handle that cleanly in case it's trapped?" Adrian asks.
Moore takes out his harp and strums it once, sending a sonic blast at the door!
[22:58] <Nephrite> roll 10d6
[22:58] <Serith> Nephrite roll for Serith < 37 > [d6=6,3,3,6,1,5,4,2,4,3]
Not sure it counts as brittle or not, doubt it does.
DC 29 Fort halves
The door cracks and splinters under your shout, though it doesn't go all the way.
> roll 1d20 1 check
<Serith> Kotono roll for Serith < 16 > [d20=16]
"I was more thinking like knock," Adrian says with a growing smile, a slash of Gaelach finishing off the door. It collapses inward, a kick after knocking the upper part aside and making a passage to within.
"Oh, I never quite mastered that one. Huh, I wonder if I could come up with a version that I could use... that'd be fun." Moore says with a sheepish smile. He flies in to look around!
Inside you find the first floor is - !!!
Coming ahead, blocking almost everything, is a massive creature of stone. A stone golem, you can tell that much from general time with Afina. Big enough that its head scrapes against the roof, the lumbering thing stylized as a man in armor without a weapon.
Init here.
[12:35] <Nephrite> roll 1d20+34
[12:36] <Serith> Nephrite roll for Serith < 37 > [d20=3]
Add 4 to that since I forgot Adrian's thing for 41.
> roll 1d20+25 Adrian
<Serith> Koaway roll for Serith < 27 > [d20=2]
> roll 1d20-2 golem
<Serith> Koaway roll for Serith < 13 > [d20=15]
Init is Moore (37) > Adrian (27) > Golem (13)
Go.
#100
I'm guessing between the free act and everything the songs have probably worn off by now, so, in that case...
"Really? This is all they've got?" Moore shakes his head. "Afina would be disappointed in this lot -- Adrian, let's show them we're still running hot!"
[12:56] <Nephrite> roll 3d4 nonlethal
[12:56] <Serith> Nephrite roll for Serith < 9 > [d4=3,2,4]
Inspire Courage, +14 to all the things Inspire Courage always gives things to.
Active Spells:  fortunate fate (CL15), planar tolerance (CL7), Superior Resistance (CL 24), Conviction (+4 saving throw), Tyche's Touch (+4 sacred saving throw), Haste (+1 ac, dodge, reflex, 30 move), surge of hope
HP: (26)289/311
AC: 56, 32 touch
24/25 Bardic music uses, Refrain 0/3
Spells:
0th - 7/7 (DC 21)
1st - 7/7
2nd - 7/7
3rd - 6/6
4th - 6/6
5th - 6/6
6th - 5/5
7th - 5/5
8th - 2/2
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 7/7
7th - 4/4
+1 Luck Bonus on Attack Rolls
Adrian simply holds position in front of the door, gesturing for the creature to come at him.
The golem lumbers forward, ground shaking as he walks. His long arms hang low, knuckles almost scraping across the ground. They come up, a pair of heavy strikes right at Adrian's chest.
> roll 1d20+42
<Serith> Koaway roll for Serith < 44 > [d20=2]
> roll 4d8+13 does not beat DR
<Serith> Koaway roll for Serith < 29 > [d8=6,3,2,5]
14 damage after that.
Adrian takes the blow with a grunt, giving up a single step before laying into the golem, leaping up to cut the golem right through the chest.
> roll 1d20+31 (+14 inspire courage, -15 PA)
<Serith> Koaway roll for Serith < 37 > [d20=6]
> roll 2d6+82+2d6+82+2d6+82+2d6+82
<Serith> Koaway roll for Serith < 354 > [d6=2,1,4,6,2,5,5,1]
In one stroke of Gaelach, the golem is cut from arm to arm. The upper chest and head of the golem fall away with a massive clatter of stone, while the rest of it takes a few steps forward before falling to the side.
Ahead is a large, empty room. There's a door on the far aside, and...
Free act, though I need Spot checks.
Adrian
HP: 344/358 (fast healing 1)
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Surge of Hope (CL25)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +4 morale to attack rolls, saving throws, ability checks and skill checks, immunity to fear, +4 morale saving throws, +4 sacred to saving throws, -1 each save
would you believe I'm going to take 10 for 45? Also he's going to maintain the Inspire Courage for now since he's pretty sure there will be more fighting.
> roll 1d20+38 Spot Adrian
<Serith> Koaway roll for Serith < 40 > [d20=2]
44, forgot Surge of Hope's bonus.
Anyway, you don't see anything so carry on.
#104
Oh, I did too. Oh well.
Moore casts a quick spell onto Adrian as he flies towards the door to open it! He's a brave soul, that one. He continues to murmur a quiet song to himself and Adrian about courage in the face of uncertainty.
Share Talents, Adrian and Moore get +2 on any skillcheck for the next few hours.
