Liber (Jaela, Moore)
Started by Anastasia, February 09, 2017, 02:33:24 PM
I am not. If conditions are such that It's obvious I'd need that kind of amplification then I can redo the standard action if allowed.
Yes, it's getting rather loud and apocalypsy out here.
Apocalypsy is a good word.
For the time being, Moore stays where he is and offers further support to his allies -- if he has to raise his voice louder, he will!
Standard action to cast Carrying Voice to improve his ability to be heard in the loud noises.
Inspire Greatness on himself, Sylvie, Mirajane, Jaela and Afina. This is 8d10 temp HP for all of them, +8 to attack rolls and +4 to fort saves, they are competence bonuses.
Finally he's using an immediate to activate his Badge of Valor, which increases Inspire Courage by 2.
This means that everyone should have a total of +14+2+8 to attack rolls, and 14+2 to damage rolls.
Inspire Courage is now at 10 rounds left.
Active Spells:  fortunate fate (CL15), planar tolerance (CL7), Superior Resistance (CL 24), Conviction (+4 saving throw), Tyche's Touch (+3 sacred saving throw), Harmonize (CL25), Greater Improvisation (CL25) (49 points left), Share Talents (CL25), Divine Insight, Surefooted Stride (CL25)
HP: (52)311+40/311
AC: 61, 32 touch
16/25 Bardic music uses, Refrain 0/3
Spells:
0th - 7/7 (DC 21)
1st - 4/7
2nd - 3/7
3rd - 2/6
4th - 6/6
5th - 1/6
6th - 3/5
7th - 5/5
8th - 1/2
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 5/9
3rd - 7/8
4th - 8/8
5th - 7/8
6th - 6/7
7th - 4/4
+1 Luck Bonus on Attack Rolls
[/spoiler]
Words of power are sent through the wind, voice projecting far louder than it should be. It's heard by all as...
Init is Afina (46) > Moore = Sylvie (38) > Jaela (36) > Spirit of Malice (33) > Mirajane (9)
Jaela.
Gripping Gae Dioltas's shaft tighter, Jaela decides to focus on finesse this time around. Too much strength lead her blow astray before, so now she focuses on making a cleaner hit!
[20:53] <@Rin> roll 1d20+43+1+5+1+2+14+2+8+2+3-10 divine might,10pa
[20:53] <Serith> Rin roll for Serith < 81 > [d20=10]
Forgot Mirajane's +4, so 85.
[20:54] <@Rin> roll 4d8+116+20+56+8+12+12+40+56+2d6+4d6 last is goldenfire
[20:55] <Serith> Rin roll for Serith < 360 > [d8=1,5,1,7][d6=5,6,2,4,4,5]
Anything to dispel?
[20:55] <@Rin> roll 8d10
[20:55] <Serith> Rin roll for Serith < 47 > [d10=2,2,9,9,9,3,7,6]
Temp hp.
Init +13
HP: 457+47/490
AC: 73 =65base+1AotDP(armor max dex +8)+2Foresight+5SoW, 20% miss chance (airborne creatures take a -1 penalty on attack rolls and damage rolls against you).
Full Attack (Gae Bolg, GMW, HW, K:D +5, CMT +1luck, CMT +2competence, HF +1morale/GH +4 morale, SofDP +2 attack/+3 damage, DM, vs devils only): +59/+54/+49/+44 or +63 AoO, 2d8+56+8d6+4d6 last is goldenfire
Spells Active: Energy Absorption CL 26, Create Magic Tattoo x2 CL 26, Elemental Body/Air CL 26, Surraruthru's Stupendous Dragonskin CL 26, Agility of the Dragon Princess CL 26, Strength of the Dragon Princess CL 26, Mind of the Dragon Princess CL 26, Stoneskin CL 26, Spell Turning CL 26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL25, Conviction CL29, Longstrider CL23, Divine Insight CL28, Lore of the Gods CL28, Mind Blank (CL26), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Righteous Halo CL28, Greater Heroism CL28, Tyche's Touch CL14 (+4 sacred to next save), Share Talents CL14 (+2 untyped to skills), Moment of Prescience CL23, Good Hope CL28, Shield of Warding CL28, Crown of Flames CL28, Mass Death Ward CL24.
Resistances and Immunities: Fire Immunity, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20, Damage Reduction 25/Epic and Evil and Cold Iron (10/Adamantium from Stoneskin), Spell Resistance 35 (45 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Never surprised or flat-footed/Foresight, Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Body (Air).
Spells Left (1-9): 8/9/8/1/8/5/8/2/7
Spells Left (10-11): 6/2
Saves: Fort +61, Ref +62, Will +61
-True Strike x3
-Turning x3
-Teleport x1
-Greater Teleport x1
-Moment of Prescience x2
-3 smite
-True Seeing component x1
-Stoneskin 120/150
Chain Dispel -> Gae Dioltas
Nothing to dispel and hit. Are you just making the one attack?
Since her strike didn't seem to bother their opponent too much, Jaela decides to set it on fire as an afterthought.
Swift for Flame Strike.
[21:12] <@Rin> roll 1d20+25 SR
[21:12] <Serith> Rin roll for Serith < 34 > [d20=9]
[21:12] <@Rin> roll 15d6+4d6 flame strike, goldenfire, DC29
[21:12] <Serith> Rin roll for Serith < 79 > [d6=6,5,4,5,4,1,2,5,5,4,6,3,6,6,5,6,1,4,1]
Divine Might 14/14 rounds
Init +13
HP: 457+47/490
-True Strike x3
-Turning x4
-Teleport x1
-3 smite
-Stoneskin 120/150
You hit - striking it deeply into it, your goldenfire spear making the spirit wail. A wail of sublime agony, shaking in place as your flame strike fizzles against it, consumed.
At the same time Sylvie positions as 21 is withdrawn, three profound words uttered as...
> roll 21d12+21
<Serith> Kotono roll for Serith < 163 > [d12=2,10,6,5,6,7,4,7,9,6,6,8,12,2,7,11,8,11,5,1,9]
> roll 1d20+30
<Serith> Kotono roll for Serith < 40 > [d20=10]/i]
Wounded from your strike, the spirit breaks apart and is completely dissolved in 21's light. But that doesn't stop the hail falling all around you.
Ref saves and then we'll go into free act after I resolve this. Reasonably tough but not a ton of HP by standards.
[21:23] <@Rin> roll 1d20+62+2 evasion
[21:23] <Serith> Rin roll for Serith < 83 > [d20=19]
[14:27] <Nephrite> roll 1d20+50 evasion
[14:27] <Serith> Nephrite roll for Serith < 64 > [d20=14]
[19:29] <@Ebiris> roll 1d20+44 evasion
[19:29] <Serith> Ebiris roll for Serith < 55 > [d20=11]
> roll 1d20+43 Mirajane
<Serith> Kotono roll for Serith < 45 > [d20=2]
> roll 1d20+51 Sylvie 11/3 inspiration fo rencounter
<Serith> Kotono roll for Serith < 69 > [d20=18]
No one's hit and you all have evasion, so free act for now.
"Back to Aurora until we see another!" Afina calls, heading back for the gates to get under shelter once more.
Jaela sees no reason to object, zooming towards the gates.
Moore will follow along with the others, continuing his words of encouragement and bolstering.
He'll just maintain Inspire Greatness for the foreseeable future.
