Salvation at last (Tryll)
Started by Anastasia, February 20, 2017, 04:07:59 PM
There's faint magic here - just the byproducts of what the dreadnought is more than anything else. You aren't sure about weakpoints, but it is just flesh, so enough force should tear it apart.
When in doubt, apply more damage!
Stygian Bolt, Twinned & Augmented
PP Cost: 25
Reflex save halves. Oh look, he can't. HAR.
He takes the following negative levels:
<Serith> Jubilant_Successor roll for Serith < 5 > [d4=1,3,1]
<Serith> Jubilant_Successor roll for Serith < 8 > [d4=2,3,3]
The entire beast's body turns gray from the inside out, weakening and paling. The creature shakes again before going still, no more disruptions.
Go ahead, act.
Right. Carapace preserved. Delightful. Tryll searches the area. Calleigh will know he's fine anyway. The familiar bond is still intact.
As noted there, a bunch of debris about as well as a few intact buildings. You could search it over in passing, which would be quick and most prone to failure. You could take some time and do it right, which is better but takes longer. Finally, you could really take your time and dig into searching it.
Might as well give the place a thorough sacking.
Cool. What's your take 20 total for search?
Alas, it's not a skill I possess. 31.
Oh yes, forgot to ask. Are you tallying everything or only valuables?
Valuables and magical items. DM is up, reminder. I'll pop True Seeing as well, just in case.
You find the following before being interrupted:
A coin pouch with 49 gold coins, 142 silver and 491 copper.
A gold ring.
A small bag with several uncut gemstones.
A somewhat damaged but intact dagger+2.
You barely get into it before light floods in. A hole in the side of the beast is carved open, "Tryll?" Rosa's voice, "Are you in here?" The silvery glow of the Astral flows in as Mei flies in, followed by Rosa.
'Yes! Be careful with the carapace! Very valuable, you know. Come on in, but mind the acid. How did things go?' Tryll asks, still sorting through abandoned stones and stacking things neatly.
"We overcame it. A powerful beast, but not one as powerful as us," Rosa says, as Mei does a general sweep, checking for threats. Rosa flies in your direction, "Fantase believes his vault is within, one of those buildings," Rosa grimaces, "The stench in here is remarkable."
'Really? I hadn't noticed. I've been stripping the place slowly. It really is quite remarkable. The size of this beast! Where's Calleigh?'
"Outside. She's fine," Rosa says, "Keeping an eye on Fantase too."
