Surraruthru and spellhoarding (Surraruthru)
Started by Anastasia, February 22, 2017, 02:44:16 PM
Depends on what it is. It also lets me ID the spells with a +5 bonus, so that first.
> roll 1d20+37+5 Spellcraft
<Serith> Iddy roll for Serith < 60 > [d20=18]
Surraruthru can tell it's an empowered orb of force.
Surraruthru smirks at the Red Dragon, letting the spell hit him and relying on his Spell Turning to deal with it.
The orb flies - and hits your defense, going right back at him.
> roll 1d20 touch AC, he's a dragon so this is only missing on a 1
<Serith> Space_Cat roll for Serith < 1 > [d20=1]
By a sheer fluke the orb somehow misses him, going off errant entirely. The dragon growls as your spell turning holds, then...
Go.
#259
Surraruthru chuckles in amusement at the failed spell, obviously mocking the larger dragon, and uses his boots again before casting a spell.
Teleporting behind him at 110ft, to try and break line of sight before casting again. And since it worked so well last time:
Spell Turning, CL 33, 330 minute duration
On a different note, can Surraruthru tell what kind of space this is? As in, can he tell if it's a mental bubble or something? Intent is to find out if Gate would allow me to try and get someone in here to help.
Surraruthru
HP: 126/347
AC: 70=38+4+20+1+7 (Deflection/EMA/Dodge/MotP(NA))
Init: +13, Touch/Atk: 38/42+5
Active: Epic Mage Armor (CL26), Superior Mighty Wallop (CL26), Greater Heroism (CL26), Elemental Body: Fire (CL26), Might of the Planetar (CL26), Battlemagic Perception (CL5), Spell Turning (CL33)
> roll 1d20+41 K:A
<Serith> Iddy roll for Serith < 53 > [d20=12]
It's a sort of soulscape. You aren't escaping without winning this battle.
That's what I figured. In any case, I both moved and cast, so it's Red's turn.
The dragon whirls around, sees you and does what is natural - charges you head on, snarling in fury.
> roll 1d20+59
<Serith> Space_Cat roll for Serith < 65 > [d20=6]
Miss! You see the dragon coming and utter a word of overwhelming arcane power. It pushes the dragon back, maw mere feet at you but briefly held in check.
Go.
#267
Surraruthru snarls at the larger Red Dragon before launching himself at its face, intent on ripping its eyes out, and the upper half of its skull with it, if he can!
> roll 1d6 Flailing Strikes
<Serith> Iddy roll for Serith < 4 > [d6=4]
> roll 1d20+38+9 Unarmed
> roll 1d20+35+9 Unarmed
> roll 1d20+28+9 Unarmed
> roll 1d20+23+9 Unarmed
<Serith> Iddy roll for Serith < 61 > [d20=14]
<Serith> Iddy roll for Serith < 57 > [d20=13]
<Serith> Iddy roll for Serith < 55 > [d20=18]
<Serith> Iddy roll for Serith < 44 > [d20=12]
> roll 1d20+28+9 Bite
> roll 1d20+28+9 Claw
> roll 1d20+28+9 Claw
> roll 1d20+38+9 Slam
<Serith> Iddy roll for Serith < 43 > [d20=6]
<Serith> Iddy roll for Serith < 49 > [d20=12]
<Serith> Iddy roll for Serith < 54 > [d20=17]
<Serith> Iddy roll for Serith < 66 > [d20=19]
> roll 1d20+38+9 Flailing Strike
<Serith> Iddy roll for Serith < 55 > [d20=8]
<Serith> Iddy roll for Serith < 58 > [d20=11]
<Serith> Iddy roll for Serith < 67 > [d20=20]
<Serith> Iddy roll for Serith < 56 > [d20=9]
> roll 1d20+38+9 Flailing Strike#3 Crit Confirm
Unarmed Damage:
Note: +1 Con Damage per Hit
> roll 7#6d10+15+5 (Unarmed)
<Serith> Iddy roll for Serith < 55, 66, 70, 56, 47, 44, 43 >
> roll 12d10+30 (Flailing Strikes Crit)
<Serith> Iddy roll for Serith < 112 > [d10=3,5,9,7,9,9,7,7,6,9,6,5]
> roll 1d6+15+5 (Bite)
<Serith> Iddy roll for Serith < 26 > [d6=6]
> roll 2#1d4+15+5 (Claw)
<Serith> Iddy roll for Serith < 21, 21 >
> roll 2d8+18 (Slam)
<Serith> Iddy roll for Serith < 27 > [d8=7,2]
Edit: It was supposed to be 1d6-1 for Flailing Strikes, so remove the last attack string:
And remove the last damage value for non-crit Flailing Strikes which was 43 total. Total below is recalculated.
Totals if everything hits: 475 +10 Con damage. (Note: Not counting Slam in Con damage as it's not specifically covered by the wounding item)
Surraruthru
HP: 126/347
You dive in, full steam.
Rip.
Tear.
Blood.
You go into dragon's skull and then brain, an otherworldly flurry of attacks that cause the dragon's entire body to wither. With all your magic you plunge your claws into its gray matter, causing reality to shake and abruptly - !!!
Congratulations, you finished off the wounded dragon. I'm going to pause you until this evening, which at that point we'll go over the after effects of this and how your ritual went.
Okay, one more time, refresh me on the goals of your transformation?
