To defeat a daemon (Jaela, Afina)
Started by Anastasia, March 02, 2017, 03:19:47 PM
I bet you could breathe a water elemental!
First of all, what ioun stone are you using, Jaela?
As written, it sounds like it doesn't provide as as much as keeps you going without it. Useful for Mirima or Bubbles here obviously, but not an actual air source.
To Afina - there's some gases, yes. They don't seem to be transmitting sound, it's probably wizardly bullshit of some manner.
Can you breathe an air elemental? A willing one who allows it, yes. Otherwise they're too violent and fast moving to, the pressure difference wouldn't work out. In a normal situation this wouldn't deal any damage since they'd naturally recover air. In this situation, in a vacuum without air? They'd take steady damage from it.
Yes, air is integral to Air. A planar bubble cast on a native of Air would do that. Most other planes it wouldn't work with, but having actual air is 100% critical for Air to mean anything.
Afame isn't helping, so it's environmental rather than innate traits.
Holding up a finger for patience, Afina first calls upon air elementals to answer her bidding while also using her control over wind to sweep away the acidic fumes before they can get near anyone.
Elemental Swarm (Air) SLA used
[18:05] <@Ebiris> roll 2d4 large air elementals
[18:05] <Serith> Ebiris roll for Serith < 4 > [d4=3,1]
Control wind is still up and being used for acid fume clearing duties
Four answer her call, though they're immediately stricken by the environment here. Afina thankfully possesses the means to mitigate that as she flies in towards one of them and uses its own body as a medium to transmit the verbal components of her next spell which produces a bubble of Air all around it for ten feet. "Get in close to the elementals," she instructs as breathable air is provided. it's still cold, but she fixes that next by making a bubble of warmth around herself.
Casting Control Temperature next. I can increase the temperature by 5 bands, presumably we're below 'unearthly cold' right now. Assuming that just counts as one band I could get us up to moderate. If it's two below unearthly I could get us to merely cold which is just a small fort save per hour or take some nonlethal damage.
That's 3 rounds worth of actions there for the persistent damage and any stuff that might butt in part way
Afina: 303+20/303, glaciante's spiteful ward (CL 27 attached to epic mage armour), heroes feast (CL 23), epic mage armour (CL 25), moment of prescience (CL 25), control winds (CL 25), fortunate fate (CL 28), good hope (CL 28), death ward (CL 28), shield (CL 25), greater heroism (CL 25), resist energy (Acid) (CL 25), control temperature (CL 25)
AC 96, spell resistance 40, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, negative energy
Spell charges: 6/9/9/9/7/9/8/7/6/8/6/1
> roll 5d6 1
> roll 5d6 2
<Serith> Space_Cat roll for Serith < 21 > [d6=3,2,6,4,6]
<Serith> Space_Cat roll for Serith < 23 > [d6=4,3,6,4,6]
> roll 5d6 3
<Serith> Space_Cat roll for Serith < 19 > [d6=1,3,6,6,3]
Cold damage.
Warmth returns - warm but not overly so as Afina finishes. Just in time as you can all breathe.
"Ugh..." Bubbles gasps, "Dears, I think this yugoloth is a dreadful host!"
As you do this, you can see them emerge from the gaps in the frozen acid. Bloated green zombies, wretched things that drip and sizzle with acid. One, three, six, ten...more! They're coming up all around you.
"Well," Mirima draws her blade, taking a breath, "It seems we'll have to make a proper entrance."
Init here.
Mirima
HP: 241/307
Spells Active: Heroes Feast (CL23), Fortunate Fate (CL28), Mass Death Ward (CL28), Good Hope (CL28), Greater Mage Armor (CL9), Resist Energy (Acid) (CL25)
Bonuses: +1 morale attack and will, immunity to poison and fear, +2 morale a bunch of things, resistance to acid 30.
Bubbles
HP: 218/279
Spells Active: Heroes Feast (CL23), Fortunate Fate (CL28), Mass Death Ward (CL28), Good Hope (CL28), Resist Energy (Acid) (CL25)
Spell like abilities
1/day-scorching ray. Caster level 24th. The save DCs are 20 + spell level.
Mirima casts as a 9th level sorcerer. The save DCs are 20 + spell level.
[6/day]0: Acid Splash, Detect Magic, Detect Poison, Mage Hand, Mending, Message, Prestidigitation, Read Magic, Resistance.
[9/day]1: Endure Elements, Fist of StoneSC, Magic Missile, Shield, Weapon ShiftSC.
[8/day]2: False Life, Ray of WeaknessSC, Resist Energy, Whirling BladeSC.
[6/day]3: False GravitySC, Fly, Greater Mage ArmorSC.
[7/day]4: Greater Invisibility, Orb of Force
[5/day]5: Wall of Force
SC - Spell Compendium.
Spell-Like Abilities
At will-dimension door. Caster level 22nd. The save DCs are 18 + spell level.
Bubbles casts as a 24rd level druid. The save DCs are 17 + spell level.
[6/day]0: Creater Waterx3, Cure Minor Woundsx3
[7/day]1: Cure Light Woundsx7
[7/day]2: Barkskinx7
[7/day]3: Corona of ColdSC, Neutralize Poison, Poison, Protection from Energyx3, SinkSC
[7/day]4: Control Water, Flame Strikex2, Planar Tolerancex3SC, Rusting Grasp
[6/day]5: Cloak of the SeaSC, Panaceax3SC, Wind Tunnelx2SC
[5/day]6: Antilife Shell, Extract Water Elementalx3SC, Tortoise ShellSC
[5/day]7: Animate Plants, Aura of VitalitySC, Control Weather, Creeping Doom, Heal
[5/day]8: Bombardmentx2SC, StormrageSC, Sunburst, Superior VigorHome
[4/day]9: Greater WhirlwindSC, Phantom Bearx2SC, UndermasterSC
[3/day]10: Mass Healx3, Telay's Ice HorrorHome
[1/day]11: Fog TrapHome
[/quote]
[/quote]
[18:20] <@Ebiris> roll 3#1d20+11 elemental init
[18:20] <Serith> Ebiris roll for Serith < 26, 28, 19 >
[18:20] <@Ebiris> roll 1d20+30 Afina init
[18:20] <Serith> Ebiris roll for Serith < 39 > [d20=9]
Elemental 1: 18/60, planar bubble (CL 25)
Elemental 2: 18/60
Elemental 3: 18/60
[20:21] <@Rin> roll 1d20+17
[20:21] <Serith> Rin roll for Serith < 31 > [d20=14]
Init: +17
HP: 490+13/490
AC: 72 =65base+2Foresight+5SoW, 20% miss chance
Full Attack (Gae Bolg, GMW, HW, K:D +5, GH +2 morale, vs devils only): +51/+51/+46/+41/+36 or +57 AoO, 2d8+42+8d6+4d6 last is goldenfire
Spells Active: Spell Turning CL 24, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL25, Conviction CL29, Divine Insight CL28, Lore of the Gods CL28, Fortunate Fate CL28, Heroes Feast CL23, Righteous Halo CL28, Moment of Prescience CL23, Mass Death Ward CL28, Moment of Prescience CL23, Foresight CL25, Sign CL28, Good Hope CL28, Shield of Warding CL29, Vision of the Omniscient Eye CL28, Invisibility Purge CL28, Acid Resistance CL25, Cold Resistance CL29.
Resistances and Immunities: Fire Immunity, Cold Resistance 30, Acid Resistance 30, Electricity Resistance 20, Sonic Resistance 20, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 35 (45 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, 140ft radius invisibility-busting aura.
Spells Left (1-9): 5/6/7/5/9/8/4/5/8
Spells Left (10-11): 7/4
Saves: Fort +62, Ref +61, Will +62
-Longstrider
-Foresight x1
-Spell Turning
-Moment of Prescience x2
-Heroes's Feast
-MV x2 (gauntlets)
-GMW x1 (gauntlets)
> roll 1d20+11 Mirima
<Serith> Space_Cat roll for Serith < 13 > [d20=2]
> roll 1d20+13 Bubbles
<Serith> Space_Cat roll for Serith < 30 > [d20=17]
> roll 1d20+5 zombies
<Serith> Space_Cat roll for Serith < 12 > [d20=7]
Init is Afina (39) > Jaela (31) > Bubbles (30) > Elemental 2 (28) > Elemental 1 (26) > Elemental 3 (19) > Mirima (13) > Zombies (12)
Go pixie.
#159
"These elementals aren't strong, make sure they don't get hurt," Afina warns, hasting her allies as is her wont and then just making everything nice and fiery around her as she flies around within the bubble provided by her air elemental.
Gift of Fire SLA, all allies weapons gain the flaming burst property, all enemies take damage. 30 foot radius.
[18:41] <@Ebiris> roll 15d6 fire damage, no save no SR
[18:41] <Serith> Ebiris roll for Serith < 64 > [d6=6,2,3,1,6,6,5,5,5,6,1,2,5,5,6]
Flaming burst lasts for 20 rounds.
Afina: 303+20/303, glaciante's spiteful ward (CL 27 attached to epic mage armour), heroes feast (CL 23), epic mage armour (CL 25), moment of prescience (CL 25), control winds (CL 25), fortunate fate (CL 28), good hope (CL 28), death ward (CL 28), shield (CL 25), greater heroism (CL 25), resist energy (Acid) (CL 25), control temperature (CL 25), haste (CL 25)
AC 97, spell resistance 40, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, negative energy, 50% miss chance, freedom of movement
Spell charges: 6/9/9/8/7/9/8/7/6/8/6/1
Elemental 1: 18/60, planar bubble (CL 25), haste (CL 25)
AC 21
Elemental 2: 18/60, haste (CL 25)
AC 21
Elemental 3: 18/60, haste (CL 25)
AC 21
How long does flaming burst last?
Mirima
HP: 241/307
Bubbles
HP: 218/279
[/quote]
[/quote]
[/quote]
As I see in your previous post. That's what a natural 1 on a Spot check looks like.
The innermost zombies explode, immolated and bursting like giant sacks of acid. There's more coming up and more from a distance, however, even if that bought you some room.
Jaela.
"I'll draw them off," Jaela says, tapping her head where a crown of flames appears. "Follow me when you can, let's explore this crappy place."
Then, she advances past the cleared zone to burn and strike any of them who are in her way!
Crown of Flames, moving 40ft. Gambit. I'll return any AoOs that might go my way.
[21:09] <@Rin> roll 2d6+4d6 goldenfire
[21:09] <Serith> Rin roll for Serith < 23 > [d6=1,5,2,6,5,4]
Init: +17
HP: 490+13/490
Spells Active: Spell Turning CL 24, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL25, Conviction CL29, Divine Insight CL28, Lore of the Gods CL28, Fortunate Fate CL28, Heroes Feast CL23, Righteous Halo CL28, Moment of Prescience CL23, Mass Death Ward CL28, Moment of Prescience CL23, Foresight CL25, Crown of Flames CL28, Good Hope CL28, Shield of Warding CL29, Vision of the Omniscient Eye CL28, Invisibility Purge CL28, Acid Resistance CL25, Cold Resistance CL29.
Spells Left (1-9): 5/6/7/5/8/8/4/5/8
-Longstrider
-Foresight x1
-Spell Turning
-Heroes's Feast
-MV x2 (gauntlets)
-GMW x1 (gauntlets)
Jaela positions, burning with flames as the zombies crawling up ignite. It isn't enough to do them in, as Bubbles nods and stands guard over the elementals for the moment.
She's holding for the second, she'll take further action once the elementals do their thing. Go elementals.
