Now where am I?! (Moore)
A bare miss. You dodge at the last second, avoiding the blade as it hits the ceiling and falls to the ground, a broken wreck.
Whoops, I said 47 and meant 57. Oh well.
Moore blinks a few times. "Are you all right, Ilsenine?"
"I'm unhurt," Queen Ilsenine replies, "You as well?"
"Quite. I think that was the guillotine from before..." He makes a mental note of this as well as he takes stock of the new room.
This new room is a rough square, nothing remarkable. There are passages to the north, south east and west. In the southwest corner is a pentagon and a sphere of stone, both set into the watery wall.
Moore will fly over to touch the pentagon!
You touch the pentagon. Another dagger appears as the pentagon crumbles to dust.
A moment later, the sphere glows and does the same.
[blockquote]Rolled 1d100 : 19, total 19[/blockquote]
More in the next post. Once reason I don't like using these on the DM end is because I don't see the results so I have to partition posts.
Gah! Fire loops around you, a wall of it surrounding you on all sides.
[blockquote]Rolled 1d20+15 : 17 + 15, total 32[/blockquote]
Which does nothing at all, the flames ceasing when they come too close to you.
Act.
Moore shrugs and tries to put the fire out with some magic!
He's trying to use Create Water to just douse it. He gets... 28 gallons, but I'd imagine he doesn't need to use all of it if it's actually working.
This does so easily enough.
"Moore, are you hurt?" Ilsenine races to you once the fire's gone.
"Not even a singe." He says as he gestures at his clothes. "It didn't... seem to do anything, it just surrounded me. Quite peculiar."
He analyzes this +1 magical bane dagger and puts it away.
"So Spheres are... some sort of trap?" He scratches his cheek. "I guess we'll have to try again when we see them."
It is a dagger+1, giant bane.
"Curious," Ilsenine says, "There seems to be a logic to this place, at least."
Moore will put that new dagger away. "Well... hm... four cardinal directions... Let us try south." He says as he heads south!
You head south. This leads into a small, compact room with only a door north. Sitting in the back of this room is a statue of a rust-red, four legged beast with long, frilly antennae. On the creature's forehead is a slot to put something in, something narrow.
