Now where am I?! (Moore)
Ilsenine considers a few moments and then nods, "No, you're right. Lead on," she says.
"I want to at least see what we can find on this floor... but I think... I have a feeling that the squares and lines don't create passages to different floors, just alternatives on the same floor. What I don't know about is the hexagon. That might be like a pentagon, but... better? I suppose we'll have to find out. This is fun, if not exactly an ideal date, though." Moore says with a chuckle as he goes out and north.
"I can accept it if we go back rich enough to make this worthwhile," Ilsenine agrees as you go on.
As you enter this room, you hear the sound of laughter, far away. It gives you goosebumps.
There are passages to the north and west here, as well as a hole in the ceiling to go up if you wish.
A stone pentagon, hexagon and sphere are set into the floor here.
"Promise me you'll try and convince Lady Skye not to kill me in my sleep?" Moore asks with a smile.
Hmm, another pentagon, but... they have to find a hexagon alone -- they can backtrack if they need to. Moore will continue north.
This is a plain room with but one thing - an actual stairway of water, leading up a gap in the ceiling to the next floor.
Also, a stone dot and a stone sphere are embedded into the ground.
"I think the dot... mm." Moore rubs his chin, thinking back to the triangle and dot. "I think... this opens a passage or changes ones that we've visited."
He touches the dot stone!
You touch the stone dot, which crumbles away.  The passage back south begins to glow.
Then the sphere crumbles away.
> roll 1d100
<Serith> Kotono roll for Serith < 1 > [d100=1]
Nothing seems to immediately happen?
"...Time-delayed traps?" Moore wonders aloud as he turns to go back south.
"I don't have the foggiest," Ilsenine admits.
There is still an unexplored passage west here, as well as a pentagon, hexagon and sphere.
"Maybe some of them just don't do anything." Moore says as he now goes west!
This room is curved all the way around, gentle slopes to its walls and a slight lean to them.
There's no passages here, a dead end.
A pool of water is built into the floor, surrounded by a 'tub' of stone.
A triangle, pentagon and sphere are laid into the floor just past the pool.
Moore raises an eyebrow and goes over to the water to investigate!
Spellcraft for 49
The pool is enchanted two fold. The first enchantment is healing - those that bathe within it will heal. The other is a mild charm effect, that will make anyone in the pool more romantically interested in the others in there.
Moore can't help but just laugh.
"Ilsenine, you really should see this for yourself." Moore says as he backs away slightly.
Ilsenine kneels and studies the water, before going quite still.
She takes 10 on Spellcraft.
"I see," her voice is like ice, "More, you know planar lore better than I. Do slaad have the proper bits to be unmanned? There can be no other punishment for expecting me to behave as a common trollop for entertainment."
