Now where am I?! (Moore)
[13:29] <Nephrite> roll 1d20+4 just had to be a strength check
[13:29] <Rei-chan> Nephrite rolled : 1d20+4 just had to be a strength check --> [ 1d20=11 ]{15}
> roll 1d20+3 Ilsenine does not care for strength checks
<Rei-chan> Koaway rolled : 1d20+3 Ilsenine does not care for strength checks --> [ 1d20=10 ]{13}
It's too strong - you're being sucked in if slowly, about halfway down to it as both of you are dragged closer. You still have time to act, Ilsenine biting off a rather uncouth curse as...
Go, it's not fast enough to grab you and pull you the entire way in one round.
Moore grabs hold of Ilsenine and tries to teleport them both ahead!
He's trying Dimension Door since it seems teleportation effects work here (but he's guessing planar ones don't) - -he's going to try and get them 1400 ft ahead of the vortex.
The two of you step through the conjured door, appearing far above. You can see forest for miles and miles all around, slowly crumbling away into an ever growing void below.
"Whew... I'm not exactly sure what we do from here." Moore admits. "I have a feeling it'll eventually reach up here... Maybe we should just go up, then?"
"I believe it beats going down," Ilsenine agrees, "Shall we?"
Moore nods. He then takes her hand and begins to rise!
"Seems like a rather extreme way to start over with a clean slate for something like this, if you ask me." Moore says.
What's your movement speed, matters here.
The two of you fly up and away - and as you do, 30ft away on either size, great yawning black portals appear, swirling and sucking at the two of you.
"More? What mad game is this?" Ilsenine gasps, as...
Strength checks again.
[14:06] <Nephrite> roll 1d20+4 just had to be a strength check again
[14:07] <Rei-chan> Nephrite rolled : 1d20+4 just had to be a strength check again --> [ 1d20=6 ]{10}
<Rei-chan> Koaway rolled : 1d20+3 Ilsenine does not care for strength checks --> [ 1d20=16 ]{19}
Ilsenine manages to fly up and away, but you're stuck. The only saving grace is that you're pulled between them, back and forth rather than going all the way into one.
"Moore!" Ilsenine calls down, as...
Go.
"If you're done with us then just put a door in front of us to go through!" Moore shouts.
Another Dimension Door to nearby where Ilsenine is.
[14:41] <Nephrite> roll 1d20+55
[14:41] <Rei-chan> Nephrite rolled : 1d20+55 --> [ 1d20=3 ]{58}
