Surraruthru's Tree (Surraruthru)
Started by Anastasia, March 29, 2017, 11:03:08 PM
Surraruthru turns to the bear, "Do you want to try some rations? Kascha wants you to have some."
"You have food? Give me food," The bear says, "Food now."
Can I do that in this form or do I need to shift or have Kascha do it?
The item in question would've merged in when you changed shape, so you'd need to change.
Surrurarthru shifts back into his original form and reaches into his pack, pulling out his bag of rations and dumping a serving out.
The bear growls low at the transformation, but food gets his attention. He approaches and sniffs it before starting to eat.
Surraruthru mostly ignores the bear and starts moving on towards their goal.
The arch is ahead - just as planned. Pearwood says, "This will take us to Brux, and from there we'll need to find passage to Karasuthra."
Surraruthru nods. "Let's get going, then."
You step through into a forest at dusk. Long shadows frame everything and reddish sunset light spills through the canopy above. It's a little cooler here, the air tinted by a faint mist.
"Hm. Should I fly up and get an idea of where we are, or do you know the way Pearwood?"
"Not terribly well," He says, "It will take time. Be careful of aerial predators if you go up," He warns.
Surraruthru nods and hops into the trees, using a combination of leaping and flying to get the top of the canopy, taking a moment to survey the skies for any threats before going higher to see the land.
It is an endless forest of trees at sunset. You can see a crescent moon in the sky, semi-visible as darkness falls. The trees stretch as far as you can see in every direction.
Surraruthru launches himself into the sky, intent on doing a fast survey before watching for predators.
