Surraruthru's Tree (Surraruthru)
Started by Anastasia, March 29, 2017, 11:03:08 PM
You have one round as people rush in and get ready to gate. Cast what you will during it.
Surraruthru realizes the pace of the deployment operations and knows he won't have enough time to cast what he needs...
... So he'll just make more time.
Casting Time Stop. CL 26.
> roll 1d4+1
<Serith> Iddy roll for Serith < 4 > [d4=3]
Cool, you have 4 rounds. What are you doing with them?
#618
I'm going to assume there's no time for including others into the tapestry since that takes 10 minutes IIRC, so I'm going to cast these and go with just Kascha, Simmer, and myself unless you say otherwise.
Surraruthru idly looks around at the suddenly frozen people and begins casting spells.
Casting these spells into the Tapestry as Quiescent Weaving:
Level 7:
Energy Absorption: (Complete Mage, p. 103), CL 26, Duration 26 hours/expended
The subject gains resistance 10 against all five energy types: acid, cold, electricity, fire, and sonic. As an immediate action, the subject can cause the spell to absorb the power of a single energy-based attack. The subject gains immunity to any energy types used in that attack (but only for that attack) and also heals a number of points of damage equal to 1/2 the damage the effect would normally have caused.
Elemental Body: (Spell Compendium p. 78), CL 26, Duration 26 hours
You have the benefits of the attune form spell (page 17) with respect to the appropriate element. If you choose a water body, for example, you can breathe normally on water-dominant planes.You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking. You gain darkvision out to 60 feet. Your creature type remains unchanged, so you are unaffected by spells that target elementals, but you gain the air, earth, fire, or water subtype depending on the elemental substance you chose.
Level 8:
Cool.
As time resumes, people rush to Aruroa's gates. Balyss, Sage Vul'lath, Cresiel. Others are just behind them, 27 hopping up and down. "Aim there there there," he points, "Do it!"
Surraruthru follows the others with Kascha and Simmer in tow.
"Kascha, Simmer. Stay in spell range with me. I have some spells in mind for when we hit the ground to make close combat against us rather painful for others. I've given you both flight movement, too. I think we should focus on being a fast strike and response group, unless the ground commanders have other ideas for us."
Wasn't planning to. I'll use whatever ones are opening.
Portals open as Moore rushes up, along with Jetina, "Go," 27 demands, "Portals! Hurry and keep them open!"
Moore shakes his head, no choice but to help out!
He could stop time, but... for now...
Three standard actions, the first on Sonorous Hum, which will then maintain one of Moore's Gates for him, then he'll open a second on his own and maintain it that way.
Surraruthru activates the spells he loaded into the Tapestry and heads through, looking for targets for either rescue or destruction!
It is a crevice, a vast crack in the earth. Here people are held in little broken cells or chained to walls, hundred of feet long and deep. Prisoners all around, hundreds of them spread out and cheering. You can see Jaela, Afina and their forces as...
Let me know how you're going to try and rescue them, Surru.
"Simmer, I assume you can melt through those chains and locks? If so I'll cover you while you free the prisoners, Kascha direct and control them. I'll run interference and watch for threats. Stick close and be ready to refocus as offense. Afina and Jaela are fighting, I'll message them and see if they need us to move off of rescue duty."
Saying so, Surraruthru begins casting a spell while pointing at Jaela, sending a message, "Jaela, reinforcements are here. This is Surraruthru with Kascha and Simmer. We're moving to rescue prisoners, inform us if you need us elsewhere."
Okay, room merging time. This topic's locked. I'll take care of any pasting.
