Refugees (Moore)
Started by Anastasia, May 26, 2017, 02:40:14 PM
"Coming," Canderella calls, sauntering over.
"Yeah, I bet she says that a lot." Dana mutters under her breath, readying her shield and rapier at the same time.
Moore can't help but grin at that comment and then he nods to Candy. "All right, I'm not entirely sure where we'll end up when we go there, but hopefully it'll be close enough to the others. Oh!" He snaps his fingers. "Elena, can you get Tepen or someone else to cast the inter-planar telepathy spell on us? Just to be safe."
Elena pops in, "He's coming, he's coming," Elena says, then pops out.
"Oh, how simple." Canderella says, "What's the complication?"
"What, with us going?" Moore asks.
"Yes," Canderella says as you see Moonlight sprinting across the courtyard, red hair vibrant in the light of Elysium as she races over. "You called," she says, skidding to a stop.
"We're going to Lifasa to make sure everyone else gets out. I... had a premonition that Bel was going to attack Aurora." Moore explains. "Now that he can't, he may turn his attention to Lifasa to capture everyone that's there right now. We're going there to hopefully meet up and get out."
Moonlight takes a deep breath, "Lathander," she breathes, "No time to waste then, let's go!"
"Yeah!" Dana hefts her shield, "Let's go kick some devil ass so hard that Asmodeus thinks he's getting assfucked!" She grins ear to ear, "Maybe this asshole will be a worthwhile fight."
Go ahead, Moore. Where are you aiming for?
Since Adrian (I think, maybe it was Gisfal) mentioned Jaela's teleport block, what would he know about that? His intention is to get them basically nearby where all the refugees were coming from -- i.e. where they opened the gates to last time.
Roughly, you'd know a teleport block somewhere akin to 1/5th to 1/4th of a mile in radius.
Then he'll just go as close to that as they can go -- would Greater Plane Shift suffice if the coordinates are basically 'as close as possible to where the gates were'? Or can I use Jaela as a target?
If not then we'll just have to wing it as best we can.
You've visited that location, so yes. Of course, if Jaela's block is still up, you'd be blocked. Your call if you want to try.
Let's try it. Moore will use Greater Plane Shift.
Nothing happens. Planar magic's being blocked, most likely.
He nods. At least that means the devils can't do the same.
He will try again approximately 1/4 of the mile away from that location in a westerly direction.
Opening a portal with your own magic or Aurora's gates?
