Hell conference (Moore, day 87)
Started by Anastasia, July 12, 2017, 04:20:21 PM
Moore will set the small plate down first nearby.
"I need to go to Smoke tomorrow and... deal with some things. I was wondering if you knew of any contacts we have there. If not, I can just try and divine some more specific directions." He explains to take a small beat. "Ah... I was given a name if that helps narrow things down any: Sarem Dizal, if that rings any bells? I hadn't checked the library yet to see if they were a notable figure."
"Thank you," Morniel takes the plate and has a bite before anything else. He listens afterwards.
> roll 1d20+54
<Rei-chan> Kotono rolled : 1d20+54 --> [ 1d20=13 ]{67}
"I know some from Smoke, but do not know that place," Morniel says. "Or name, I assumed it was a place."
Moore snaps his fingers. "You're right, it is a place, not a person. Apparently it's a lot like the place on Earth that we found where the devils had a base."
"I do not, but I can ask," Morniel says, "It  may also be a new location or base, if you suspect it to be such. The name may mean nothing because it's too new to be known."
Moore nods. "I will check the library as well and let you know what I discover. It seems Someone," at this he makes a gesture up above his head, "Doesn't want me to get too and get more sleep than I need." He laughs a little at that.
"There's time to rest in Paradise," Morniel says with his own smile, "Draw on magic to resolve your sleepiness short term, if you must."
"It's fine. Somehow or another I'm used to this. I'll see you soon. Thanks, Morniel." He offers a bow and heads to the library!
His intent is to research Sarem Dizal and see if he can find anything out ahead of going there directly.
You find nothing. After a few hours, you're even more tired and you're pretty sure there's no leads here. It's just not a term you can find anything on.
Huh. Well then, it's time to do some more direct research -- by praying to the right people!
He'll pull himself up and sluggishly go to the Temple to Mount Celestia for some knowledge.
The idea is to cast divination, as in the spell. I will post the gold cost once I get done with all of these.
First question: "Can I gate to Sarem Dizal?"
Next question!
"How can we get to Sarem Dizal?"
I forgot to mention his chances are 88%.
Your answer is this: Follow the Choking Path.
Take 10 for 79, does he know what that is?
