> roll 1d20+30
<Serith> Kotono roll for Serith < 43 > [d20=13]
Flatfooted AC, Surru? Note if you have uncanny dodge.
Flat footed AC: 57, no uncanny dodge.
Surraruthru
HP: 413/413 (359 base)
AC: 52+4 (Deflection)
Touch AC: 24, Flat Footed: 57, SR: 37, CMB: 33, CMD: 51
Init: +12, Touch Atk: 38
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Bibliotheca Arcana (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL28), Epic Mage Armor (CL28)
Passive: True Seeing, Detect Magic, +15 to knowledge checks
Kascha
HP: 359/359 (305 base)
AC: 63
Touch AC: 47, Flat Footed: 57, SR: 38, CMB: 33, CMD: 61
Init: +14, Touch Atk: 31
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL28)
Passive:
I'm sorry, flatfooted TOUCH AC. My fault there, forgot an important part of that.
15 in that case. Does SR apply?
Surraruthru
Touch AC: 22, Flat Footed: 55, SR: 37, CMB: 33, CMD: 51
Kascha
AC: 63
Passive:
> roll 4d8+15
<Serith> Kotono roll for Serith < 31 > [d8=5,6,1,4]
It does not. Do you have DR that applies?
I dunno. You haven't said what it is. This is the DR I have, though:
Damage Reduction 10/Magic, Resistance 10 to Acid/Cold/Electricit, and DR 10/Magic from Dragonskin spell.
Doesn't apply, okay.
As you walk a head, a solid stone arm comes smoothly up from the ground, punching Surraruthru in the leg. It huts considerably, a crack of bone giving way as you see the arm flicker, semi transparent as it sinks back down into the ground.
Act y'all, I'm sure you can come up with ideas to deal with this.
Surraruthru snarls in response and pulls on his draconic power, casting a spell at the floor where it came from.
For posterity:
<Kotono> > roll 4d8+15
<Kotono> <Serith> Kotono roll for Serith < 31 > [d8=5,6,1,4]
Disintegrate, CL 18. Touch attack for creature, otherwise it just destroys 10 cu. ft. chunk.
> roll 1d20+38 Touch Attack
<Serith> Iddy roll for Serith < 55 > [d20=17]
> roll 36d6 Disintegrate
<Serith> Iddy roll for Serith < 99 > [d6=2,3,1,2,6,5,4,3,1,3,2,1,1,3,5,2,1,6,2,1,6,1,2,1,4,5,1,4,4,2,1,1,3,1,3,6]
Surraruthru
HP: 382/413 (359 base)
Kascha
AC: 63
Passive:
A hunk of the floor disintegrates, revealing the upper body of what looks like a stone statue. Yet it moves smoothly, slowly sinking down deeper into the intact stone as...
Chance for everyone else to act since Surru revealed it.
Knowledge: PSionics, is that a golem?[blockquote]Rolled 1d20+44 : 17 + 44, total 61[/blockquote]
It appears to be a stone construct of some kind. It's too small to be a normal stone golem, and most aren't ethereal like this one appears to be, either.
You'd suspect it's a custom construct rather than a true golem. On the other hand, that means you don't have to worry about a golem's immunity to magic and psionics.
'It does not appear to be a standard golem, so it should not be immune to magic.' Tryll sends to the group.
Doing anything else, Tryll and Calleigh? NPCs will go if not.
Tryll tries something new! A brief moment of concentration and a pair of blazing lines of positive energy briefly link Tryll's ethereal form with that of the pseudo-golem.
Empowered Maximized Twinned Augmented Celestial Conduit
Extra Cost: 2
Reflex 49 halves
SR applies, rolling for applicability.
[blockquote]Rolled 1d20+31 : 9 + 31, total 40[/blockquote]
Tryll
HP: 326
AC: 47
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Inertial Armor (CL 31), True Seeing (CL 28), Elemental Body (CL 28), Surraruthru's Stupendous Dragonskin (CL 28), Strength of the Dragon Princess (CL 28), Mind of the Dragon Princess (CL 28), Agility of the Dragon Princess (CL 28), Endurance of the Dragon Princess (CL 28), Beauty of the Dragon Princess (CL 28), Create Magic Tattoo (CL 24), Create Magic Tattoo (CL 24), Energy Immunity (CL 26)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +19 armor bonus to AC (blocks incorporeal), True Seeing, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls
Resources Used: 19 PP
Calleigh
HP: 217
AC: 56
