> roll 1d20+15 1
> roll 1d20+15 2
<Serith> Kotono roll for Serith < 16 > [d20=1]
<Serith> Kotono roll for Serith < 31 > [d20=16]
Go for it.
As in healing, doesn't harm non-undead creatures?
As in damage. Negative hit points. I didn't write it, I just cast it.
Quote from: Complete PsionicReaching across the planes, you form a momentary link between yourself and the Positive Energy Plane. With the connection made, you instantly guide a massive charge of positive energy from your psyche into the material world, channeling it along a burning ectoplasmic line that extends from your outstretched hands. Anyone caught in the area takes 9d6 points of damage. Undead caught in the area take 2 additional points of damage per die. A construct or inanimate object takes only 5d6 points of damage from this power. This power is a positive energy effect.
Augment
For every additional power point you spend, the power deals an additional 1d6 points of damage (1d6+2 against undead), and the power's save DC increases by 1.
Okay, fair enough.
By the way, I think the DC got errataed, but you'd need to look that up later. I'm not going to worry about it for this casting.
Well, that's one way to solve it. The sheer rush of power explodes the upper part of the construct's body like glass dropped onto the floor, shattering it. Shards rain against all of you, unable to do any real damage thanks to your protections.
"Geez, the fuck did you do to it?" Dana asks, hands on her hips.
Free act.
"Oh wow, that was GREAT!" Calleigh cackles.
'I didn't realize the reaction would be that strong. That was the first time I've used that power. I essentially created a link to the Positive Energy Plane, and...well, it exploded.' Tryll replies.
Tryll
HP: 326
AC: 47
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Inertial Armor (CL 31), True Seeing (CL 28), Elemental Body (CL 28), Surraruthru's Stupendous Dragonskin (CL 28), Strength of the Dragon Princess (CL 28), Mind of the Dragon Princess (CL 28), Agility of the Dragon Princess (CL 28), Endurance of the Dragon Princess (CL 28), Beauty of the Dragon Princess (CL 28), Create Magic Tattoo (CL 24), Create Magic Tattoo (CL 24), Energy Immunity (CL 26)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +19 armor bonus to AC (blocks incorporeal), True Seeing, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls
Resources Used: 48 PP
Calleigh
HP: 217
AC: 56
"Hmm.. Effective. I may have to find a way to use magic to simulate that ability... Let's keep moving."
'Good luck to you on that. I've found that while magic is significantly more diverse than psionics are, the powers of the mind are generally more powerful. If you can find a way around that, I congratulate you.' Tryll replies as they move on.
Surraruthru considers Tryll's comment... How to increase the power of the spell? Perhaps with a special focus? Hmm. Tap the weave and try to crystallize it? Possibly a feed back loop? Hmm...
He continues to ponder as they go.
> roll 1d20+58 K:A
<Serith> Iddy roll for Serith < 68 > [d20=10]
Generally, metamagic's the best way. Magic lacks the ability of psionics to simply boost with more mental reserves. Magic's much more common and versatile, but psionics of Tryll's level can sometimes do crazy things.
Incidentally, I need to walk through celestial conduit and how you ran it, and also check on that errata. That'll be tomorrow.
Surraruthru mentally logs it for later work and keeps advancing.
The party is now at the four way intersection, free to choose which every way they wish.
