> roll 1d20+54 Spellcraft
<Serith> Iddy roll for Serith < 57 > [d20=3]
It's a teleport circle keyed into a greater network. Teleport circle is a ninth level spell you can already manage. The network part not so much, it's much bigger and that's about all you can tell about it from here.
Time to gear up! Tryll manifests True Seeing on himself and Calleigh as a precaution! That done, the pair enter the circle.
Tryll
HP: 326
AC: 47
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Inertial Armor (CL 31), True Seeing (CL 28), Elemental Body (CL 28), Surraruthru's Stupendous Dragonskin (CL 28), Strength of the Dragon Princess (CL 28), Mind of the Dragon Princess (CL 28), Agility of the Dragon Princess (CL 28), Endurance of the Dragon Princess (CL 28), Beauty of the Dragon Princess (CL 28), Create Magic Tattoo (CL 24), Create Magic Tattoo (CL 24), Energy Immunity (CL 26)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +19 armor bonus to AC (blocks incorporeal), True Seeing, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls
Resources Used: 9 PP
Calleigh
HP: 217
AC: 56
#65
Tapestry refresher:
Tapestry:
Elemental Body (fire) CL 28, 28 hour duration
You have the benefits of the attune form spell with respect to the appropriate element. If you choose a water body, for example, you can breathe normally on waterdominant planes.
You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking. You gain darkvision out to 60 feet.
Your creature type remains unchanged, so you are unaffected by spells that target elementals, but you gain the air, earth, fire, or water subtype depending on the elemental substance you chose.
Surraruthru's Stupendous Dragonskin, CL 28, 28 hour duration
Strength of the Dragon Princess, CL 28, 28 hour duration
Mind of the Dragon Princess, CL 28, 28 hour duration
Agility of the Dragon Princess, CL 28, 28 hour duration
Endurance of the Dragon Princess, CL 28, 28 hour duration
The target of this spell gains a +4 insight bonus to Constitution.
Beauty of the Dragon Princess, CL 28, 28 hour duration
The target of this spell gains a +4 insight bonus to Charisma.
Create Magic Tattoo, CL 24, 24 hour duration
+2 competence bonus on attack rolls.
Energy Immunity (x4) CL 26, 24 hour duration
Grants complete protection agianst: acid, cold, electricity, sonic
Quiescent Weaving: Haste, Retributive Enervation, Spell Turning, Greater Mirror Image
Self:
Epic Mage Armor CL 28, 24 hour duration
An invisible but tangible field of force surrounds the subject of epic mage armor, providing a +20 armor bonus to Armor Class. Unlike mundane armor, epic mage armor entails no armor check penalty, arcane spell failure chance, or speed reduction. Because epic mage armor is made of force, incorporeal creatures can't bypass it the way they do normal armor.
Moment of Prescience CL 28, 28 hour duration
This spell grants you a powerful sixth sense in relation to yourself. Once during the spell's duration, you may choose to use its effect. This spell grants you an insight bonus equal to your caster level (maximum +25) on any single attack roll, opposed ability or skill check, or saving throw. Alternatively, you can apply the insight bonus to your AC against a single attack (even if flat-footed). Activating the effect doesn't take an action; you can even activate it on another character's turn if needed. You must choose to use the moment of prescience before you make the roll it is to modify. Once used, the spell ends.
Bibliotheca Arcana, CL 28, 24 hour duration
You gain a +15 insight bonus to all knowledge checks and may make knowledge checks untrained. This knowledge extends to knowledge of your own life. You you have perfect recall of your own memories for the duration of the spell. Effects that change your memories, such as modify memory or mindrape, are suppressed for the duration of the spell. You gain the ability to read and speak all languages during this time, as if affected by a comprehend languages and tongues spell. Finally, you may instantly absorb the information of any written material you touch, as if by a scholar's touch spell. For the duration of the spell, you have perfect recall of the material read in this manner.
The five of you appear in a pitch black room. Cold liquid laps at your legs, freezing you near immediately. Brr!
Note if you have darkvision or can otherwise see in the dark.
Dana
HP: 392+16/392
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength of the Dragon Princess (CL28), Mind of the Dragon Princess (CL28), Agility of the Dragon Princess (CL28), Endurance of the Dragon Princess (CL28), Beauty of the Dragon Princess (CL28), Bibliotheca Arcana (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunityx4 (CL26)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, immunity to elemental damage, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls,
Hanna
HP: 396+15/396
Tryll and Calleigh have True Seeing, which confers darkvision.
Surraruthru has Darkvision to 120 ft as well as Blindsense.
Kascha has Darkvision to 120 ft.
Surraruthru
HP: 413/413 (359 base)
AC: 52+4 (Deflection)
Touch AC: 24, Flat Footed: 57, SR: 37, CMB: 33, CMD: 51
Init: +12, Touch Atk: 38
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Bibliotheca Arcana (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL26), Epic Mage Armor (CL28)
Passive: True Seeing, Detect Magic, +15 to knowledge checks
Kascha
HP: 359/359 (305 base)
AC: 63
Touch AC: 47, Flat Footed: 57, SR: 38, CMB: 33, CMD: 61
Init: +14, Touch Atk: 31
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL26)
Passive:
The party stands in a 20 by 20ft room filled with icy cold water up to your ankles. There's a closed door to the south and a closed door to the west. The walls are made of solid stone, the doors of good and sturdy wood and the door frames of the same. As you all look around, you see the ceiling is studded with little protruding iron nubs, dozens of them spaced out.
Dana
HP: 392+16/392
Hanna
HP: 396+15/396
[/quote]
"Nice place!" Calleigh remarks, very clearly not standing at all, "Very dungeon-chique!"
"Yeah, great place to go send someone to die," Dana drawls, "Hey, fuck that guy, go toss him in here."
Waiting on Iddy spell corrections before sorting this out further.
Note that Surraruthru has Detect Magic going.
Surraruthru inspects the iron nubs, trying to discern their purpose.
"Tryll, would you kindly float through the walls and scout those rooms for us?"
Surraruthru
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Bibliotheca Arcana (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL28), Epic Mage Armor (CL28)
Kascha
AC: 63
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL28)
Passive:
"I got it!" Calleigh chirps, lurching forward and vanishing through the wall.
