Surraruthru makes a rumbling considering noise in his throat as he inspects the cylinder with his Detect Magic and True Seeing.
> roll 1d20+57 Spellcraft
<Serith> Iddy roll for Serith < 67 > [d20=10]
Your detect magic spell fails.
Your arcane knowledge is sufficient to tell you that it failed because it's likely warded against divinations. At least weaker ones but possibly more.
"Hmm.. It's warded against divination, I think. Interesting. Kascha, ideas on how to break through divination wards? I'm not sure I want to throw a dispel at yet, without knowing what other magic is on it."
"Cabinet's magic," Kascha announces, "It preserves what's stored in it, nothing too fancy." She pauses looking over at you.
"Well," Kascha says, "Do you have a stronger spell, like analyze dweomer, available?" Kascha turns all the way to you, "That's a good choice and worth trying if you do, since some anti divination wards only work on spells of up to a certain circle, under the same principle as globe of invulnerability. Otherwise there's not a lot I can think of to do."
'I may be able to get around it with an actual Divination.'
"Please do, Tryll. I don't have much divination magic prepared."
Tryll manifests Divination!
seeking knowledge of what's inside first, followed by how to open the cylinder.
You get no answer.
Your arcane knowledge tells you the same thing as Surraruthru - something's blocking your divination about the cylinder and what's inside.
It cannot, either due to a divination block or whatever it is not being in a category true seeing helps with.
Can we determine ANYTHING about this thing? What it is? What it does? Who made it? Is it a folded space like a bag of holding? Is it a big black dildo? Gimme something.
Have you made a Knowledge check about it yet or any other check?
I need to know. I need to know.
Tell me baby girl because I need
to
know.
