Miasma (Moore, 86 days left)
Started by Anastasia, July 19, 2017, 02:05:12 PM
Jetina has faith -- and so she calls out for healing!
Mass heal, Effortless healing prevents any AoOs from this.
"IT WILL NOT BE!" Magic explodes around Jetina and...
> roll 1d20+37
<Serith> Kotono roll for Serith < 44 > [d20=7]
Countered.
Chance to do anything else with her turn.
She'll use emergency healing again for mass heal and then that'll be it.
That goes through.
Healing spreads, as abruptly  winds begin to surge. A massive whirlwind blows where Westwind should be, knocking Nessians back a bit, "To me!" You aren't sure what happens there, but you can feel the winds blowing as...
Listen.
[14:56] <Nephrite> roll 1d20+36 Listen Moore
[14:56] <Serith> Nephrite roll for Serith < 41 > [d20=5]
[14:56] <Nephrite> roll 1d20+36 Listen Jetina
Jetina's is actually 39 so that should be 44 for her.
You think you hear...something? Maybe. You aren't sure, as suddenly darkness covers all of you.
Fort save, all.
Init is Moore (48) > Jetina (37) > Finnegan (36) > Westwind (32) > Nessians (22) This will update shortly.
[21:55] <Nephrite> roll 1d20+64 Moore, mettle (tyche's touch to +3)
[21:55] <Serith> Nephrite roll for Serith < 81 > [d20=17]
[21:57] <Nephrite> roll 1d20+56 Jetina, mettle (tyche's touch to +3, also she needs to just cast Superior Resistance on herself all the time from now on)
[21:57] <Serith> Nephrite roll for Serith < 67 > [d20=11]
> roll 1d20+46 (+16 morale, +3 tyche's touch) Westwind
<Serith> Kotono roll for Serith < 54 > [d20=8]
> roll 1d20+55 (+16 morale, +3 tyche's touch) Finnegan
<Serith> Kotono roll for Serith < 75 > [d20=20]
Darkness rips through all of you, sharp and painful. But nothing else happens as...
100 damage to Westwind and Finnegan, the other two have mettle. Adjusting init.
Init is Moore (48) > Jetina = Afina (37) > Finnegan (36) > Westwind (32) > Nessians (22) > Jaela (20)
Go Moore.
+24 attack from Moore. +22 damage, improved crit and +12 crit confirms, +16 dodge to AC and morale to saves, fast healing 10.
Prince Westwind
HP: 460/490
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Mass Conviction (CL16), Tyche's Touch (CL16), Mass Valiant Fury (CL26)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +4 morale saves, +4 luck to saves, -1 each time, +6 morale strength+con, 1 extra attack like haste.
Finnegan
HP: 380/434 (356 normally)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +4 morale saves, +3 luck to saves, -1 each time, +6 morale strength+con, 1 extra attack like haste.
Did he hear something...?
At any rate, there's really not a lot else to do right now, so he takes a breath and... ...no. He can't just stay here and dance with them, can he?
For now, though...
"We won't lose to you!" He shouts.
Move action spent on refreshing Inspire Greatness.
[23:08] <Nephrite> roll 12d4 nonlethal
[23:08] <Serith> Nephrite roll for Serith < 24 > [d4=1,1,2,1,1,3,4,1,4,1,3,2]
[23:08] <Nephrite> roll 8d10 temp hp Moore
[23:08] <Serith> Nephrite roll for Serith < 32 > [d10=3,3,6,4,1,3,3,9]
[23:08] <Nephrite> roll 8d10 temp hp Jetina
[23:08] <Serith> Nephrite roll for Serith < 48 > [d10=2,5,1,5,10,7,8,10]
That said, Moore calls on divine power to showcase itself as light -- if anyone IS coming, hopefully this will help them find him... or see him, at least!
Righteous Halo. He doesn't have anything else to do on his turn, really. He can't get to Westwind so he's hoping someone will make a path for him.
Next is Jetina.
#159
If they're standing their ground, then Jetina knows just the spell to allow them to do it!
Sublime Revelry on herself and Moore. If somehow she can target Westwind and Finnegan too she will but I presume she is unable to do so.
Moore
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 24), True Seeing (CL10), Bibliotecha Arcana (CL29), Greater Improvisation (CL27), Divine Insight (CL18), Snowsong, Righteous Halo
HP: (24)336+81(not temp)+32
AC: 62, 46 touch, 52 flatfooted 20% miss chance, SR 41, 30 resist all to elements (AC is currently 82)
29/32 Bardic music uses 2/3 Refrain
Spells:
0th - 4/4 (DC 22)
1st - 7/7
2nd - 7/7
3rd - 7/7
4th - 7/7
5th - 4/6
6th - 6/6
7th - 6/6
8th - 5/5
9th - 1/1
Favored Soul:
0th - 5/5
1st - 9/9
2nd - 9/9
3rd - 7/8
4th - 8/8
5th - 8/8
6th - 8/8
7th - 6/6
8th - 4/4
Jetina
Planar Tolerance (CL16), Mass Conviction (CL160), mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7), greater mage armor(CL5)
353/353 +48
+78
Init: +5, AC 53, Speed 30/30 (P)
Saves: Fort +41, Ref +33, Will +43
6/9/9/8/8/8/8/7/5/6/5/4
Emergency Healing 1/3
All healing spells (up to 3 targets) remove negative afflictions per panacea spells and also grant fast healing 10 for 24 rounds, also add +23 to the amount healed
Eb, could you cross post your time stop actions from the other thread? Thanks.
Afina goes very fast and things happen!
10th level slot for 5 levels time stop
round 1: prismatic wall
round 2: prismatic wall
round 3: prismatic wall
round 4: prismatic wall
round 5: prismatic wall
Walls are 108x54 feet. Arranged to partition the battlefield so there's a clear path for Moore and company to reach us but all other avenues are blocked.
To save on my rolling, its +27 for SR checks on it and the save DCs are 33
A series of brightly glowing prismatic walls appear, a long line stretching on either side as well as above and below leading from Afina and Jaela straight to their allies, with a further wall cutting across their rear to block that path. Hopefully it's obvious enough what direction to retreat in.
She follows that up by dropping an ashen avalanche, the prismatic wall above their allies heads protecting them from it while any devils above said wall will get crushed through all its layers, and the ones on the perimeter will just get dropped.
Fire subbed call avalanche, DC 33 ref half
[19:58] <@Ebiris> roll 8d6
[19:58] <Serith> Ebiris roll for Serith < 28 > [d6=4,2,3,3,6,3,5,2]
If they save they're not buried, if they don't they are. But with no ground here I imagine they just get dragged down by the falling avalanche for whatever distance it falls?
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), death ward (CL 20), sublime revelry (CL 31), good hope (CL 30), control winds (CL 27), interplanar telepathic bond (CL 26), haste (CL 27)
defences: AC 97 (touch 60), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, 50% miss chance, freedom of movement
spell slots: 6/9/10/7/7/8/2/8/3/6/5/0/3
Okay, so if you're at the bottom of the passage you're making, with a prismatic wall sealing off your rear, correct?
No, it seals off Moore's rear.
This is a top down view for example. But it also works as a side on view too. There's basically a long prismatic tunnel bordered on all four sides stretching from Afina to Moore's group, with the far end (relative to Afina) blocked off so that Moore and co would only have one direction they could travel in (towards Afina and potential safety) without having to brave the prismatic walls.
..............................Nessians.......|......................
Afina.............................Moore......|......................
................Nessians.....................|......................
.....................Nessians................|......................
Okay, cool. So they're 108ft tall to be clear?
