The Rime Tower (Afina, 86 days left)
Started by Anastasia, July 19, 2017, 02:12:04 PM
[20:15] <@Annerose> roll 1d20+18 I'm strangely okay with it
[20:15] <Serith> Annerose roll for Serith < 34 > [d20=16]
> roll 1d20+13 Bubbles
<Serith> Kotono roll for Serith < 21 > [d20=8]
> roll 1d20+13 Crystal+Hope, one will hold forthe other so whatever
<Serith> Kotono roll for Serith < 19 > [d20=6]
> roll 1d20+14 Cresiel
<Serith> Kotono roll for Serith < 25 > [d20=11]
> roll 1d20 tower
<Serith> Kotono roll for Serith < 20 > [d20=20]
Init is Afina (46) > Jaela (34) > Cresiel (25) > Bubbles (21) > Tower (20) > Crystal (19)
Open Afina.
Bubbles
HP: 298+20/298
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Greater Heroism (CL27), Epic Mage Armor (CL27), Mass Death Ward (CL24), Sublime Revelry (CL31), Good Hope (CL30), Interplanar Telepathic Bond (CL26)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +4 morale attack rolls and saves, +20 armor bonus AC.
Crystal
HP: 444+20/444
Resources Used: Mass death ward
Hope
HP: 619+2/619
Cresiel
HP: 596+20/596
How fast is the tower coming at us and how tall/wide is it?
It's got to be over 100ft tall if not more, certainly a colossal creature. It's coming at you fairly fast, surprisingly despite its size.
"Allow me a little room, it's going to get hot," Afina asks, flying a bit clear of her companions before a gigantic magmaberg drops on top of the tower.
6th level slot for 1 round time stop, cast elemental bubble then cast elemental subbed iceberg
[18:43] <@Ebiris> roll 1d20+33 iceberg SR
[18:43] <Serith> Ebiris roll for Serith < 37 > [d20=4]
DC 37 ref, 120 damage to anything within 20 feet of impact (no save, also buried), 120 damage for 20-40 feet of impact (save for half and avoid burial), 60 damage for 40-60 feet of impact.
All damage ignores resistance/immunity and does 250% on anything vulnerable to fire.
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), death ward (CL 20), sublime revelry (CL 31), good hope (CL 30), control winds (CL 27), interplanar telepathic bond (CL 26), haste (CL 27), recitation (CL 30), planar bubble (CL 27)
defences: AC 97 (touch 60), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, 50% miss chance, freedom of movement
spell slots: 6/9/10/8/7/9/2/8/8/8/6/0/3
The spell radius is 60 feet but that includes 'splash' from it shattering on impact. It's described thus:
When cast, the spell creates a single large block of ice that drops from the sky onto a spot you select.
The iceberg then shatters if it encounters a solid surface.
Elephant-sized blocks of ice scatter in all directions, affecting nearby creatures based on how far they are from the center of the area.
Assuming lowered damage comes from the splash after 40 feet, we could guess it's 40 feet wide? No idea how tall.
> roll 1d20+10 Ref needs a 20, really, towers aren't evasive
<Serith> Kotono roll for Serith < 29 > [d20=19]
The magmaberg slams into the top of the tower, stone giving way from the impact. The upper stories collapse onto each other, the entire tower driven into the still quivering ground. Fires spread over parts of it, ablaze from the magmaberg's impact.
However, it's already starting to rise again, in spite of the damages.
Jaela.
Taking 10 for K:A 60 on understanding the tower.
Spells Active: Spell Turning CL26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL30, Greater Heroism CL30, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL33, Interplanar Telepathic Bond CL26 (Tepen), Sublime Revelry CL31, Mass Death Ward CL24 (Cresiel), Good Hope CL30.
Short Duration Spells: Grace CL30, Moonlight Revelation CL30, Recitation CL30, Haste CL27.
An entire tower animated by magic like this is no easy feat. It suggests an epic spellcaster or artifact, unless the tower was carefully designed to be one already, but that's one hell of a task. It's like any other construct - hit it hard enough to break it and it'll stop.
Jaela follows through with another pair of Earthquakes while the tower had been driven into the ground! And regardless of the outcome, continues her advance at an angle to attempt to draw Mala's enmity towards her.
Moving 150ft ahead and to the left to get out of the direct path the tower was on.
Remember to make a fort save against the winds if you go more than 40 feet from Afina. Don't 1!
[21:37] <@Annerose> roll 1d20 not 1!
[21:37] <Serith> Annerose roll for Serith < 10 > [d20=10]
> roll 1d20+20 tower fort in bad shape with more earthquakes
<Serith> Kotono roll for Serith < 24 > [d20=4]
Earthquakes rock the tower, ground ripping apart beneath you as the tower shudders. Cracks run all up and down it, hunks of stone and ice falling away. It's like it's crumbling before you as...
"Wisdom," Cresiel intones, as the earth again shatters. At this point the entire land is breaking apart, canyons forming and magma erupting from below. The screaming of rock tearing like paper is a hideous din. The entire tower shudders one last time and starts to break apart, plunging into the rends in the earth, into the magma revealed like the land's corrupted blood.
Well that was a boss fight that got owned quite thoroughly. Free act.
"I think we're done," Afina says, stilling the winds and then casting a Gate spell to open the way back to Aurora.
