Surru's to-dos (Surraruthru, 85 days left)
Started by Anastasia, September 01, 2017, 12:02:09 AM
Okay, deduct the cost of this in loot.
"Beyond the hook but before the rise." Mirajane repeats when she's done.
"Hmm... I'll have to see if the library has any maps I can use to identify that. I may return if not. Thank you for the help, Mirajane."
Going to research that? K:P with library bonus if so.
I will!
> roll 1d20+57+15 K:P/Library
<Serith> Iddy roll for Serith < 76 > [d20=4]
Secondary bonus: Do you have any ranks in K:Geography?
Not directly, but the Knowledge Prism gives me +15 to all, and if I cast Biblotheca Arcana, that gives me another +15 and allows me to make knowledge checks untrained. That'd be a total of 1d20+39.
Roll it.
BA is an all day spell, FYI. If you're going to use it I suggest assuming it's always on and cast at the beginning of the day, though this isn't mandatory.
I was going to hold BA until I had a full tapestry, so it'd extend to everyone, but in this case, the immediate info need sorta calls for it.
> roll 1d20+39 K:G/Library/BA
<Serith> Iddy roll for Serith < 48 > [d20=9]
The Ember Coast is huge, as most outer planes regions are. Still, several hours on maps of regions finds a likely location. There's a small, jutting cape along the coast in a rough hook shape, and a bit past that is a region called the Sulphurian Rises.
Surraruthu nods to himself. A place to try. He heads off to find Kascha and Simmer again.
"Oh, that sounds promising," Kascha says, "Shall we go?"
Simmer's more relaxed about it, "A magma sea? Do you have a plan in case they go swimming and we can't follow?"
"Well, elemental body will protect us from the fire, and I have my necklace of adaptation, which should let me breathe. Is there something else you suggest we prepare for?"
"Magma's much harder to move in than thin lava," Simmer point sout, "It's not really like water. Creatures adapted to Fire can do it, but you'd find it difficult, even if you could breathe. Do you have a means to see in the magma?"
"Hmm, I have blindsense, but I'm not sure if that will work through magma.. Do you have any suggestions?"
Are there spells that grant that stuff? I can't recall any.
Not that I can think of, it's pretty specialized territory.
