Just gimme a 1 check real quick, since time matters here.
[22:01] <@Jessica> roll 1d20
[22:01] <Rei-chan> Jessica rolled : 1d20 --> [ 1d20=8 ]{8}
WHAM! Another blow, shredding a good chunk of floor. However, only more stone is beneath this.
Jaela disintegrates it with a thought and gesture!
Quickened disintegrate.
19:24 <Luisa> roll 1d20
19:24 <Kobot> Luisa rolled 1d20 --> [ 1d20=19 ]{19}
More stone vanishes, revealing a dark room below. You don't get much of a glance before Adrian calls, "Devils!"
Your choice how to handle it. Dana and Adrian are still a floor above you, while you two and Barne are down here dealing with this. I'll call for init as needed.
Can I get more information on these devils? Blindsight 200
'Go, open up the path below,' Jaela relays to Afina, sending to Adrian and Dana, 'Get down here, I'll hold the devils off.'
Looks like an assorted bunch of barbazu, a few spinagons, an erinyes and a few barbed devils.
Afina flies down into the dark room and disintegrates the floor, not seeing any great threat from the devils she can sense.
[18:08] <@Ebiris> roll 1d20 1 check
[18:08] <Kobot> Ebiris rolled 1d20 1 check --> [ 1d20=18 ]{18}
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), haste (CL 27), control winds (CL 27)
defences: AC 99 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, 50% miss chance, freedom of movement
spell slots: 6/9/10/10/7/9/4/8/8/8/7/2/3
Okay. Jaela is going into a side topic for the moment, splitting her off for this combat. One second on that.
It's less of a room and more of a broad hall. Disintegrating the floor only reveals more stone as Barne says, "We're in the basements now," he says, pointing in one direction, "That way leads away from here, the other leads back to the hall, if I have the right of it."
This might need Jaela to cast that Find the Path spell. Afina ways here for them to catch up, monitoring everything around her within 200 feet to ensure nothing sneaks up on them.
You meant waits here and you're holding on Jaela, right?
