"I haven't taxed myself yet," Afina confirms as she flies along.
Deeper and deeper. You're running along, footsteps echoing all around the halls as Barne leads you along. As you go...
Spot all. This is probably perfunctory with Afina.
[17:57] <@Ebiris> roll 1d20+70
[17:57] <Rei-chan> Ebiris rolled : 1d20+70 --> [ 1d20=3 ]{73}
As you all hurry along, Afina's eyes catch a tiny segment of stone in the wall moving aside, a tiny spyhole used, gleaming red eyes within it, watching the party as they pass.
My power is leading us! Though he's helping. And I can't beat that.
Afina immediately disintegrates that section of wall!
[18:07] <@Ebiris> roll 1d20 1 check
[18:07] <Rei-chan> Ebiris rolled : 1d20  check --> [ 1d20=9 ]{9}
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), haste (CL 27), control winds (CL 27), spell turning (CL 26)
defences: AC 99 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, 50% miss chance, freedom of movement
spell slots: 6/9/10/10/7/9/1/8/8/8/7/2/3
2 moments of prescience left
The wall disintegrates. Behind it is a mere spinagon in a narrow, tight hallway running parallel to the passage. It stares a moment in shock as the wall it was behind is now gone. It's twisted, smirking devil face is marred with its surprise, a complete moment of being off guard.
Afina takes advantage of that surprise, flying in and stabbing it to death! 'Jaela, does this change your path?' she asks telepathically.
[18:23] <@Ebiris> roll 1d20+62
[18:23] <Rei-chan> Ebiris rolled : 1d20+62 --> [ 1d20=17 ]{79}
[18:23] <@Ebiris> roll 1d20+57
[18:23] <Rei-chan> Ebiris rolled : 1d20+57 --> [ 1d20=12 ]{69}
[18:24] <@Ebiris> roll 1d4+30+3d6+3d6+4d6+6d6 and 2 negative levels
[18:24] <Rei-chan> Ebiris rolled : 1d4+30+3d6+3d6+4d6+6d6 and 2 negative levels --> [ 1d4=2 3d6=12 3d6=10 4d6=6 6d6=19 ]{79}
[18:24] <Rei-chan> Ebiris rolled : 1d4+30+3d6+3d6+4d6+6d6 and 2 negative levels --> [ 1d4=4 3d6=8 3d6=10 4d6=12 6d6=23 ]{87}
"W-"
That's all the spinagon manages to get out before his body is slashed into several pieces, bursting into a foul pile of dust. Got it, another down.
Adrian just glances over and keeps on flying ahead.
Jaela notes this hasn't changed her path at all.
'Not really,' Jaela responds. 'Didn't even register as a trap, possibly because it was so weak.'
No shortcut there then, she'll stick with following Jaela's spell.
Down and down and down some more. At last you come to a heavy stone door, Barne going to it. "This should be barricaded, you'll need to bust through it," she says, as your spell concurs.
Heavy steel doors with no magical protections are weak to disintegrations!
[21:38] <@Armand> roll 1d20
[21:38] <Rei-chan> Armand rolled : 1d20 --> [ 1d20=5 ]{5}
Naturally, there is one less door and stone around it. Ahead is a chamber - storage, perhaps, boxes and barrels. Alls tacked up, three fortifications ahead. Erinyes and barbazu hold them, dozens of arrows flying in the aftermath as...
Init.
[19:40] <@Ebiris> roll 1d20+34
[19:40] <Rei-chan> Ebiris rolled : 1d20+34 --> [ 1d20=6 ]{40}
