Jaela has no trouble leading the way while staying afloat!
Airborne it is. Once in the air, "Neat trick," Dana says, "Gives me an idea, too."
"Some sort of ass kicking ability that comes right on up and fucks all the enemies over," Dana says, "Something to get a lot of the assholes at once."
"I haven't gotten bored of burning things," Afina opines.
"Afina fuckin' gets it."
On that observation you advance in. Down more stairs - and you find a thick wall of iron midway down, completely blocking the way ahead. It glows red with heat, as if burning hot.
'Adrian and I are immune to fire,' Jaela muses in their minds. 'I can manage a protective spell. How about you, Afina?'
'Only to resist fire, not immunity,' Afina answers. 'There's probably a wall of lava behind the door like in Apasa's place. You disintegrate it and I'll shoot out a cone of cold?' she suggests.
Adrian readies himself in front of the wall, "Get back, just in case," he says, "I can block if it is fire."
Jaela wards Dana all the same before disintegrating the door!
Energy Immunity: Fire CL26.
Also!
[21:29] <@Armand> roll 1d20
[21:29] <Rei-chan> Armand rolled : 1d20 --> [ 1d20=11 ]{11}
The wall is gone, and sure enough ,a pocket of lava starts to gush out, spraying up and out, as if pressurized.
Afina?
I'll put resist energy fire on Barnes while Jaela wards Dana
A spray of frigid air meets it!
[19:32] <@Ebiris> roll 15d6 cone of cold
[19:32] <Rei-chan> Ebiris rolled : 15d6 cone of cold --> [ 15d6=32 ]{32}
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), haste (CL 27), control winds (CL 27), spell turning (CL 26)
defences: AC 99 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, 50% miss chance, freedom of movement
spell slots: 5/9/9/9/7/9/0/8/8/8/7/2/3
2 moments of prescience left
Lava meets cold. What happens is an explosion, pelted by rock as hunks of it flash freeze. The hallway is now clogged by volcanic glass and stone, , but at least you aren't about to be immolated anymore.
Afina uses Stone Shape to carve out a tunnel through the now solidified lava.
