Done and done. The passage is now revealed, if you care to travel it.
Assuming Jaela's path says so then they surely will!
Down ahead, into a room. Here is a lot of open space, a barred and locked door at the far end. However, ahead of you? A line of lemures blocks the way 30ft ahead, squalid and squeaming like blobs of soul-fat. Behind them stands a good dozen steel devils, tower shields at the ready forming a formidable shield wall. Behind them stands a pit fiend with a gelugon on either side of him.
"I am Colonel Magre," he introduces himself, voice a soft, sibilant thing that yet carries. "Surrender or face immediate execution."
"A colonel leading lemures into battle? What an honor to meet you!"
Adrian chuckles at that, "Yeah, not even a general? What noble did you piss off to get this position?"
Dana just readies her shield and rapier, "Yeah, what the fuck ever. C'mon and die so you can sniff asses in Hell."
With the mocking part of combat done with, Jaela charges ahead!
Of course with blindsight 60 and anti-invis 140 if this is some elaborate trap I'd like to know about it as I close in.
Afina certainly doesn't have banter for a lowly gelugon.
[18:14] <@Ebiris> roll 1d20+34 init
[18:14] <Rei-chan> Ebiris rolled : 1d20+34 init --> [ 1d20=20 ]{54}
[20:15] <@Armand> roll 1d20+22 init
[20:15] <Rei-chan> Armand rolled : 1d20+22 init --> [ 1d20=3 ]{25}
> roll 1d20+13 Adrian
<Rei-chan> Kotono rolled : 1d20+13 Adrian --> [ 1d20=14 ]{27}
> roll 1d20+89 Dana
<Rei-chan> Kotono rolled : 1d20+89 Dana --> [ 1d20=11 ]{100}
> roll 1d20+10 lemure line
<Rei-chan> Kotono rolled : 1d20+10 lemure line --> [ 1d20=12 ]{22}
> roll 1d20+18 sheel devil shield wall
<Rei-chan> Kotono rolled : 1d20+18 sheel devil shield wall --> [ 1d20=5 ]{23}
> roll 1d20+19 gelugon 1\
<Rei-chan> Kotono rolled : 1d20+19 gelugon 1\ --> [ 1d20=18 ]{37}
> roll 1d20+19 gelugon 2
<Rei-chan> Kotono rolled : 1d20+19 gelugon 2 --> [ 1d20=3 ]{22}
> roll 1d20+26 pit fiend
<Rei-chan> Kotono rolled : 1d20+26 pit fiend --> [ 1d20=9 ]{35}
Dana's init is 20, it wasn't meant to be +89 but +9.
Init is Afina (54) > Gelugon 1 (37) > Pit Fiend (35) >  Adrian (27) > Jaela (25) > Shield Line (23) > Gelugon 2 = Lemure Line (22) > Dana (20)
Afina opens.
With everyone currently resistant to fire, Afina can afford to go all out. Thus she speeds herself up massively before bringing the fire!
7th level slot for 2 rounds of time stop
Round 1: cast planar bubble
Round 2: cast searing delayed blast fireball to cover all the devils
[18:27] <@Ebiris> roll 1d20+33 searing delayed blast fireball SR
[18:27] <Rei-chan> Ebiris rolled : 1d20+33 searing delayed blast fireball SR --> [ 1d20=13 ]{46}
Does 162 fire damage, ignoring immunity/resistance. DC 35 ref half
And as time resumes its flow she follows that up by throwing a swarm of meteors at the pit fiend, fireballs blooming across the battlefield!
[18:34] <@Ebiris> roll 1d20+33 searing meteor swarm SR
[18:34] <Rei-chan> Ebiris rolled : 1d20+33 searing meteor swarm SR --> [ 1d20=2 ]{35}
[18:34] <@Ebiris> roll 4#1d20+51 ranged touch
[18:35] <Rei-chan> Ebiris rolled : 4#1d20+51 --> [ 1d20=19 ]{70}, [ 1d20=17 ]{68}, [ 1d20=15 ]{66}, [ 1d20=17 ]{68}
Does 96x4 damage to the pit fiend struck (bludgeoning/fire) and 48x4 damage to everything else. No save for pit fiend, DC 37 ref half for the rest.
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), haste (CL 27), control winds (CL 27), spell turning (CL 26)
defences: AC 99 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, 50% miss chance, freedom of movement
spell slots: 5/9/9/9/7/9/0/7/7/8/6/2/3
2 moments of prescience left
> roll 1d20+13 lemures if you couldn't guess, they're waaaay boosted
<Rei-chan> Kotono rolled : 1d20+13 lemures if you couldn't guess, they're waaaay boosted --> [ 1d20=4 ]{17}
> roll 1d20+21 steel devils
<Rei-chan> Kotono rolled : 1d20+21 steel devils --> [ 1d20=13 ]{34}
> roll 1d20+24 Gelugons
<Rei-chan> Kotono rolled : 1d20+24 Gelugons --> [ 1d20=16 ]{40}
> roll 1d20+24 Gelugon 2
<Rei-chan> Kotono rolled : 1d20+24 Gelugon 2 --> [ 1d20=2 ]{26}
> roll 1d20+29 evasion pit fiend
<Rei-chan> Kotono rolled : 1d20+29 evasion pit fiend --> [ 1d20=10 ]{39}
Init is Afina (54) > Gelugon 1 (37) > Pit Fiend (35) >  Adrian (27) > Jaela (25) > Shield Line (23) > Gelugon 2 (22) > Dana (20)
> roll 1d20+24 gelugon 1
> roll 1d20+24 gelugon 2
<Rei-chan> Kotono rolled : 1d20+24 gelugon 1 --> [ 1d20=19 ]{43}
<Rei-chan> Kotono rolled : 1d20+24 gelugon 2 --> [ 1d20=10 ]{34}
<Rei-chan> Kotono rolled : 1d20+21 steel devils --> [ 1d20=8 ]{29}
Fire and fury. The devils are blasted, burned and obliterated. The lemures are no more, the shield wall badly burning and almost broken. The pit fiend screams as he's hit over and over again, falling to its knees, still up, if perhaps by little indeed. Then one of the gelugons turns to Afina and....
> roll 1d20+20
<Rei-chan> Kotono rolled : 1d20+20 --> [ 1d20=5 ]{25}
Nothing happens, magic crumbling before Afina's might.
Then the pit fiend stands its ground and begins to chant, horrid words coming from the depths of Hell. The screams of the fallen, the faithless and the failed. Magic begins to form around her, as it fans out, abruptly immersing all in unholy power.
> roll 1d20+30 SR check
<Rei-chan> Kotono rolled : 1d20+30 SR check --> [ 1d20=19 ]{49}
Fort, all.
[20:55] <@Armand> roll 1d20+35 counterspell
[20:55] <Rei-chan> Armand rolled : 1d20+35 counterspell --> [ 1d20=1 ]{36}
[18:55] <@Ebiris> roll 1d20+61 fort, moment of prescience
[18:55] <Rei-chan> Ebiris rolled : 1d20+61 fort, moment of prescience --> [ 1d20=4 ]{65}
Afina 329+20/329
1 moment of prescience left
