Fort
[20:56] <@Armand> roll 1d20+66
[20:56] <Rei-chan> Armand rolled : 1d20+66 --> [ 1d20=1 ]{67}
> roll 1d20+46 Adrian does not fail fort on a natural 1
<Rei-chan> Kotono rolled : 1d20+46 Adrian does not fail fort on a natural 1 --> [ 1d20=4 ]{50}
> roll 1d20+44 Dana also has steadfast determination
<Rei-chan> Kotono rolled : 1d20+44 Dana also has steadfast determination --> [ 1d20=1 ]{45}
Dana is grateful to Steadfast Determination about now.
OOC: 160 hellfire damage. Halved for all but Jaela, who takes full.
Maximizing hurts.
Pain. Pain and fire that is not fire but pure hate, boring and burning into the four of you like nothing else. Jaela shudders, caught offguard from it and burned, the flames blowing into her like a poison. YEt all of you endure, far stronger than that as...
Adrian and then Jaela. Go ahead and go, Jaela, I need a sec.
12th level slot sacrificed for -60 damage on that via spell shield.
Is Barnes dead, btw?
Afina 329/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), haste (CL 27), control winds (CL 27), spell turning (CL 26)
defences: AC 99 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, 50% miss chance, freedom of movement
spell slots: 5/9/9/9/7/9/0/7/7/8/6/2/3
1 moment of prescience left
He wisely fell back when attacks started being a concern.
"Enough!" Jaela snarls, burning with holy light. "Disappear from my sight!"
Mass Heal as swift.
[21:09] <@Armand> roll 1d20+67+7-10 10pa divine might charging smite
[21:09] <Rei-chan> Armand rolled : 1d20+67+7-10 0pa divine might charging smite --> [ 1d20=19 ]{83}
[21:11] <@Armand> roll 12d8+138+96+18+6+60+4d6+4d6
[21:11] <Rei-chan> Armand rolled : 12d8+138+96+18+6+60+4d6+4d6 --> [ 12d8=49 4d6=10 4d6=12 ]{389}
Goldenfire to all the devils within 10ft of me.
[21:12] <@Armand> roll 1d20+30 SR
[21:12] <Rei-chan> Armand rolled : 1d20+30 SR --> [ 1d20=7 ]{37}
[21:12] <@Armand> roll 2d6+4d6 burn
[21:12] <Rei-chan> Armand rolled : 2d6+4d6 burn --> [ 2d6=6 4d6=8 ]{14}
The pit fiend. Since I'm flying I assume I can go above the wrecked wall of devils. They can AoO me, of course.
They can and they will!
> roll 1d20+30 vs Jaela's AC of way more than that
<Rei-chan> Kotono rolled : 1d20+30 vs Jaela's AC of way more than that --> [ 1d20=5 ]{35}
With the wall in disorder, Jaela zips past and to the pit fiend, impaling him. There's a gurgling cry and he explodes, ripped in half by his own energies.
Init is Afina (54) > Gelugon 1 (37) > Pit Fiend (35) >  Adrian (27) > Jaela (25) > Shield Line (23) > Gelugon 2 (22) > Dana (20)
Any other actions this turn, Jaela?
I'm done. But you're right, I'll explicitly Gambit with Gae Bolg as I've been doing all this time!
Adrian meanwhile charges in, going to meet the devastated shield devils head on, as they burn with goldenfire.
> roll 1d20 -25 PA this is just a 1/crit check since even with the boosts Adrian has a ton of to hit going right now, will do the math if it looks like it might matter
<Rei-chan> Kotono rolled : 1d20 -25 PA this is just a 1/crit check since even with the boosts Adrian has a ton of to hit going right now, will do the math if it looks like it might matter --> [ 1d20=2 ]{2}
> Crap, math time.
<Ebiris> Adriaaaaan!
> roll 49+2+2+4+7
<Rei-chan> Kotono rolled : 49+2+2+4+7 --> {64}
> Yeah, doens't matter. Okay.
> roll 2d6+90+9d6+4d6
<Rei-chan> Kotono rolled : 2d6+90+9d6+4d6 --> [ 2d6=6 9d6=32 4d6=9 ]{137}
Adrian charges into the devils head on, a swipe of his blade clearing away three. Shields and bodies are severed in equal measure, a gaping hole in the defense line as the remnants of the shield line try and hold the position, as the second gelugon, burning and marred, turns and stabs at Jaela.
<Rei-chan> Kotono rolled : 1d20+39 vs Jaela AC --> [ 1d20=7 ]{46}
> OOC: +4 more but still a miss.
Gambit away.
Stepping aside, Jaela lets the unlucky devil run head-first into Gae Bolg!
[21:42] <@Armand> roll 1d20+53+7-10+6 10pa
[21:42] <Rei-chan> Armand rolled : 1d20+53+7-10+6 0pa --> [ 1d20=20 ]{76}
[21:42] <@Armand> roll 1d20+53+7-10+6 10pa crit?
[21:42] <Rei-chan> Armand rolled : 1d20+53+7-10+6 0pa crit? --> [ 1d20=18 ]{74}
[21:44] <@Armand> roll 12d8+120+11d6+6+60+42+9d6+4d6 and 4 negative levels
[21:44] <Rei-chan> Armand rolled : 12d8+120+11d6+6+60+42+9d6+4d6 and 4 negative levels --> [ 12d8=43 11d6=42 9d6=34 4d6=10 ]{357}
Init is Afina (54) > Gelugon 1 (37) > Adrian (27) > Jaela (25) > Shield Line (23) > Dana (20)
As you would expect, impaling a gelugon through the throat kills it. Good to know. As that happens...
Make a Listen check, all. +9 circumstance penalty.
[19:50] <@Ebiris> roll 1d20+61
[19:50] <Rei-chan> Ebiris rolled : 1d20+61 --> [ 1d20=15 ]{76}
Afina can hear the faintest whirring in the air.
Meanwhile Dana marches right up to the remnants of the shield wall, tucking into them as well as you two deal with the rest.
> roll 1d20+27 (+4 greater heroism, +2 recitation, +1 haste, -25 PA)
<Serith> Kotono roll for Serith < 42 > [d20=15]
> roll 1d20+27 (+4 greater heroism, +2 recitation, +1 haste, -25 PA) crit threat
<Serith> Kotono roll for Serith < 41 > [d20=14]
> roll 2d6+100
<Serith> Kotono roll for Serith < 109 > [d6=6,3]
More of the line is reduced, strange chanting from the steel devils interrupted by impalement. As Dana fights...
Afina.
Adrian
HP: 385/385
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Greater Heroism (CL27), Epic Mage Armor (CL27), Sublime Revelry (CL31), Mass Death Ward (CL30), Good Hope (CL30), Recitation (CL30)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +4 morale attack/saves, +20 armor bonus, +7 saves, +4d6 goldenfire damage
Dana
HP:392/392
