My action is as I said before, using phase door towards Quinn and detect evil to find his stuff. Sigil should be extra evil, and detect evil penetrates up to a foor of stone on top of the tunnel's cheat.
> roll 1d100 stability, though th eimmediate range is supported thanks to Afina's actions
<Rei-chan> Sunshine_Ko rolled : 1d100 stability, though th eimmediate range is supported thanks to Afina's actions --> [ 1d100=37 ]{37}
There's a few rumbles of the settling stone, but nothing else.
Afina's wall of stone blocks up and supports the sides and ceiling, as...
One problem, Jaela: The door does not allow light, sound, or spell effects through it, nor can you see through it without using it. <--- Phase door explicitly doesn't allow this. If you're going back to your original position and trying it there once you're out of it, that's fair game. But using it while in the phase door tunnel isn't. Go ahead and revise your action to account for this.
I said I was opening a door to where Quinn was. I should remember relative positions since I was flanking him with Afina. If there is no space at the destination I will disintegrate one.
> roll 1d100
<Rei-chan> Sunshine_Ko rolled : 1d100 --> [ 1d100=32 ]{32}]
You got lucky, there's space. If there isn't any, you couldn't reach out through the spell and disintegrate anything, as see the previous post.
There's space - just a little gap above it, barely big enough to crawl into. It scrapes your body and squeezes you tightly, but you can get in there.
Jaela slowly turns her head around and looks for evil!
While Jaela does that Afina checks in with Adrian and Dana. 'Are those elementals having any luck digging you out or want me to summon more help?'
Nothing within a foot of Jaela's vision, besides a general aura of fading evil that's everywhere.
'They're working on it,' Adrian replies.
'Yeah, just fuckin' fine,' Dana sends.
'Nothing,' Jaela reports in frustration, before disintegrating two areas around her and retreating to her phase door, just in case.
[i[> roll 1d100
<Rei-chan> Sunshine_Ko rolled : 1d100 --> [ 1d100=43 ]{43}[/i]
A bunch of rubble falls, but nothing caves in somehow. There! With the open space you can detect overwhelming evil, a sigil ring sitting atop a hunk of stone.
'Got it!' Jaela relays triumphantly, picking it up and storing it away. 'How long before we're linked with Adrian and Dana, Afina?'
She takes the opportunity to look for magic, in case something of value survived the explosion and ended up near the sigil.
[20:42] <@Luiza> roll 1d20+44
[20:42] <Rei-chan> Luiza rolled : 1d20+44 --> [ 1d20=14 ]{58}
Magic is wild and uncontrolled here, auras unreliable. However, your sharp eyes catch a glint of something. Half covered by rubble is a silver bracelet, shiny and smooth. The inside of it is covered with images of birds in flight. It radiates strong magic.
Electing to hurry things along, Afina summons some more elementals to go dig the other two out and brace the rocks around them better.
[18:47] <Ebiris> roll 1d4+1 greater earth elementals
[18:47] <Rei-chan> Ebiris rolled : 1d4+1 greater earth elementals --> [ 1d4=3 ]{4}
Afina 329/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), haste (CL 27), control winds (CL 27), spell turning (CL 26), ferocity of sanguine rage (CL 27)
defences: AC 99 (touch 62), CMD 89, spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, 50% miss chance, freedom of movement
spell slots: 5/9/8/9/6/9/0/6/2/7/4/2/2
Easy enough to do. What's the plan here now, you two?
