The hoard: always (Surraruthru, 84 days left)
Started by Anastasia, September 22, 2017, 02:05:56 PM
Just going to work on that more then? Go ahead and describe the action you're taking.
Well, you said I worked out the ritual. Also since it's a new day, I'll rebuff. I'm not sure if there's anyone around who wants the buffs, NPC or otherwise.
Tapestry:
Elemental Body (fire) CL 28, 28 hour duration
You have the benefits of the attune form spell with respect to the appropriate element. If you choose a water body, for example, you can breathe normally on waterdominant planes.
You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking. You gain darkvision out to 60 feet.
Your creature type remains unchanged, so you are unaffected by spells that target elementals, but you gain the air, earth, fire, or water subtype depending on the elemental substance you chose.
Surraruthru's Stupendous Dragonskin, CL 28, 28 hour duration
Strength of the Dragon Princess, CL 28, 28 hour duration
Mind of the Dragon Princess, CL 28, 28 hour duration
Agility of the Dragon Princess, CL 28, 28 hour duration
Endurance of the Dragon Princess, CL 28, 28 hour duration
The target of this spell gains a +4 insight bonus to Constitution.
Beauty of the Dragon Princess, CL 28, 28 hour duration
The target of this spell gains a +4 insight bonus to Charisma.
Create Magic Tattoo, CL 24, 24 hour duration
+2 competence bonus on attack rolls.
Energy Immunity (x4) CL 26, 24 hour duration
Grants complete protection agianst: acid, cold, electricity, sonic
Quiescent Weaving: Haste, Retributive Enervation, Spell Turning, Greater Mirror Image
Self:
Epic Mage Armor CL 28, 24 hour duration
An invisible but tangible field of force surrounds the subject of epic mage armor, providing a +20 armor bonus to Armor Class. Unlike mundane armor, epic mage armor entails no armor check penalty, arcane spell failure chance, or speed reduction. Because epic mage armor is made of force, incorporeal creatures can't bypass it the way they do normal armor.
Moment of Prescience CL 28, 28 hour duration
This spell grants you a powerful sixth sense in relation to yourself. Once during the spell's duration, you may choose to use its effect. This spell grants you an insight bonus equal to your caster level (maximum +25) on any single attack roll, opposed ability or skill check, or saving throw. Alternatively, you can apply the insight bonus to your AC against a single attack (even if flat-footed). Activating the effect doesn't take an action; you can even activate it on another character's turn if needed. You must choose to use the moment of prescience before you make the roll it is to modify. Once used, the spell ends.
Bibliotheca Arcana, CL 28, 24 hour duration
You gain a +15 insight bonus to all knowledge checks and may make knowledge checks untrained. This knowledge extends to knowledge of your own life. You you have perfect recall of your own memories for the duration of the spell. Effects that change your memories, such as modify memory or mindrape, are suppressed for the duration of the spell. You gain the ability to read and speak all languages during this time, as if affected by a comprehend languages and tongues spell. Finally, you may instantly absorb the information of any written material you touch, as if by a scholar's touch spell. For the duration of the spell, you have perfect recall of the material read in this manner.
Surraruthru sits down to refine the ritual as much as he can before he actually works it, drawing it out as he goes.
"Elena, could you have Tepen and Kascha meet me here? I'd like to get their eyes on this before I attempt it."
"Sure," Elena pops in to say, "Anything else while I'm at it?"
"I'm open to suggestions. With your awareness of everything in Aurora I'm sure you've seen talents in people that might be helpful."
"Well, if you need more mystical analysis, I'd suggest Sylvie. She's really good at it," Elena says, tapping her finger on her chin.
Surraruthru nods.
"Her as well then. Thank you, Elena."
Okay, you want them to all go over it and idiot proof it, basically?
Essentially. Any suggestions for improvement are fully welcome as well. My goal is to retain as much of the Chaos Diamond abilities and hardness/DR/whatever it translates to as possible.
> roll 1d20+58+15 K:A
<Serith> Iddy roll for Serith < 83 > [d20=10]
> roll 1d20+57+15 Spellcraft
<Serith> Iddy roll for Serith < 73 > [d20=1]
The others will all be taking 10.
A few hours pass as the three look over it. It's Tepen who speaks up first when it's all done. "Surraruthru," he begins, "You've cobbled and compressed this ritual down to something you can do in a few hours rather than decades of effort," he begins evenly. "There's a certain amount of inherent risk to that."
"Which means it might go wrong anyway," Sylvie pipes up, "He might also be calling you an idiot in the most polite way possible."
"Ahem!" Tepen clears his throat, then goes on, getting a smile from Sylvie. "In essence, yes. Do be careful. I concede that our needs and pressures dictate such a ritual, but do not take it lightly. Baleruk's support will doubtless help, many rules cease to matter with divinity of any stripe."
"So I've not overlooked anything that you can see. I know all the danger involved, but I've done what I can to mitigate it. Outside of Baleruk helping to bend the rules, so to speak, do you see anything that can be done to improve the odds?"
"On this study, no," Tepen says, "Sylvie, Kascha?"
Kascha shakes her head, "I'm estimating about an 80% chance of success, roughly."
"Somewhere around there," Sylvie replies, wavering a hand back and forth. "It could be a little higher, a little lower, but I think it's within 5 percentage points. Hope Tymora finds you and not Beshaba."
"Hmm... 80% is about as high as I can expect, yes. I am a bit loathe to have Baleruk's help with this. The gods know he'll never be silent about it... But it is what it is, I suppose... Though... What do you think about doing this in the Cauldron?"
