"Our arrogance is our power."
Gar-Malleos
I'll let Canderella dole out the mage armours since she doesn't have anything else to use her 11th level slots on anyway.
Happy to get epic mage armor.
#17
Statblock Here.
Moore is good on the armor since he can just use Surru's from the tapestry.
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 27), True Seeing (CL10), Bibliotecha Arcana (CL27). Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, agility of dragon princess (CL 28), Surraruthru's Stupendous Dragonskin, CL 28, endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 28), magic tattoo (CL 28), energy immunity (acid) (CL 28), energy immunity (sonic) (CL 28), energy immunity (elec) (CL 28)
HP: 363(415)+52
AC: 62 (69), 46 (53) touch, 52 (59) flatfooted 20% miss chance, SR 41, 30 resist all to elements
32/32 Bardic music uses 3/3 Refrain
Fort +36 (38), Ref +40 (42), Will +41 (43) (+6 due to Superior Resistance)
+14 to initiative for everyone
Spells:
0th - 4/4 (DC 22)
1st - 7/7
2nd - 7/7
3rd - 7/7
4th - 7/7
5th - 6/6
6th - 6/6
7th - 6/6
8th - 5/5
9th - 1/1
Favored Soul:
0th - 5/5
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 8/8
7th - 6/6
8th - 4/4
+1 Luck Bonus on Attack Rolls
Additionally, the below are pre-loaded into the Tapestry for activation as Quiescent Weaving:
Resist Energy, CL 26, Duration 260 Minutes. (4 castings)
Subject gains energy resistance to: Acid, Electricity, Fire, Sonic of 30 points.
[/spoiler]
Done. CL24, Jaela. Anyone else?
I mean if she has them to spare Moore will take one!
Done. We'll begin shortly in the next post.
For now though, we have a Surraruthru problem. This is mostly my fault for not getting the tree done. I meant to and just didn't get to it, mostly forgot since this weekend was a thing and I was spacey.
Can some one give me trio of Spellcraft checks for Surru real quick?
I thought Surru's Spellcraft was higher, but I could be wrong there.
#23
Spells I cast on everyone: Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30.
Spell I cast on everyone, it has a short duration: Recitation CL30.
Halved physical damage, negated 'pain' attacks, immunity to negative energy/death effects/energy drain, +2 morale to attack/damage/saves/ability checks/skill checks, +2 luck to AC/attack/saving throws or +3 if worshiping the same religion
Spells Active: Spell Turning CL26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL30, Greater Heroism CL27, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL33, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Epic Mage Armor CL24.
Elemental Body (fire) CL 28, 28 hour duration
You have the benefits of the attune form spell with respect to the appropriate element. If you choose a water body, for example, you can breathe normally on waterdominant planes.
Surraruthru's Stupendous Dragonskin, CL 28, 28 hour duration
Strength of the Dragon Princess, CL 28, 28 hour duration
Mind of the Dragon Princess, CL 28, 28 hour duration
Agility of the Dragon Princess, CL 28, 28 hour duration
Endurance of the Dragon Princess, CL 28, 28 hour duration
The target of this spell gains a +4 insight bonus to Constitution.
Beauty of the Dragon Princess, CL 28, 28 hour duration
The target of this spell gains a +4 insight bonus to Charisma.
Create Magic Tattoo, CL 24, 24 hour duration
+2 competence bonus on attack rolls.
Energy Immunity (x4) CL 26, 24 hour duration
Grants complete protection agianst: acid, cold, electricity, sonic
Init: +18/+22 with Sign
HP: 490+52/490
AC: 83 =75base+2Foresight+3Recitation+1Grace+2cha of the dragon princess, 20% miss chance
AC: 99 =75base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2cha of the dragon princess+5surru's dragonskin/NA+6epic MA/armor, 20% miss chance
Touch AC: 80 =69base+2+3+5+1
Full Attack (Gae Bolg, GMW, HW, DP +3, haste, K:D +5, Greater Heroism +4 morale/attack, Good Hope +2 morale/damage, Recitation +3 luck/attack, CMT +2 competence/attack, SotDP +2 attack/+3 damage, Divine Might +16 damage): +64/+64/+59/+54/+49 or +70 AoO, 4d8+59+11d6+4d6 last is goldenfire and 1 negative level, silver+good+anarchic+epic
[not used: CV +4 sacred attack/damage, Divine Favor +3 luck/damage]
Short Duration Spells: *Grace CL30, *Moonlight Revelation CL30, Recitation CL30, *Haste CL27.
Resistances and Immunities: Fire Immunity, Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry, Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Immunity (Fire).
Spells Left (1-9): 8/9/5/5/8/8/8/6/7
Spells Left (10-12): 8/5/4
DC: 26 + spell level
Saves: conviction +5, shield of warding ref +5, recitation +3, foresight ref +2, haste ref +1, hidden dawn +7, grace ref +1, dex of the dragon princess +2, con of the dragon princess +2
Saves: Fort +68, Ref +69, Will +66
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Turning Left: 19/19
Taking ten for K:A 62, K:N 41, K:R 65, K:P 65, Spellcraft 54
Hidden Dawn used with Canderella
Golden Bracers (Hidden Dawn):
Flame Strike at will
Immunity to fire
Save bonuses increase to +7
You are correct, he has a Knowledge Prism not listed. So 3x 84
Okay. Short version is that he has is tree done. I'll go into more detail with him on this when I have a bit of time with Iddy, hopefully at some point on his vacation.
Ugh, I really dropped the ball on that one. Anyway.
It's time. Everyone is gathering at Aurora's Gates for the assault on Gar-Malleos, and...
Go ahead and set yourselves up.
Neph,  mentioned this in IRC just now, but tossing it for posterity here. Tapestry only goes up to level 10 spells.
"We're expecting heavy opposition against a very entrenched foe here, so we're going to be going in hard and fast to overwhelm them before they can rally more reinforcements," Afina says to those present. "Only three traitors and their sigils are left, and Hell knows as much as we do how important they are for deciding Lifasa's future. Above all else we absolutely must obtain Silvber's sigil. His survival is not a priority, as lately the traitors have become far less useful for providing intelligence. Though be careful of him exploding if you see him within any sort of ritual apparatus."
Moore gives everyone a wave as they arrive.
"For the sake of my own curiosity, do we have any idea of what to expect? Do you expect Taelfagn to try and intercede in this at all, or do you think his efforts are focused elsewhere?"
"That could be a pickle if he shows up," Canderella agrees, "So we're going in as the angry fist of Talos?"
