"Our arrogance is our power."
Gar-Malleos
Posting this as we wait on Iddy, he's incoming.
Canderella
HP: 383/383
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Haste (CL27)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, elemental traits, immunity to elemental damage, +10 armor bonus to AC and damage reduction 10/magic, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls, halved damage from melee attacks, immunity to pain, immunity to negative energy and energy drain, +2 luck AC/attacks/saving throws, +1 attack rolls haste, +1 attacks, movement speed bonus, +1 reflex saves haste.
Resources Used: 2 9th, 2 11th level spells
Mei
HP: 449/502
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Heavenly Grace (CL26), Haste (CL27)
Heavenly Grace
Epic; 9th
You are protected by the forces of righteousness and safe from death. You are immune to negative energy, energy drain, ability damage and ability drain for 24 hours. Creatures who use these against you suffer 7d6 points of damage each time they do.
+16 morale bonus on saving throws against charm and fear effects and a +16 morale bonus on attack and weapon damage rolls. Afina gets +18.
In addition, everyone also gets +2 to attack rolls and +2 to CL as long as they continue to be able to hear him.
Destined Strike, +4 (untyped) to attack and damage rolls, Improved Critical Feat, +14 to threat confirmation.
He's also casting Inspire Great spells with a swift action.
Jaela, Afina, Candy, Surru and Mei all get the benefit of +8d10 temp hp, competence +8 Attack rolls and competence +3 fort. In ADDITION to that, they all get a free widen spell metamagic for their next spell.
This increases the attack bonuses to:
+16 (morale) +2 (untyped) +4 (untyped) +8 (competence)
Weapon damage: +16 (morale), +4 (untyped)
"Let me see..."
Surraruthru inspects the area with his True Seeing and Detect Magic, looking for the trick.
As an aside, I think I asked before but I don't recall the answer; has it been 1 month since Benfal?
It has not.
Make Spellcraft first of all, Surru.
> roll 1d20+57 Spellcraft
<Serith> Iddy roll for Serith < 72 > [d20=15]
What trick in particular are you looking for?
Any kind of magic that'll open a path or a hidden door or the like. I mean, they could have pulled a Secretus and made the place so that there are almost no physical paths, but a keyed teleport ward/system for things to get around, but I'll look for the less complex answer first and go from there.
Afina has Find the Path on her via Jaela pointing her to Gar-Malleos so poke to see if that gives her any pointers.
#277
So I did my stat black and Surraruthru has a bit of a problem. I didn't see any healing outside of the +52 temp HP, which puts him at 125 hp. Basically, the next solid blow or two that hits him will probably kill him.
Edit: Missed the Jaela heals. Surraruthru is fine. However, it occurs to me that I need to invest in Evasion quickly. Apparently, I don't cast enough abjurations to depend on my class ability to supply it.
Surraruthru
HP: 411/411 (359 base)
AC: 52+4 (Deflection)
Touch AC: 24, Flat Footed: 57, SR: 37, CMB: 33, CMD: 51
Init: +12, Touch Atk: 38
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Bibliotheca Arcana (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL26), Epic Mage Armor (CL28), Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30
Passive: True Seeing, Detect Magic, +15 to knowledge checks
Surraruthru does not detect any other magic save for the dimensional blocking he detected before, as well as the magic of the fires.
CL check on Find the Path.
[06:20] <@Luiza> roll 1d20+25
[06:20] <Serith> Luiza roll for Serith < 32 > [d20=7]
Afina can't quite sense anything from it. It's like it's being blocked, unable to quite close in on anything. Most likely wardings against divinations according to Afina's vast knowledge of magical lore.
Would it be reasonable that someone else casting it might have a different effect?
Possibly, IC you don't know about the check but you know sometimes wards can be overcome by stronger casters.
Okay.
'If that didn't work, I can try myself.' Moore offers.
'Can try, I've got nothing,' Afina says, thinking back. That narrow cleft they passed by earlier, just how narrow was it? Too narrow for a human to easily fit through?
